ccgx:start
ccgx:start [2019-05-26 22:59] – [1.5 Connecting a PV Inverter] mvader | ccgx:start [2023-01-19 15:08] (current) – external edit 127.0.0.1 | ||
- | ====== Color Control GX manual ====== | + | The content |
- | The Color Control GX (CCGX) sits at the heart of your energy installation. All the other system-components - such as inverter/ | + | |
- | Monitoring can be done either with the CCGX in front of you - or from anywhere in the world using an internet connection and the [[https:// | + | |
- | The CCGX also provides Remote firmware updates and even allows the settings to be Changed Remotely. | + | |
- | The Color Control GX is part of the [[https:// | + | |
- | If you power the CCGX from an AC adaptor connected to the AC-out port of any VE.Bus product (Inverter, Multi or Quattro), then a deadlock will occur after the VE.Bus products are powered-down for any reason (after any operational fault or during a black start). The VE.Bus devices will not boot-up until the CCGX has power ...but the CCGX will not boot-up until //it// has power. This deadlock can be rectified by briefly unplugging the CCGX VE.Bus cable at which point you will observe the VE.Bus products will immediately begin to boot-up. | + | |
- | [[ccgx_faq## | + | |
- | === Isolation === | + | |
- | Although the number of USB ports can be extended by using a hub, there is a limit to the amount of power that the //onboard USB port// can provide. When extending the number of USB ports, we recommend you always use //powered// USB hubs. And to minimize the chance of issues, be sure to use good-quality USB hubs. As Victron also offers a VE.Direct to USB adapter, you can use this arrangement to increase the number of VE.Direct devices you can connect to your system, [[https:// | + | |
- | === 1.4.1 Multis/ | + | |
- | Note that it is not possible to use the Remote On/Off (header on the VE.Bus control PCB) in combination with a CCGX. There should be wire between the left and middle terminal, as it is when shipped from the factory. In case a wired switch that disables the system is required, use the [[assistants: | + | |
- | __Connecting multiple VE.Bus systems to a single CCGX__\\ | + | |
- | Other notes: | + | |
- | === 1.2.6 VE.Can Resistive Tank Sender Adapter === | + | |
- | See [[https:// | + | |
- | Alternatively, | + | |
- | ==== 1.5 Connecting a PV Inverter ==== | + | |
- | Besides monitoring, the GX device can also curtail some types and brands of PV Inverters, ie. reduce their output power. This is used, and required, for the [[ess: | + | |
- | === Direct connections === | + | |
- | ^ Type ^ Zero feed-in ^ Details ^ | + | |
- | | Fronius | Yes | LAN Connection, see [[ccgx: | + | |
- | | SMA | No | LAN Connection, see [[ccgx: | + | |
- | | SolarEdge | No | LAN Connection, see [[venus-os: | + | |
- | | ABB | Yes | LAN Connection, see [[https:// | + | |
- | === Using a meter === | + | |
- | For PV Inverters that cannot be interfaced digitally, a meter can be used: | + | |
- | | [[https:// | + | |
- | In addition to remote monitoring, an active internet connection allows the CCGX to regularly check for a new firmware versions - which will be automatically downloaded and installed. | + | |
- | * [[venus-os: | + | |
- | The chapters below describe these options in detail. | + | |
- | * Partno. BPP900100200 - CCGX WiFi module simple (Nano USB), small, low cost. | + | |
- | * Partno. BPP900200300 - [[https:// | + | |
- | WiFi modules that are no longer available, but still supported, are: | + | |
- | * Partno. BPP900200100 - [[https:// | + | |
- | * Partno. BPP900100100 - [[https:// | + | |
- | * Partno. BPP900200200 - [[https:// | + | |
- | This is a useful facility when it works - but don't rely on it because it has not proved very dependable. Consult the internet for instructions about tethering for your phone and its particular operating system. We have heard of it working on: | + | |
- | ...but not on: | + | |
- | Almost no installations will need the IP address configuration | + | |
- | See [[ccgx: | + | |
- | |**General** ||| | + | |
- | |**Firmware** ||| | + | |
- | |Disable password check |Password authentication not required for remote consul access.|| | + | |
- | |Enable on LAN |No|Enabling will allow direct connection to the CCGX by typing it's IP address into a web browser. Only Enable this function on trusted networks.| | + | |
- | |Show mobile overview | No |Enable this to show the mobile overview page which is designed for Marine and Remote Vehicle applications. This overview gives direct access to the AC Current limit as well as the // | + | |
- | |Log to |Internet |Choose between //no logging//, //logging via the internet// directly to the VRM Portal, and //logging to a microSD card or USB flash drive//. See chapter 2.2 below for more information. | | + | |
