ccgx:start [2020-06-27 21:21] mvader [7.2 Supported devices / PGNs] |
ccgx:start [2020-10-15 10:37] ictbeheer Added more vncrelays; load balancing |
Line 111: | Line 111: | ||
__Connecting more than two devices to your CCGX using VE.Direct__ | __Connecting more than two devices to your CCGX using VE.Direct__ | ||
- | First of all, note that the maximum of VE.Direct devices that can be connected is 5 for the CCGX. How they are connected, so direct, via USB or via CAN, does not change the maximum. See [[venus-os: | + | First of all, note that the maximum of VE.Direct devices that can be connected is 5 for the CCGX. How they are connected, so direct, via USB or via CAN, does not change the maximum. See [[venus-os: |
+ | Then, these are the options on how to connect more VE.Direct products than available VE.Direct ports: | ||
*Option 1: Use the [[https:// | *Option 1: Use the [[https:// | ||
- | *Option 2: The BMV700 and BMV702 | + | *Option 2: (Only!) the BMV700 and BMV702 can also be connected using the [[https:// |
__Notes about older VE.Direct MPPTs__\\ | __Notes about older VE.Direct MPPTs__\\ | ||
Line 150: | Line 152: | ||
Make sure that the canbus is powered, see the [[https:// | Make sure that the canbus is powered, see the [[https:// | ||
- | === 1.4.7 NMEA Tank senders from other manufacturers === | ||
- | A tank sender must meet the following requirements to be visible on the CCGX: | ||
- | * Transmit the NMEA2000 Fluid Level PGN, 127505 | ||
- | * The NMEA2000 device class needs to be ' | ||
- | * The NMEA2000 function needs to be ' | ||
- | Since v2.17 the following functions are accepted as well: | ||
- | * The NMEA2000 device class ' | ||
- | A single function reporting multiple Fluid Levels is currently not supported. | ||
- | For some tank senders it is also possible to configure the capacity and the fluid type from the CCGX - for example the Maretron TLA100. This facility may be available with other senders made by other manufacturers - it's well-worth trying. | ||
- | To connect an NMEA2000 network to the VE.Can port on the CCGX, use a [[https:// | ||
- | Alternatively, | ||
==== 1.5 Connecting a PV Inverter ==== | ==== 1.5 Connecting a PV Inverter ==== | ||
Line 220: | Line 204: | ||
=== 1.6.2 Wi-Fi USB dongle === | === 1.6.2 Wi-Fi USB dongle === | ||
- | Using a Wi-Fi dongle it is possible to connect to WEP, WPA and WPA2 secured networks. There are four supported USB Wi-Fi dongles. Two of them are also available from stock at Victron Energy: | + | Using a Wi-Fi dongle it is possible to connect to WEP, WPA and WPA2 secured networks. There are five supported USB Wi-Fi dongles. Two of them are also available from stock at Victron Energy: |
* Partno. BPP900100200 - CCGX WiFi module simple (Nano USB), small, low cost. | * Partno. BPP900100200 - CCGX WiFi module simple (Nano USB), small, low cost. | ||
Line 314: | Line 298: | ||
See [[ccgx: | See [[ccgx: | ||
- | ==== 1.9 Connecting NMEA-2000 tank senders ==== | + | ==== 1.9 Connecting |
A third party NMEA2000 tank sender must meet the following requirements to be visible on the GX Device: | A third party NMEA2000 tank sender must meet the following requirements to be visible on the GX Device: | ||
Line 322: | Line 306: | ||
A single function reporting multiple Fluid Levels is currently not supported. | A single function reporting multiple Fluid Levels is currently not supported. | ||
- | For some tank senders it is also possible to configure the capacity and the fluid type on the GX Device - for example the Maretron TLA100. This facility may be available with other senders made by other manufacturers - it's well-worth trying. | + | For some tank senders it is also possible to configure the capacity and the fluid type on the GX Device |
- | To connect an NMEA2000 network to the VE.Can port on the CCGX, use a [[https:// | + | Tested |
- | Alternatively, | + | |
- | Tested NMEA2000 tank senders: | + | |
* Maretron TLA100 | * Maretron TLA100 | ||
* Maretron TLM100 | * Maretron TLM100 | ||
- | * Navico Fluid Level Sensor Fuel-0 PK, partno. 000-11518-001. Note that this sender requires a 12V powered NMEA2000 network; it breaks when connected to a 24V-powered NMEA2000 network. And note that you need a Navico display to configure the Capacity, Fluid type, and other parameters of the sensor. | + | * Navico Fluid Level Sensor Fuel-0 PK, partno. 000-11518-001. Note that you need a Navico display to configure the Capacity, Fluid type, and other parameters of the sensor. |
