ccgx:start
ccgx:start [2019-08-13 09:29] – [4.4 DVCC features for all systems] andyalford | ccgx:start [2023-01-19 15:08] (current) – external edit 127.0.0.1 | ||
- | ====== Color Control GX manual ====== | + | The content |
- | The Color Control GX (CCGX) sits at the heart of your energy installation. All the other system-components - such as inverter/ | + | |
- | Monitoring can be done either with the CCGX in front of you - or from anywhere in the world using an internet connection and the [[https:// | + | |
- | The CCGX also provides Remote firmware updates and even allows the settings to be Changed Remotely. | + | |
- | The Color Control GX is part of the [[https:// | + | |
- | If you power the CCGX from an AC adaptor connected to the AC-out port of any VE.Bus product (Inverter, Multi or Quattro), then a deadlock will occur after the VE.Bus products are powered-down for any reason (after any operational fault or during a black start). The VE.Bus devices will not boot-up until the CCGX has power ...but the CCGX will not boot-up until //it// has power. This deadlock can be rectified by briefly unplugging the CCGX VE.Bus cable at which point you will observe the VE.Bus products will immediately begin to boot-up. | + | |
- | [[ccgx_faq## | + | |
- | === Isolation === | + | |
- | Although the number of USB ports can be extended by using a hub, there is a limit to the amount of power that the //onboard USB port// can provide. When extending the number of USB ports, we recommend you always use //powered// USB hubs. And to minimize the chance of issues, be sure to use good-quality USB hubs. As Victron also offers a VE.Direct to USB adapter, you can use this arrangement to increase the number of VE.Direct devices you can connect to your system, [[https:// | + | |
- | === 1.4.1 Multis/ | + | |
- | Note that it is not possible to use the Remote On/Off (header on the VE.Bus control PCB) in combination with a CCGX. There should be wire between the left and middle terminal, as it is when shipped from the factory. In case a wired switch that disables the system is required, use the [[assistants: | + | |
- | __Connecting multiple VE.Bus systems to a single CCGX__\\ | + | |
- | Other notes: | + | |
- | === 1.2.6 VE.Can Resistive Tank Sender Adapter === | + | |
- | See [[https:// | + | |
- | Alternatively, | + | |
- | ==== 1.5 Connecting a PV Inverter ==== | + | |
- | Besides monitoring, the GX device can also curtail some types and brands of PV Inverters, ie. reduce their output power. This is used, and required, for the [[ess: | + | |
- | === Direct connections === | + | |
- | ^ Type ^ Zero feed-in ^ Details ^ | + | |
- | | Fronius | Yes | LAN Connection, see [[ccgx: | + | |
- | | SMA | No | LAN Connection, see [[ccgx: | + | |
- | | SolarEdge | No | LAN Connection, see [[venus-os: | + | |
- | | ABB | Yes | LAN Connection, see [[https:// | + | |
- | === Using a meter === | + | |
- | For PV Inverters that cannot be interfaced digitally, a meter can be used: | + | |
- | | [[https:// | + | |
- | In addition to remote monitoring, an active internet connection allows the CCGX to regularly check for a new firmware versions - which will be automatically downloaded and installed. | + | |
- | * [[venus-os: | + | |
- | This video explains how to connect LAN, WiFi and a GX GSM: | + | |
- | {{youtube> | + | |
- | The chapters below describe the options in detail. | + | |
- | * Partno. BPP900100200 - CCGX WiFi module simple (Nano USB), small, low cost. | + | |
- | * Partno. BPP900200300 - [[https:// | + | |
- | WiFi modules that are no longer available, but still supported, are: | + | |
- | * Partno. BPP900200100 - [[https:// | + | |
- | * Partno. BPP900100100 - [[https:// | + | |
- | * Partno. BPP900200200 - [[https:// | + | |
- | This is a useful facility when it works - but don't rely on it because it has not proved very dependable. Consult the internet for instructions about tethering for your phone and its particular operating system. We have heard of it working on: | + | |
- | ...but not on: | + | |
- | Almost no installations will need the IP address configuration | + | |
