ccgx:swupdate-developer-notes
CCGX - Developer migration notes for swupdate
(draft!)
What is swupdate?
swupdate is the name of the tool we use for image updates. Image updates? Yes, previously the CCGX firmware updates were all done with packages. Not anymore, finally!
For the advantages, see: swupupdate-project#features-for-in-the-change-log.
To learn more background and details, read the rest of that same page.
What has changed for developers?
- the set-feed.sh script is now here:
/opt/victronenergy/swupdate-scripts/ - the root-password will be removed after every update.
- ssh keys will be maintained: so that is what you should use!
- everything not in the /data partition will be gone after an update
What happens during this manual upgrade of a CCGX?
- It saves the contents of the old /data partition
- Formats most of the nand storage, without touching the bootloader, and creates several volumes: kernel1, kernel2, rootfs1, rootfs2, data, etcetera.
- Restores the data partition on the new partition
For even more details see the swupdate script.
ccgx/swupdate-developer-notes.1475604509.txt.gz · Last modified: by mvader