+ | * Oceanic Systems (UK) Ltd (OSUKL) - 3271 Volumetric Tank Sender. In case it doesn’t work, it needs a firmware update. Contact OSUKL for that. **See voltage warning below** | ||
+ | * Oceanic Systems UK Ltd (OSUKL) - 3281 Water Level Sender. **See voltage warning below** | ||
Most likely others work as well. If you know of one working well, please edit this page -or- get in touch with us on [[https:// | Most likely others work as well. If you know of one working well, please edit this page -or- get in touch with us on [[https:// | ||
+ | To connect an NMEA2000 network to the VE.Can port on the CCGX, which both have different type connectors, there are two solutions: | ||
+ | - The [[https:// | ||
+ | **Warning and solution for 24V and 48V systems** | ||
+ | Whilst all Victron components can work up to 70V input on their CAN-bus connections, | ||
==== 1.10 Connecting IMT Solar Irradiance, Temperature and Wind Speed Sensors ==== | ==== 1.10 Connecting IMT Solar Irradiance, Temperature and Wind Speed Sensors ==== | ||
Line 355: | Line 346: | ||
The required interface software is pre-installed within the Venus OS, however the Victron GX device must be running recent firmware - FW v2.40 is the minimum requirement. | The required interface software is pre-installed within the Venus OS, however the Victron GX device must be running recent firmware - FW v2.40 is the minimum requirement. | ||
- | Physical connection to the Vicron | + | Physical connection to the Victron |
A suitable external DC power source (12 to 28 VDC) is also required - the sensor is NOT powered via USB. | A suitable external DC power source (12 to 28 VDC) is also required - the sensor is NOT powered via USB. | ||
Line 1086: | Line 1077: | ||
- [[https:// | - [[https:// | ||
+ | - [[https:// | ||
=== Technical background === | === Technical background === | ||
To have Remote Console on VRM working, your web browser and the GX Device need to have a connection between them. This connection is designed such that it doesn' | To have Remote Console on VRM working, your web browser and the GX Device need to have a connection between them. This connection is designed such that it doesn' | ||
- | When Remote Console on VRM is enabled, the GX Device will open and maintain a connection to any of the servers pointed to by supporthosts.victronenergy.com. Which currently resolves to two IP addresses (84.22.107.120 and 84.22.108.49), and likely more in the future. The technology used is ssh, and it will try to connect using port 22, 80 and 443, only one of them needs to work. The reason for it to try all three is that on most networks one of them will be allowed by the local firewall. | + | When Remote Console on VRM is enabled, the GX Device will open and maintain a connection to any of the servers pointed to by supporthosts.victronenergy.com. Which currently resolves to multiple |
Once connected to one of the supporthost servers, that reverse ssh tunnel is waiting to be connected from someone needing the connection. Which can be your browser, or a Victron engineer since this same technology is used for the Remote Support functionality; | Once connected to one of the supporthost servers, that reverse ssh tunnel is waiting to be connected from someone needing the connection. Which can be your browser, or a Victron engineer since this same technology is used for the Remote Support functionality; | ||
Line 1136: | Line 1130: | ||
* [[venus-os: | * [[venus-os: | ||
Line 1194: | Line 1188: | ||
Since both functions transmit the same PGNs, for example an AC Status PGN containing voltage, current and more information, | Since both functions transmit the same PGNs, for example an AC Status PGN containing voltage, current and more information, | ||
based on the network address. Depending on the function belonging to that network address the need to interpret it as either Inverter Input or Inverter Output. Displays not being capable of doing so will regard the data as belonging to the mains (utility). The Inverter Output is then interpreted as utility #0 and Inverter Input as utility #1. These default instance numbers can be changed by a network configuration tool if necessary. | based on the network address. Depending on the function belonging to that network address the need to interpret it as either Inverter Input or Inverter Output. Displays not being capable of doing so will regard the data as belonging to the mains (utility). The Inverter Output is then interpreted as utility #0 and Inverter Input as utility #1. These default instance numbers can be changed by a network configuration tool if necessary. | ||