- | See [[ccgx: | + | |
- | |**General** ||| | + | |
- | |**Firmware** ||| | + | |
- | |Disable password check |Password authentication not required for remote console access.|| | + | |
- | |Enable on LAN |No|Enabling will allow direct connection to the CCGX by typing it's IP address into a web browser. Only Enable this function on trusted networks.| | + | |
- | |Show mobile overview | No |Enable this to show the mobile overview page which is designed for Marine and Remote Vehicle applications. This overview gives direct access to the AC Current limit as well as the // | + | |
- | |Log to |Internet |Choose between //no logging//, //logging via the internet// directly to the VRM Portal, and //logging to a microSD card or USB flash drive//. See chapter 2.2 below for more information. | | + | |
- | |**ESS**||| | + | |
- | |**Hub-4**||| | + | |
- | |**Ethernet** ||| | + | |
- | |**Wi-Fi** ||| | + | |
- | |**GPS** ||| | + | |
- | |**Relay** ||| | + | |
- | |**Services** ||| | + | |
- | Click the thumbnail below to see the complete menu-tree: | + | |
- | ==== 2.4 Battery State of Charge (SOC) ==== | + | |
- | === 2.4.1 Which device should I use for SOC calculation? | + | |
- | __When to use what?__ | + | |
- | If you have a battery with build-in battery monitor, such as a BYD or Freedomwon battery; its easy. Use that. | + | |
- | If the MultiPlus or Quattro inverter/ | + | |
- | If the systems consists of an inverter/ | + | |
- | For any other system types, such as a boat or vehicle with DC lights and other loads, a dedicated battery monitor will be required. | + | |
- | === 2.4.2 The different solutions explained in detail === | + | |
- | Configuration: | + | |
- | * Alternators | + | |
- | * DC-DC chargers | + | |
- | * Wind turbines | + | |
- | * Hydro turbines | + | |
- | - Configure all BMV parameters (see BMV documentation) | + | |
- | - In the CCGX, in Settings -> System setup, verify the selected Battery Monitor. It should be the BMV Battery Monitor. | + | |
- | === 2.4.3 Notes === | + | |
- | More information: | + | |
- | * [[vrm_portal: | + | |
- | * [[ccgx: | + | |
- | === 2.4.4 Selecting SOC source === | + | |
- | The ' | + | |
- | === 2.4.5 Details on VE.Bus SOC === | + | |
- | === 2.5 Customize the logo on the Boat & Motorhome page === | + | |
- | Type the following address into the web browser of a device connected to the same network. Using this address as a template: | + | |
- | http:// | + | |
- | The IP address can be found by going to Settings > Ethernet or Wifi. Once the page is loaded, Choose an image file from your device. Re-boot the VENUS device. | + | |
- | ===== 3 VE.Bus Inverter/ | + | |
- | ==== 3.1 Input current-limiter setting ==== | + | |
- | Also the // | + | |
- | The configured AC input current limit is the total limit //per phase//. | + | |
- | ==== 3.2 Phase rotation warning ==== | + | |
- | The AC supply, either Generator or Grid, to a three phase inverter/ | + | |
- | The '' | + | |
- | On the GX device itself, the warning will be popup as a notification on the GUI: | + | |
- | Also, it is visible in the menus: | + | |
- | And on the VRM Portal, it is visible on the VE.Bus Alarms & warnings widget on the Advanced page: | + | |
- | And also it will be listed in the Alarm Log on VRM, and an email will be sent; using [[: | + | |
- | ===== 4 DVCC - Distributed Voltage and Current Control ===== | + | |
- | ==== 4.1 Introduction and features ==== | + | |
- | Enabling DVCC changes a GX device from a passive monitor into an active controller. | + | |
- | For example, in systems with an intelligent CAN-bus BMS battery connected, the GX receives a Charge Voltage Limit (CVL), Charge Current Limit (CCL), Discharge Current Limit (DCL) from that battery and relays that to the connected inverter/ | + | |
- | For systems with lead batteries, DVCC offers features such as a configurable system wide charge current limit and shared temperature sense. | + | |
- | As also in above example, the available features and effects of enabling DVCC depend on the type of battery used. The effect also depends on the installed Victron components and their configuration. | + | |