- | |**ESS**||| | + | |
- | |**Hub-4**||| | + | |
- | |**Ethernet** ||| | + | |
- | |**Wi-Fi** ||| | + | |
- | |**GPS** ||| | + | |
- | |**Relay** ||| | + | |
- | |**Services** ||| | + | |
- | Click the thumbnail below to see the complete menu-tree: | + | |
- | ==== 2.4 Battery State of Charge (SOC) ==== | + | |
- | === 2.4.1 Which device should I use for SOC calculation? | + | |
- | __When to use what?__ | + | |
- | If you have a battery with build-in battery monitor, such as a BYD or Freedomwon battery; its easy. Use that. | + | |
- | If the MultiPlus or Quattro inverter/ | + | |
- | If the systems consists of an inverter/ | + | |
- | For any other system types, such as a boat or vehicle with DC lights and other loads, a dedicated battery monitor will be required. | + | |
- | === 2.4.2 The different solutions explained in detail === | + | |
- | Configuration: | + | |
- | * Alternators | + | |
- | * DC-DC chargers | + | |
- | * Wind turbines | + | |
- | * Hydro turbines | + | |
- | - Configure all BMV parameters (see BMV documentation) | + | |
- | - In the CCGX, in Settings -> System setup, verify the selected Battery Monitor. It should be the BMV Battery Monitor. | + | |
- | === 2.4.3 Notes === | + | |
- | More information: | + | |
- | * [[vrm_portal: | + | |
- | * [[ccgx: | + | |
- | === 2.4.4 Selecting SOC source === | + | |
- | The ' | + | |
- | === 2.4.5 Details on VE.Bus SOC === | + | |
- | === 2.5 Customize the logo on the Boat & Motorhome page === | + | |
- | Type the following address into the web browser of a device connected to the same network. Using this address as a template: | + | |
- | http:// | + | |
- | The IP address can be found by going to Settings > Ethernet or Wifi. Once the page is loaded, Choose an image file from your device. Re-boot the VENUS device. | + | |
- | ===== 3 VE.Bus Inverter/ | + | |
- | ==== 3.1 Input current-limiter setting ==== | + | |
- | Also the // | + | |
- | The configured AC input current limit is the total limit //per phase//. | + | |
- | ==== 3.2 Phase rotation warning ==== | + | |
- | The AC supply, either Generator or Grid, to a three phase inverter/ | + | |
- | The '' | + | |
- | On the GX device itself, the warning will be popup as a notification on the GUI: | + | |
- | Also, it is visible in the menus: | + | |
- | And on the VRM Portal, it is visible on the VE.Bus Alarms & warnings widget on the Advanced page: | + | |
- | And also it will be listed in the Alarm Log on VRM, and an email will be sent; using [[: | + | |
- | ===== 4 DVCC - Distributed Voltage and Current Control ===== | + | |
- | ==== 4.1 Introduction and requirements ==== | + | |
- | With DVCC enabled, the [[venus-os: | + | |
- | For example, an Off-grid system with MPPTs, Multis and a diesel generator. The MPPTs are sized and configured such that they charge the battery with the maximum allowed charge current. If the genset starts while there are no AC loads, with DVCC enabled, the Multi will be limited and prioritise the MPPTs. Without DVCC, the Multi would also start charging with its maximum configured charge current. | + | |
- | This system is also used to apply the various | + | |
- | Enabling and disabling DVCC: | + | |
- | * Go to Settings -> System Setup | + | |
- | * Multi/ | + | |
- | * Lynx BMS: v1.09 | + | |
- | In case of installing a MultiGrid 48/3000 the firmware needs to be version 424 or later. | + | |
- | Do not use DVCC in cases where these requirements are not met. | + | |
- | Important: Where batteries are connected via CAN-bus, check the relevant page on the [[battery_compatibility: | + | |
- | ==== 4.2 Generic features ==== | + | |
- | Below features apply to all types of systems when DVCC is enabled: Offgrid, Backup, ESS, marine and others. And applies to all types of batteries: lead batteries as well as lithium batteries, both with and without a CAN-bus BMS connected to the Victron system. | + | |
- | * A user-configurable maximum charge current setting. It works across the whole system. MPPTs are automatically prioritized over the mains/ | + | |
- | * Shared voltage sense (SVS) for VE.Bus devices and VE.Direct Solar Chargers. | + | |
- | ==== 4.3 Features for systems using a CAN-bus BMS systems ==== | + | |
- | These features apply to all types of systems (ESS and not ESS), that have a CAN-bus BMS connected battery. | + | |
- | * CAN-bus BMS control is no longer tied into ESS. It now works for other systems as well, including Off-grid and plain backup systems. It is not longer necessary to wire allow-to-charge and allow-to-discharge connections to the AUX inputs on a Multi or a Quattro. | + | |
- | * VE.Direct MPPT Solar Chargers are now also controlled with the max charge current, just like Multis and Quattros already were. | + | |