+ | Battery temperature as measured by the inverter(/ | ||
+ | All VREG communications need to be sent to be sent to the address representing the Inverter function. The other one, AC input, does not support VREG requests: that address only transmits AC information related to the AC input. | ||
=== Inverters === | === Inverters === | ||
Line 1205: | Line 1203: | ||
=== Solar chargers === | === Solar chargers === | ||
- | Not yet supported by the NMEA2000-out function but in the works and expected after in a firmware update after the summer of 2020. | + | Supported. Battery related values as well as the PV Array Voltage & Current is made available on the NMEA2000 |
=== Tank level data === | === Tank level data === | ||
- | Not yet supported | + | Supported. Tank levels measured |
=== Other data and product types === | === Other data and product types === | ||
Not supported. Above explicitly mentioned types are the only ones now supported. For example data from a charger (such as the Phoenix Smart Charger connected via VE.Direct) is not supported and not expected to be supported soon. | Not supported. Above explicitly mentioned types are the only ones now supported. For example data from a charger (such as the Phoenix Smart Charger connected via VE.Direct) is not supported and not expected to be supported soon. | ||
- | ==== 7.3 Related menu settings | + | ==== 7.3 Configuration |
^ Setting ^ Default ^ Description ^ | ^ Setting ^ Default ^ Description ^ | ||
- | | CAN-bus | + | | CAN-bus |
- | | Send data to VE.Can | + | | NMEA2000-out |
- | | Unique | + | | Unique |
| Check unique numbers | | Searches for other devices that use the same unique number. When the search is completed it will respond with either an OK, or the text \\ '' | | Check unique numbers | | Searches for other devices that use the same unique number. When the search is completed it will respond with either an OK, or the text \\ '' | ||
+ | ==== 7.4 Configuring device instances ==== | ||
+ | The Devices submenu gives access to a list showing all detected Devices on the VE.Can / NMEA-2000 network: | ||
+ | Each entry first shows the name - either the product name as in our database, or when configured, the custom name as configured during installation. | ||
+ | Then, between the square brackets, the Unique Identity Number is shown. | ||
+ | On the right, you can see the VE.Can Device Instance which is the same as the NMEA-2000 Device Instance. | ||
+ | Press enter to Edit that Device Instance. Or, press the right-key to go one step deeper in the menu structure, to a page that shows all generic data available for that device: | ||
==== 7.4 NMEA2000-out technical details ==== | ==== 7.4 NMEA2000-out technical details ==== | ||
Line 1326: | Line 1340: | ||
- For an [[ess: | - For an [[ess: | ||
- | - For systems with managed batteries, the same. | + | - For systems with managed batteries |
- For both Solar chargers, as well as AC-Connected battery chargers, when connected in a VE.Can network, they will synchronise their operation. Charge state and such. For that function to work, all chargers must be configured to the same device instance. | - For both Solar chargers, as well as AC-Connected battery chargers, when connected in a VE.Can network, they will synchronise their operation. Charge state and such. For that function to work, all chargers must be configured to the same device instance. | ||
Line 1390: | Line 1404: | ||
Whats new since Venus OS v2.40 is (a) that it automatically enables DVCC when it sees the above mentioned battery types, and (b) that when DVCC is enabled, it checks the connected devices for the minimum firmware, and raises Error #48 in case the firmware of one or more connected devices is too old. | Whats new since Venus OS v2.40 is (a) that it automatically enables DVCC when it sees the above mentioned battery types, and (b) that when DVCC is enabled, it checks the connected devices for the minimum firmware, and raises Error #48 in case the firmware of one or more connected devices is too old. | ||
+ | ==== GX Error #49 - Grid meter not found ==== | ||
+ | This warning is raised in an ESS system when Grid metering is configured to use an External meter, but no meter is present. This alerts installers and end-users that the system is not correctly configured, or cannot operate correctly because it cannot communicate with the grid meter. | ||
===== 9 More information resources ===== | ===== 9 More information resources ===== | ||
[[https:// | [[https:// |