- | For the details, carefully study below chapters to fully understand DVCC for a particular system. | + | |
- | To enable or disable DVCC, see Settings -> System Setup in the menus. | + | |
- | ==== 4.2 DVCC Requirements ==== | + | |
- | === Battery compatilibity === | + | |
- | For CAN-bus connected batteries, check the relevant page on the [[battery_compatibility: | + | |
- | === Firmware versions === | + | |
- | Do not use DVCC in cases where these requirements are not met. In all cases we recommend to install the latest available firmware during commissioning. Once running well, there is no need to pro-actively update firmware without reason. In case of difficulty, the first action is to update firmware. | + | |
- | * Multi/ | + | |
- | * MultiGrid: 424 | + | |
- | * Lynx BMS: v1.09 | + | |
- | ==== 4.3 DVCC effects on the charge algorithm ==== | + | |
- | Our inverter/ | + | |
- | In certain systems, the internal charge algorithm is disabled, and the charger is then working with an externally controlled charge voltage target. | + | |
- | This guide explains the different possibilities: | + | |
- | === Internal === | + | |
- | The internal charge algorithm (bulk -> absorption -> float -> re-bulk), and the configured charge voltages are active. | + | |
- | Inverter/ | + | |
- | MPPT indicated charge state: bulk, absorption, float and-so-forth. (firmware version v1.42 onwards. Earlier versions have a bug that make the MPPT say "Ext. Control" | + | |
- | === Inverter/ | + | |
- | The MPPTs internal charge algorithm is disabled; instead it's being controlled by a charge voltage setpoint coming from the inverter/ | + | |
- | MPPT indicated charge state: Ext. control. | + | |
- | === Battery === | + | |
- | The internal charge algorithm is disabled; and instead, the device is being controlled by the battery. | + | |
- | ==== 4.4 DVCC features for all systems ==== | + | |
- | These features apply to all types of systems when DVCC is enabled: with or without ESS Assistant, and with lead or other normal batteries as well as when an intelligent CAN-bus BMS connected battery is installed: | + | |
- | === Limit charge current === | + | |
- | This is a user-configurable maximum charge current setting. It works across the whole system. MPPT Solar Chargers are automatically prioritized over the mains/ | + | |
- | This setting is available in the " | + | |
- | Particulars: | + | |
- | 1) In case a CANBUS-BMS is connected and the BMS requests a maximum charge current that is different from the user-configurable setting, the lower of the two will be used. | + | |
- | 2) this mechanism only works for Victron inverter/ | + | |
- | 3) DC Loads are not accounted for. Even when a BMV or other battery monitor is installed. For example, with a configured maximum charge current of 50 Amps, and DC Loads drawing 20 Amps, the battery will be charged with 30 Amps. Not with the full allowed 50 Amps. | + | |
- | 4) In all situations, the maximum charge limit configured in a device itself, ie. the Charge current limit set with VictronConnect or VEConfigure for the Solar chargers or Inverter/ | + | |
- | === Shared Voltage Sense (SVS) === | + | |
- | Works with VE.Bus devices and VE.Direct Solar Chargers. | + | |
- | The system automatically selects the best available voltage measurement. It will use the voltage from the BMS or a BMV battery monitor, if possible, otherwise it will use the battery voltage reported by the VE.Bus system. | + | |
- | The voltage displayed on the GUI reflects the same voltage measurement. | + | |
- | Shared Voltage Sense (SVS) is by default enabled when DVCC is enabled. It can be disabled with a switch in the Settings -> System Setup menu. | + | |
- | === Shared Temperature Sense (STS) === | + | |
- | tbd | + | |
- | ==== 4.5 DVCC Features when using CAN-bus BMS Battery ==== | + | |
- | This chapter applies to all systems where an intelligent battery BMS is installed, and connected via CAN-bus. Note that this does not include the Victron VE.Bus BMS. | + | |
