ccgx:start
ccgx:start [2019-06-11 10:46] – [5.4 Trouble shooting data logging] iburger | ccgx:start [2019-06-11 22:10] – [4.3 DVCC effects on the charge algorithm] mvader | ||
Line 590: | Line 590: | ||
As also in above example, the available features and effects of enabling DVCC depend on the type of battery used. The also depends on the installed Victron components and their configuration. | As also in above example, the available features and effects of enabling DVCC depend on the type of battery used. The also depends on the installed Victron components and their configuration. | ||
- | {{ :ccgx:dvcc_table.png? | + | {{ :ccgx:dvcc_table2.png? |
For the details, carefully study below chapters to fully understand DVCC for a particular system. | For the details, carefully study below chapters to fully understand DVCC for a particular system. | ||
Line 636: | Line 636: | ||
Inverter/ | Inverter/ | ||
- | MPPT indicated charge state: bulk, absorption, float and-so-forth. (firmware version v1.42 onwards. Earlier versions have a bug that, even though | + | MPPT indicated charge state: bulk, absorption, float and-so-forth. (firmware version v1.42 onwards. Earlier versions have a bug that make the MPPT say "Ext. Control" |
=== Inverter/ | === Inverter/ |
