ccgx:start
ccgx:start [2018-11-16 16:12] – mvader | ccgx:start [2023-01-19 15:08] (current) – external edit 127.0.0.1 | ||
- | ====== Color Control | + | The content of this page has moved to the various |
- | Thank you for choosing the Color Control GX (CCGX). It sits at the heart of your energy installation allowing you to view data; change settings; instigate powerful functions; tailor | + | Please go to your product on our [[https:// |
- | All this can be done either with the CCGX in front of you - or from anywhere in the world using an internet connection on the [[https:// | + | |
- | If you power the CCGX from an AC adaptor connected to the AC-out port of any VE.Bus | + | |
- | [[ccgx_faq## | + | |
- | === Isolation === | + | |
- | Although the number of USB ports can be extended by using a hub, there is a limit to the amount of power that the //onboard USB port// can provide. When extending the number of USB ports, we recommend you always use //powered// USB hubs. And to minimize the chance of issues, be sure to use good-quality USB hubs. | + | |
- | === 1.4.1 Multis/ | + | |
- | Note that it is not possible to use the Remote On/Off (header | + | |
- | __Connecting multiple VE.Bus | + | |
- | Other notes: | + | |
- | === 1.2.6 VE.Can Resistive Tank Sender Adapter === | + | |
- | See [[https:// | + | |
- | Alternatively, | + | |
- | ==== 1.5 Measuring PV Inverter output ==== | + | |
- | There are several ways to get the system to show the output of a PV Inverter: | + | |
- | - [[https:// | + | |
- | - [[http:// | + | |
- | - Using a [[https:// | + | |
- | - By using [[https:// | + | |
- | In addition to remote | + | |
- | The four chapters below describe these options in detail. | + | |
- | * CCGX WiFi module simple (Nano USB), small, low cost. Victron part number BPP900100200 | + | |
- | * [[https:// | + | |
- | This is a useful facility when it works - but don't rely on it because it has not proved very dependable. Consult the internet for instructions about tethering for your phone and its particular operating | + | |
- | ...but not on: | + | |
- | Almost no installations will need the IP address configuration to be inserted manually as most systems support automatic IP configuration (DHCP) - and that is also the CCGX default setting. If you do need to configure the address manually, select the following template: | + | |
- | See [[ccgx: | + | |
- | |**General** ||| | + | |
- | |**Firmware** ||| | + | |
- | |Disable password check |Password authentication not required for remote consul access.|| | + | |
- | |Enable on LAN |No|Enabling will allow direct connection to the CCGX by typing it's IP address into a web browser. Only Enable this function on trusted networks.| | + | |
- | |Show mobile overview | No |Enable this to show the mobile overview | + | |
- | |Log to |Internet |Choose between //no logging//, //logging via the internet// directly to the VRM Portal, and //logging to a microSD card or USB flash drive//. See chapter 2.2 below for more information. | | + | |
- | |**ESS**||| | + | |
- | |**Hub-4**||| | + | |
- | |**Ethernet** ||| | + | |
- | |**Wi-Fi** ||| | + | |
- | |**GPS** ||| | + | |
- | |**Relay** ||| | + | |
- | |**Services** ||| | + | |
- | Click the thumbnail below to see the complete menu-tree: | + | |
- | ==== 2.2 Logging data for the VRM portal ==== | + | |
- | The CCGX can be used in combination with the [[https:// | + | |
- | Since version 1.40, dealing with an absent or intermittent internet connection has changed. Data is sent out via the Internet if it's available, and will fall back to non-volatile storage when there is a (temporary) Internet outage. The built-in non-volatile storage can contain 48 hours worth of data. To extend this period, one can insert an microSD card or USB stick, and the CCGX will automatically transfer any data that may reside on the internal storage to it, and will start using this external memory as backlog buffer. You can see that it's active in the settings menu: | + | |
- | When using this external memory, it will still make use of an active internet connection to send its backlog. That means that even with months worth of backlog, once the CCGX re-acquires an Internet connection, all of the backlog is sent out. And because of an enhanced algorithm, this takes considerably less time and traffic than before. | + | |
- | When a CCGX is permanently without Internet, one can choose to upload the backlog buffer manually. The first step is to use the GUI (Graphical User Interface) to eject the storage (don't just remove the SD-card/ | + | |
- | It's important to know that when the microSD card or USB stick is re-inserted, | + | |
- | Because of the aforementioned improvement in sending of backlog data, the data logging is also highly resillient to bad internet connections. Lines of up to 70% permenant packet loss are still sufficient to get the data out, albeit somewhat delayed. | + | |
- | When the storage device is full, no more data will be logged. This is due to the nature of Sqlite files. Removing data from the Sqlite database doesn' | + | |
- | If both a microSD card and a USB flash drive are connected to the CCGX, then data is logged to the one that was inserted first. If one is removed, the CCGX will not try to write to the other, but will create an internal backlog buffer until a new storage medium is inserted when it will use that storage medium. | + | |