- | Such intelligent BMS sends four parameters to the GX device: | + | |
- | - Charge voltage limit (CVL): the maximum charge voltage that the battery currently accepts. | + | |
- | - Charge current limit (CCL): the maximum charge current requested by the battery. | + | |
- | - Discharge current limit (DCL): the maximum discharge current as requested by the battery. | + | |
- | For all three parameters, some types of batteries transmit dynamic values. For example they determine the maximum charge voltage based on cell voltages, state of charge, or for example temperature. Other makes and brands use a fixed value. | + | |
- | Here is the page in the menus showing the parameters: | + | |
- | For such batteries, there is no need to wire allow-to-charge and allow-to-discharge connections to the AUX inputs on a Multi or a Quattro. | + | |
- | When inverting, ie in Island mode, Multis and Quattros will shut down when the max discharge current is zero. They will automatically start again as soon as either AC mains returns, or when the BMS increases the max discharge current again. | + | |
- | All above means that setting up charge voltages or charge profiles in VEConfigure or VictronConnect is not necessary, and will also have no effect. The Multis, Quattros and MPPT Solar Chargers will charge with the voltage as received via CAN-bus from the battery. | + | |
- | ==== 4.6 DVCC for systems with the ESS Assistant ==== | + | |
- | * The ESS '' | + | |
- | * A fixed solar offset of 0.4V is used instead of a variable 2V. (values for 48V systems, divide by 4 for 12V). Note that this solar offset is only applied when '' | + | |
- | * #1: Low SOC: discharge disabled | + | |
- | * #3: Charging disabled by BMS | + | |
- | * #4: Discharging disabled by BMS | + | |
- | ===== 5. VRM Portal ===== | + | |
- | ==== 5.1 VRM Portal Introduction ==== | + | |
- | When connected to the internet, a GX device can be used in combination with the [[https:// | + | |
- | * Easy remote access to all statistics and systems status online | + | |
- | * Remote Console on VRM: access and configure your system as if you were standing besides it | + | |
- | * Remote Firmware updates of connected Solar Chargers and other Victron products. | + | |
- | See chapter 1 for how to connect the device to the internet. | + | |
- | ==== 5.2 Registering on VRM ==== | + | |
- | Instructions are in the [[vrm_portal: | + | |
- | Note that any system will need to first have been able to successfully send data to the VRM Portal. As long is there has been no successful connection, it will not be possible to register the system to your VRM user account. In such case, refer to below Troubleshooting section 5.7. | + | |
- | ==== 5.3 Datalogging to VRM ==== | + | |
- | Data-logs are transmitted to the VRM Portal over the Internet, if it's available. All related settings are available in the VRM Online Portal menu: | + | |
- | The transmission of the data logs has been designed to work also on bad internet connections. Lines of up to 70% permenant packet loss are still sufficient to get the data out, even if delayed in some cases. | + | |
- | === Adding an external storage device === | + | |
- | When unable to transmit the logs, then the GX device will store them to non-volatile storage (ie. data is not lost on a power loss or reboot). | + | |
- | The GX device can store 48 hours worth of logs internally. To extend this period, insert a microSD card or USB stick. You can see the internal storage status in the settings. | + | |
- | Note that, when inserting such storage device, any internally stored logs will automatically be transferred to the inserted stick: no data is lost. | + | |
- | With or without an external storage device inserted, the GX Device will always keep trying to connect to the portal and transmit all backlogged logs. That means that even with months worth of backlog, once it re-acquires an Internet connection, all of the backlog is sent out. The data is sent in a compressed manner: sending a lot of backlogged data will use considerably less bandwidth than than sending the data with a continuously available internet connection. | + | |
