ccgx:start
ccgx:start [2019-08-28 23:57] – [4.4 DVCC features for all systems] mvader | ccgx:start [2019-10-01 11:28] – [2.1 Configurable parameters] guy_stewart | ||
Line 178: | Line 178: | ||
| SMA | No | LAN Connection, see [[ccgx: | | SMA | No | LAN Connection, see [[ccgx: | ||
| SolarEdge | No | LAN Connection, see [[venus-os: | | SolarEdge | No | LAN Connection, see [[venus-os: | ||
- | | ABB | Yes | LAN Connection, see [[https:// | + | | ABB | Yes | LAN Connection, see [[https:// |
=== Using a meter === | === Using a meter === | ||
Line 186: | Line 186: | ||
^ Type ^ Zero feed-in ^ Details ^ | ^ Type ^ Zero feed-in ^ Details ^ | ||
| [[https:// | | [[https:// | ||
- | | [[https:// | + | | [[https:// |
- | | [[https:// | + | | Wireless AC sensors | No | See the [[ccgx: |
==== 1.6 Internet connectivity ==== | ==== 1.6 Internet connectivity ==== | ||
Line 335: | Line 335: | ||
|Enable password check | Choose password to allow remote console access.|| | |Enable password check | Choose password to allow remote console access.|| | ||
|Enable on VRM |No|Enabling on VRM will allow connection to the CCGX from anywhere via the VRM portal. [[vrm_portal: | |Enable on VRM |No|Enabling on VRM will allow connection to the CCGX from anywhere via the VRM portal. [[vrm_portal: | ||
- | |Enable on LAN |No|Enabling will allow direct connection to the CCGX by typing it's IP address into a web browser. Only Enable this function on trusted networks.| | + | |Enable on LAN |No|Enabling will allow direct connection to the CCGX by typing it's IP address into a web browser. Only Enable this function on trusted networks. |
|**System setup** ||| | |**System setup** ||| | ||
|AC input 1 |Generator |Select Generator or Grid. (We will shortly be adding the setting 'Shore power' instead of grid.) | | |AC input 1 |Generator |Select Generator or Grid. (We will shortly be adding the setting 'Shore power' instead of grid.) | | ||
Line 391: | Line 391: | ||
==== 2.4 Battery State of Charge (SOC) ==== | ==== 2.4 Battery State of Charge (SOC) ==== | ||
Line 928: | Line 927: | ||
Raymarine: support on Raymarine MFDs is pending a Raymarine firmware update. [[https:// | Raymarine: support on Raymarine MFDs is pending a Raymarine firmware update. [[https:// |
