ccgx:start
ccgx:start [2019-10-03 13:32] – [5.4 Trouble shooting data logging] mvader | ccgx:start [2019-10-18 10:41] – [6.1 Introduction & requirements] mvader | ||
Line 335: | Line 335: | ||
|Enable password check | Choose password to allow remote console access.|| | |Enable password check | Choose password to allow remote console access.|| | ||
|Enable on VRM |No|Enabling on VRM will allow connection to the CCGX from anywhere via the VRM portal. [[vrm_portal: | |Enable on VRM |No|Enabling on VRM will allow connection to the CCGX from anywhere via the VRM portal. [[vrm_portal: | ||
- | |Enable on LAN |No|Enabling will allow direct connection to the CCGX by typing | + | |Enable on LAN |No|Enabling will allow direct connection to the CCGX by typing |
|**System setup** ||| | |**System setup** ||| | ||
|AC input 1 |Generator |Select Generator or Grid. (We will shortly be adding the setting 'Shore power' instead of grid.) | | |AC input 1 |Generator |Select Generator or Grid. (We will shortly be adding the setting 'Shore power' instead of grid.) | | ||
Line 569: | Line 569: | ||
The AC supply, either Generator or Grid, to a three phase inverter/ | The AC supply, either Generator or Grid, to a three phase inverter/ | ||
- | The '' | + | The '' |
On the GX device itself, the warning will be popup as a notification on the GUI: | On the GX device itself, the warning will be popup as a notification on the GUI: | ||
Line 904: | Line 904: | ||
https:// | https:// | ||
Functionalities: | Functionalities: | ||
Line 910: | Line 912: | ||
* Monitor battery status for one or more batteries. By using the voltage of for example battery chargers, it can also visualise secondary batteries such as Generator starter batteries. | * Monitor battery status for one or more batteries. By using the voltage of for example battery chargers, it can also visualise secondary batteries such as Generator starter batteries. | ||
* Monitor the power conversion equipment: chargers, inverters, inverter/ | * Monitor the power conversion equipment: chargers, inverters, inverter/ | ||
+ | * Monitor solar production from an MPPT Solar Charger. | ||
* Monitor AC loads, and DC loads. | * Monitor AC loads, and DC loads. | ||
* Control shore power input current limit. | * Control shore power input current limit. | ||
Line 915: | Line 918: | ||
* Optionally open the Victron Remote Console panel; allowing access to further parameters. | * Optionally open the Victron Remote Console panel; allowing access to further parameters. | ||
- | Power equipment compatibility: | + | Victron |
* All Victron inverter/ | * All Victron inverter/ | ||
- | Battery Monitors: BMV-700, BMV-702, BMV-712 and newer, Lynx Shunt VE.Can, Lynx Ion BMS. | + | * Battery Monitors: BMV-700, BMV-702, BMV-712 and newer, Lynx Shunt VE.Can, Lynx Ion BMS. |
+ | * All Victron MPPT Solar Charge Controllers | ||
- | Requirements: | + | Required components: |
* Battery system. | * Battery system. | ||
* Victron inverter/ | * Victron inverter/ | ||
Line 930: | Line 934: | ||
* [[venus-os: | * [[venus-os: | ||
+ | * [[venus-os: | ||
- | Raymarine: support on Raymarine MFDs is pending a Raymarine firmware update. [[https:// | ||
Furuno: support on Furuno MFDs is in the pipeline. There is no expected date of availability. | Furuno: support on Furuno MFDs is in the pipeline. There is no expected date of availability. | ||
Line 951: | Line 955: | ||