- | === Storage device requirements === | + | |
- | * MicroSD cards or USB flash drives must be formatted as FAT12, FAT16 or FAT32 file systems - and not exFAT or NTFS. | + | |
- | * SD and SDHC type microSD cards of 32 GB capacity and smaller are sold containing FAT12, FAT16 or FAT32. They can be used without a problem, unless they are subsequently re-formatted to a different file system. | + | |
- | * SDXC type microSD cards which have greater than 32 GB capacity are often formatted with exFAT, and therefore cannot be used with the CCGX without reformatting and possibly re-partitioning. | + | |
- | === Manually transferring datalogs to VRM === | + | |
- | For devices permanently without Internet, it is possible to take the data out, and then upload it manually from a laptop. | + | |
- | - go to Settings -> VRM Portal, and click '' | + | |
- | - now, remove the storage device and insert it into a computer or laptop that is connected to the internet. | + | |
- | - open a webbrowser, and navigate to the [[https:// | + | |
- | - Login, and then click the ' | + | |
- | - Remove the file from the storage device, and then it re-insert it into the GX Device. Note that uploading the same data twice does not cause any problems; but still it is better not to do that. | + | |
- | When the storage device is full, no more data will be logged. | + | |
- | If multiple storage devices are inserted, the GX device will store the data on the one inserted first. When that is removed, it will **not** use the other one. Instead, it will create an internal backlog buffer. Only inserting a new one will make it switch to using external storage again. | + | |
- | === Network watchdog: auto-reboot === | + | |
- | This feature, disabled by default, makes the GX device automatically reboot itself in case it has not been able to connect to the VRM Portal. | + | |
- | ==== 5.4 Trouble shooting data logging ==== | + | |
- | This chapter explains what to do when the GX Device cannot transmit data to the VRM Portal. | + | |
- | The communication required to send logs to the VRM Portal is: | + | |
- | - Working DNS | + | |
- | Note that the CCGX does not support a proxy setup. For more details on the required networking, see [[https:// | + | |
- | === Step 1: Update the GX Device to the latest available firmware === | + | |
- | [[ccgx: | + | |
- | === Step 2: Verify the network status === | + | |
- | In the menu Settings → Ethernet or Settings → Wi-Fi, check the following: | + | |
- | - State must be ‘Connected’ | + | |
- | - There must be an IP address, that does not start with 169. | + | |
- | - There must be a gateway | + | |
- | - There must be DNS servers | + | |
- | In case the IP address starts with 169, check whether your network has a DHCP server running. 99% of all networks have a DHCP server running and it is enabled by default on all well-known ADSL, cable and 3G routers. If there is no DHCP server running, then configure the ip address manually. | + | |
- | __Ethernet__ | + | |
- | __WiFi__ | + | |
- | === Step 3. Verify VRM Portal Connectivity === | + | |
- | Navigate to Settings → VRM online portal, and check the Connection error status: | + | |
- | If a Connection error is shown, the CCGX is not able to contact the VRM database. The connection error will show an error code that indicates the nature of the connectivity problem. Also, details of the error message are shown, to facilitate on site IT experts to diagnose the problem. | + | |
- | * Error #150 Unexpected response text: A connection succeeded, but the result was incorrect. This might indicate that a transparent proxy is hijacking the connection. Examples include a WiFi login page or a cellular providers payment page. | + | |
- | * Error #151 Unexpected HTTP Response: A connection succeeded, but the response did not indicate a successful HTTP result code (normally 200). This might indicate that a transparent proxy is hijacking the connection. See #150 above for examples. | + | |