- | * When inverting, ie in Island mode, Multis and Quattros will shut down when the max discharge current is zero. They will automatically start again as soon as either AC mains returns, or when BMS increases the max discharge current again. | + | |
- | * New for Off-grid systems only (for ESS systems this was already happening): setting up charge voltages in VEConfigure is no longer necessary: the Multis, Quattros and also MPPT Solar Chargers will charge with the voltage as received via CAN-bus from the battery. | + | |
- | ==== 4.4 Features for ESS ==== | + | |
- | * Fix keep batteries charged. | + | |
- | * Change the solar offset from a variable 2V to a fixed 0.4V. These values are for 48V systems, divide by 4 for 12V. This fixes over voltage warnings and shut-downs as seen on several systems with CAN-bus BMSes. Note that this solar offset is only used by the system when '' | + | |
- | * #1: SOC is low | + | |
- | ===== 5. VRM Portal ===== | + | |
- | ==== 5.1 VRM Portal Introduction ==== | + | |
- | When connected to the internet, a GX device can be used in combination with the [[https:// | + | |
- | * Easy remote access to all statistics and systems status online | + | |
- | * Remote Console on VRM: access and configure your system as if you were standing besides it | + | |
- | * Remote Firmware updates of connected Solar Chargers and other Victron products. | + | |
- | The transmission of the data logs has been designed to work also on bad internet connections. Lines of up to 70% permenant packet loss are still sufficient to get the data out, even if delayed in some cases. | + | |
- | See chapter 1 for how to connect the device to the internet. | + | |
- | ==== 5.2 Setting up VRM ==== | + | |
- | Instructions are in the [[vrm_portal: | + | |
- | Note that any system will need to first have been able to successfully send data to the VRM Portal. As long is there has been no successful connection, it will not be possible to register the system to your VRM user account. In such case, refer to below Troubleshooting section 5.7. | + | |
- | ==== 5.3 Datalogging to VRM ==== | + | |
- | Data-logs are transmitted to the VRM Portal, over the Internet, if it's available. All related settings are available in the VRM Online Portal menu: | + | |
- | === Adding an external storage device === | + | |
- | When unable to transmit the logs, then the GX device will store them to non-volatile storage (ie. data is not lost on a power loss or reboot). | + | |
- | The GX device can store 48 hours worth of logs internally. To extend this period, insert a microSD card or USB stick. You can see the internal storage status in the settings. | + | |
- | Note that, when inserting such storage device, any internally stored logs will automatically be transferred to the inserted stick: no data is lost. | + | |
- | With or without an external storage device inserted, the GX Device will always keep trying to connect to the portal and transmit all backlogged logs. That means that even with months worth of backlog, once it re-acquires an Internet connection, all of the backlog is sent out. The data is sent in a compressed manner: sending a lot of backlogged data will use considerably less bandwidth than than sending the data with a continuously available internet connection. | + | |
- | === Storage device requirements === | + | |
- | * MicroSD cards or USB flash drives must be formatted as FAT12, FAT16 or FAT32 file systems - and not exFAT or NTFS. | + | |
- | * SD and SDHC type microSD cards of 32 GB capacity and smaller are sold containing FAT12, FAT16 or FAT32. They can be used without a problem, unless they are subsequently re-formatted to a different file system. | + | |
- | * SDXC type microSD cards which have greater than 32 GB capacity are often formatted with exFAT, and therefore cannot be used with the CCGX without reformatting and possibly re-partitioning. | + | |
- | === Manually transferring datalogs to VRM === | + | |
- | For devices permanently without Internet, it is possible to take the data out, and then upload it manually from a laptop. | + | |
- | - go to Settings -> VRM Portal, and click '' | + | |
- | - now, remove the storage device and insert it into a computer or laptop that is connected to the internet. | + | |
- | - open a webbrowser, and navigate to the [[https:// | + | |
- | - Login, and then click the ' | + | |
- | - Remove the file from the storage device, and then it re-insert it into the GX Device. Note that uploading the same data twice does not cause any problems; but still it is better not to do that. | + | |
- | When the storage device is full, no more data will be logged. | + | |
- | If multiple storage devices are inserted, the GX device will store the data on the one inserted first. When that is removed, it will **not** use the other one. Instead, it will create an internal backlog buffer. Only inserting a new one will make it switch to using external storage again. | + | |
