ccgx:swupdate-developer-notes
ccgx:swupdate-developer-notes [2017-01-24 15:10] – [What is swupdate?] mvaderccgx:swupdate-developer-notes [2017-12-08 13:14] (current) – removed mvader
-====== CCGX - Developer migration notes for swupdate ======
-==== What is swupdate? ====
-swupdate is the name of the tool we use for image updates. Image updates? Yes, previously the CCGX firmware updates were all done with packages. Not anymore, finally!
-For the advantages of image based updating over package based updating, see: [[https://github.com/victronenergy/venus/wiki/swupdate-project#new-features-for-in-the-change-log|swupupdate-project#features-for-in-the-change-log]].
-To learn more background and details, read the rest of that same page.
-==== What has changed for developers? ====
-  * the set-feed.sh script is now here: ''/opt/victronenergy/swupdate-scripts/''
-  * the root-password will be removed after every update. See [[ccgx:root_access|here]] for how to arrange root access again.
-  * ssh keys will be maintained: so that is what you should use!
-  * everything not in the /data partition will be gone after an update
-==== What happens during this manual one-time upgrade of a CCGX? ====
-  - It saves the contents of the old /data partition
-  - Formats most of the nand storage, without touching the bootloader, and creates several volumes: kernel1, kernel2, rootfs1, rootfs2, data, etcetera.
-  - Restores the data partition on the new partition
-For even more details see [[https://github.com/victronenergy/meta-victronenergy/blob/master/meta-venus/recipes-images/venus-upgrade-initramfs/ccgx/swupdate|the swupdate script]].
ccgx/swupdate-developer-notes.1485270606.txt.gz · Last modified: by mvader