- | * Error #152 Connection time-out: this could indicate a poor quality internet connection, or a restrictive firewall. | + | |
- | * Error #153 Connection error: this could indicate a routing problem. For details, check the shown error message: {{ : | + | |
- | * Error #154 DNS Failure: Make sure that a valid DNS server is configured in the Ethernet or WiFi menu. Typically this is assigned automatically by a DHCP server in a network. | + | |
- | * Error #155 Routing error: VRM is unreachable. This error occurs if an ICMP error is received indicating that no route exists to the VRM server. Make sure your DHCP server assigns a working default route, or that the gateway is correctly configured for static configurations. | + | |
- | * Error #159 Unknown error: this is a catch-all error for errors that cannot be directly categorised. In such cases the Error message will provide information about the problem. {{ : | + | |
- | The ' | + | |
- | ==== 5.5 Analysing data offline, without VRM ==== | + | |
- | In certain cases, for example for very remote sites where there is no internet available, it can be useful to be able to analyse the data without first having to upload it to the VRM Portal. | + | |
- | - Install VictronConnect on a Windows or Apple laptop | + | |
- | - Insert the storage device containing the log file(s) | + | |
- | - In VictronConnect, | + | |
- | ==== 5.6 Remote Console on VRM ==== | + | |
- | This feature allows full remote control of a GX Device, over the internet: | + | |
- | Remote Console on VRM is disabled by default. Activate it by following these steps: | + | |
- | - Enabling the feature in the Settings -> Remote Console menu | + | |
- | - Either set a password; or disable the password | + | |
- | - Restart the GX Device. | + | |
- | Now, the Remote Console option will appear in the menu on the VRM Portal. Click it to open the Remote Console: | + | |
- | Trouble shooting tips: | + | |
- | - Make sure that basic communication with VRM works, see chapter 5.4. | + | |
- | - Also make sure to restart the CCGX. | + | |
- | - Make sure to update the CCGX to the latest firmware version. The last stability improvement for Remote Console was made in version v2.30. | + | |
- | ===== 6. Marine MFD Glass bridge integration ===== | + | |
- | ==== 6.1 Introduction & requirements ==== | + | |
- | A Glass Bridge is a MFD (Multi-Functional Display) that integrates a boat’s systems and navigation status into a large screen or screens at the helm of the vessel, so doing away with multiple gauges, brackets and wiring complications. | + | |
- | A Victron system can be easily integrated into that, as shown in this video: | + | |
- | https:// | + | |
- | Functionalities: | + | |
- | * Monitor shore power and generator status. | + | |
- | * Monitor battery status for one or more batteries. By using the voltage of for example battery chargers, it can also visualise secondary batteries such as Generator starter batteries. | + | |
- | * Monitor the power conversion equipment: chargers, inverters, inverter/ | + | |
- | * Monitor AC loads, and DC loads. | + | |
- | * Control shore power input current limit. | + | |
- | * Control the inverter/ | + | |
- | * Optionally open the Victron Remote Console panel; allowing access to further parameters. | + | |
- | Power equipment compatibility: | + | |
- | * All Victron inverter/ | + | |
- | Battery Monitors: BMV-700, BMV-702, BMV-712 and newer, Lynx Shunt VE.Can, Lynx Ion BMS. | + | |
- | Requirements: | + | |
- | * Battery system. | + | |
- | * Victron Battery monitor. | + | |
- | * Network cable connection between MFD and a Venus-device such as a Color Control GX, Venus GX or an Octo GX. | + | |
- | * UTP network cable. | + | |
- | ==== 6.2 Detailed instructions ==== | + | |
- | * [[https:// | + | |
- | Raymarine: support on Raymarine MFDs is pending a Raymarine firmware update. [[https:// | + | |
- | Furuno: support on Furuno MFDs is in the pipeline. There is no expected date of availability. | + | |
- | ===== 7 More information resources ===== | + | |
- | * [[open_source: | + | |
- | ~~DISQUS~~ | + | |
+ | Please go to your product on our [[https:// |