- | ==== 5.4 Trouble shooting data logging ==== | + | |
- | This chapter explains what to do when the GX Device cannot transmit data to the VRM Portal. | + | |
- | The communication required to send logs to the VRM Portal is: | + | |
- | - Working DNS | + | |
- | Note that the CCGX does not support a proxy setup. For more details on the required networking, see [[https:// | + | |
- | === Step 1: Update the GX Device to the latest available firmware === | + | |
- | [[ccgx: | + | |
- | === Step 2: Verify the network status === | + | |
- | In the menu Settings → Ethernet or Settings → Wi-Fi, check the following: | + | |
- | - State must be ‘Connected’ | + | |
- | - There must be an IP address, that does not start with 169. | + | |
- | - There must be a gateway | + | |
- | - There must be DNS servers | + | |
- | In case the IP address starts with 169, check whether your network has a DHCP server running. 99% of all networks have a DHCP server running and it is enabled by default on all well-known ADSL, cable and 3G routers. If there is no DHCP server running, then configure the ip address manually. | + | |
- | __Ethernet__ | + | |
- | __WiFi__ | + | |
- | === Step 3. Verify VRM Portal Connectivity === | + | |
- | Navigate to Settings → VRM online portal, and check the Connection error status: | + | |
- | If a Connection error is shown, the CCGX is not able to contact the VRM database. The connection error will show an error code that indicates the nature of the connectivity problem. Also, details of the error message are shown, to facilitate on site IT experts to diagnose the problem. | + | |
- | * Error #152 Connection time-out: this could indicate a poor quality internet connection, or a restrictive firewall. | + | |
- | * Error #153 Connection error: this could indicate a routing problem. For details, check the shown error message: {{ : | + | |
- | * Error #154 DNS Failure: Make sure that a valid DNS server is configured in the Ethernet or WiFi menu. Typically this is assigned automatically by a DHCP server in a network. | + | |
- | * Error #159 Unknown error: this is a catch-all error for errors that cannot be directly categorised. In such cases the Error message will provide information about the problem. {{ : | + | |
- | The ' | + | |
- | ==== 5.5 Analysing data offline, without VRM ==== | + | |
- | In certain cases, for example for very remote sites where there is no internet available, it can be useful to be able to analyse the data without first having to upload it to the VRM Portal. | + | |
- | To do so, follow these instructions: | + | |
- | - Install VictronConnect on a Windows or Apple laptop | + | |
- | - Insert the storage device containing the log file(s) | + | |
- | - In VictronConnect, | + | |
- | ===== 6. Marine MFD Glass bridge integration ===== | + | |
- | ==== 6.1 Introduction & requirements ==== | + | |
- | A Glass Bridge is a MFD (Multi-Functional Display) that integrates a boat’s systems and navigation status into a large screen or screens at the helm of the vessel, so doing away with multiple gauges, brackets and wiring complications. | + | |
- | A Victron system can be easily integrated into that, as shown in this video: | + | |
- | https:// | + | |
- | Functionalities: | + | |
- | * Monitor shore power and generator status. | + | |
- | * Monitor battery status for one or more batteries. By using the voltage of for example battery chargers, it can also visualise secondary batteries such as Generator starter batteries. | + | |
- | * Monitor the power conversion equipment: chargers, inverters, inverter/ | + | |
- | * Monitor AC loads, and DC loads. | + | |
- | * Control shore power input current limit. | + | |
- | * Control the inverter/ | + | |
- | * Optionally open the Victron Remote Console panel; allowing access to further parameters. | + | |
- | Power equipment compatibility: | + | |
- | * All Victron inverter/ | + | |
- | Battery Monitors: BMV-700, BMV-702, BMV-712 and newer, Lynx Shunt VE.Can, Lynx Ion BMS. | + | |
- | Requirements: | + | |
- | * Battery system. | + | |
- | * Victron Battery monitor. | + | |
- | * Network cable connection between MFD and a Venus-device such as a Color Control GX, Venus GX or an Octo GX. | + | |
- | * UTP network cable. | + | |
- | ==== 6.2 Detailed instructions ==== | + | |
- | * [[https:// | + | |
- | Raymarine: support on Raymarine MFDs is pending a Raymarine firmware update. [[https:// | + | |
- | Furuno: support on Furuno MFDs is in the pipeline. There is no expected date of availability. | + | |
- | ===== 7 More information resources ===== | + | |
- | * [[open_source: | + | |
- | ~~DISQUS~~ | + | |
+ | Please go to your product on our [[https:// |
ccgx/start.1558904342.txt.gz · Last modified: 2019-05-26 22:59 by mvader