- | *MicroSD cards or USB flash drives must be formatted as FAT12, FAT16 or FAT32 file systems - and not exFAT or NTFS. | + | |
- | *SD and SDHC type microSD cards of 32 GB capacity and smaller are sold containing FAT12, FAT16 or FAT32. They can be used without a problem, unless they are subsequently re-formatted to a different file system. | + | |
- | *SDXC type microSD cards which have greater than 32 GB capacity are often formatted with exFAT, and therefore cannot be used with the CCGX without reformatting and possibly re-partitioning. | + | |
- | ==== 2.3 Using the Multi and Quattro input current-limiter setting ==== | + | |
- | Also the // | + | |
- | The configured input limit is the total limit //per phase//. | + | |
- | ==== 2.4 Battery State of Charge (SOC) ==== | + | |
- | === 2.4.1 Which device should I use for SOC calculation? | + | |
- | For some systems types it is necessary to use a dedicated battery monitor, such as a BMV or Lynx Shunt VE.Can. For other systems it is not necessary: the built-in SOC calculator in the Multi/ | + | |
- | Explaining the different system types one by one: | + | |
- | Configuration: | + | |
- | * Alternators | + | |
- | * DC-DC chargers | + | |
- | * Wind turbines | + | |
- | * Hydro turbines | + | |
- | - Configure all BMV parameters (see BMV documentation) | + | |
- | - In the CCGX, in Settings -> System setup, verify the selected Battery Monitor. It should be the BMV Battery Monitor. | + | |
- | === 2.4.2 Notes === | + | |
- | More information: | + | |
- | * [[vrm_portal: | + | |
- | * [[ccgx: | + | |
- | === 2.4.3 Selecting SOC source === | + | |
- | The ' | + | |
- | === 2.4.4 Details on VE.Bus SOC === | + | |
- | === 2.5 Customize the logo on the Boat & Motorhome page === | + | |
- | Typic the following address into the web browser of a device connected to the same network. Using this address as a template: | + | |
- | http:// | + | |
- | The IP address can be found by going to Settings > Ethernet or Wifi. Once the page is loaded, Choose an image file from your device. Re-boot the VENUS device. | + | |
- | ===== 3 DVCC - Distributed Voltage and Current Control ===== | + | |
- | ==== 3.1 Introduction and requirements ==== | + | |
- | With DVCC enabled, the Venus-device takes a more central role in the Victron system, improving and changing system behaviour. | + | |
- | Enabling and disabling DVCC: | + | |
- | * Go to Settings -> System Setup | + | |
- | * Multi/ | + | |
- | * Lynx BMS: v1.09 | + | |
- | In case of installing a MultiGrid 48/3000 the firmware needs to be version 424 or later. | + | |
- | Do not use DVCC in cases where these requirements are not met. | + | |
- | Important: Where batteries are connected via CAN-bus, check the relevant page on the [[battery_compatibility: | + | |
- | Minimum firmware for the Lynx Ion + Shunt | + | |
- | ==== 3.2 Generic features ==== | + | |
- | Below features apply to all types of systems, and all types of batteries. Both lead batteries and batteries with a CAN-bus BMS. | + | |
- | * Add a user-configurable maximum charge current setting. This is available in the Venus GUI (Settings -> System Setup) and works across the whole system. MPPTs are automatically prioritized over the mains. In case a CANBUS-BMS is connected and the BMS requests a maximum charge current that is different from the user-configurable setting, the lower of the two will be used. | + | |
- | * Add shared voltage sense (SVS) for VE.Bus devices and VE.Direct Solar Chargers. | + | |
- | ==== 3.3 Features for systems using a CAN-bus BMS systems ==== | + | |
- | These features apply to all types of systems (ESS and not ESS), that have a CAN-bus BMS connected battery. | + | |
- | * CAN-bus BMS control is no longer tied into ESS. It now works for other systems as well, including Off-grid and plain backup systems. It is not longer necessary to wire allow-to-charge and allow-to-discharge connections to the AUX inputs on a Multi or a Quattro. | + | |
- | * VE.Direct MPPT Solar Chargers are now also controlled with the max charge current, just like Multis and Quattros already were. | + | |
- | * When inverting, ie in Island mode, Multis and Quattros will shut down when the max discharge current is zero. They will automatically start again as soon as either AC mains returns, or when BMS increases the max discharge current again. | + | |
- | * New for Off-grid systems only (for ESS systems this was already happening): setting up charge voltages in VEConfigure is no longer necessary: the Multis, Quattros and also MPPT Solar Chargers will charge with the voltage as received via CAN-bus from the battery. | + | |
- | ==== 3.4 Features for ESS ==== | + | |
- | * Fix keep batteries charged. | + | |
- | * Change the solar offset from a variable 2V to a fixed 0.4V. These values are for 48V systems, divide by 4 for 12V. This fixes over voltage warnings and shut-downs as seen on several systems with CAN-bus BMSes. Note that this solar offset is only used by the system when '' | + | |
- | * #1: SOC is low | + | |
- | ===== 4 More information resources ===== | + | |
- | * [[open_source: | + | |
ccgx/start.1542381152.txt.gz · Last modified: 2018-11-16 16:12 by mvader
