ccgx:start
ccgx:start [2019-10-10 16:35] – guy_stewart | ccgx:start [2019-10-18 13:04] – [6.2 Compatible MFDs and instructions] guy_stewart | ||
Line 569: | Line 569: | ||
The AC supply, either Generator or Grid, to a three phase inverter/ | The AC supply, either Generator or Grid, to a three phase inverter/ | ||
- | The '' | + | The '' |
On the GX device itself, the warning will be popup as a notification on the GUI: | On the GX device itself, the warning will be popup as a notification on the GUI: | ||
Line 912: | Line 912: | ||
* Monitor battery status for one or more batteries. By using the voltage of for example battery chargers, it can also visualise secondary batteries such as Generator starter batteries. | * Monitor battery status for one or more batteries. By using the voltage of for example battery chargers, it can also visualise secondary batteries such as Generator starter batteries. | ||
* Monitor the power conversion equipment: chargers, inverters, inverter/ | * Monitor the power conversion equipment: chargers, inverters, inverter/ | ||
- | * Monitor solar production from an MPPT. | + | * Monitor solar production from an MPPT Solar Charger. |
* Monitor AC loads, and DC loads. | * Monitor AC loads, and DC loads. | ||
* Control shore power input current limit. | * Control shore power input current limit. | ||
Line 918: | Line 918: | ||
* Optionally open the Victron Remote Console panel; allowing access to further parameters. | * Optionally open the Victron Remote Console panel; allowing access to further parameters. | ||
- | Power equipment compatibility: | + | Victron |
* All Victron inverter/ | * All Victron inverter/ | ||
* Battery Monitors: BMV-700, BMV-702, BMV-712 and newer, Lynx Shunt VE.Can, Lynx Ion BMS. | * Battery Monitors: BMV-700, BMV-702, BMV-712 and newer, Lynx Shunt VE.Can, Lynx Ion BMS. | ||
* All Victron MPPT Solar Charge Controllers | * All Victron MPPT Solar Charge Controllers | ||
- | Requirements: | + | Required components: |
* Battery system. | * Battery system. | ||
* Victron inverter/ | * Victron inverter/ | ||
Line 932: | Line 932: | ||
==== 6.2 Compatible MFDs and instructions ==== | ==== 6.2 Compatible MFDs and instructions ==== | ||
- | * [[https://docs.victronenergy.com/ | + | * [[https://www.victronenergy.com/ |
* [[venus-os: | * [[venus-os: | ||
Line 938: | Line 938: | ||
Furuno: support on Furuno MFDs is in the pipeline. There is no expected date of availability. | Furuno: support on Furuno MFDs is in the pipeline. There is no expected date of availability. | ||
===== 7 More information resources ===== | ===== 7 More information resources ===== | ||
