ccgx:start
ccgx:start [2019-05-21 11:45] – thiemovanengelen | ccgx:start [2023-01-19 15:08] (current) – external edit 127.0.0.1 | ||
- | ====== Color Control GX manual ====== | + | The content |
- | The Color Control GX (CCGX) sits at the heart of your energy installation. All the other system-components - such as inverter/ | + | |
- | Monitoring can be done either with the CCGX in front of you - or from anywhere in the world using an internet connection and the [[https:// | + | |
- | The CCGX also provides Remote firmware updates and even allows the settings to be Changed Remotely. | + | |
- | The Color Control GX is part of the [[https:// | + | |
- | If you power the CCGX from an AC adaptor connected to the AC-out port of any VE.Bus product (Inverter, Multi or Quattro), then a deadlock will occur after the VE.Bus products are powered-down for any reason (after any operational fault or during a black start). The VE.Bus devices will not boot-up until the CCGX has power ...but the CCGX will not boot-up until //it// has power. This deadlock can be rectified by briefly unplugging the CCGX VE.Bus cable at which point you will observe the VE.Bus products will immediately begin to boot-up. | + | |
- | [[ccgx_faq## | + | |
- | === Isolation === | + | |
- | Although the number of USB ports can be extended by using a hub, there is a limit to the amount of power that the //onboard USB port// can provide. When extending the number of USB ports, we recommend you always use //powered// USB hubs. And to minimize the chance of issues, be sure to use good-quality USB hubs. As Victron also offers a VE.Direct to USB adapter, you can use this arrangement to increase the number of VE.Direct devices you can connect to your system, [[https:// | + | |
- | === 1.4.1 Multis/ | + | |
- | Note that it is not possible to use the Remote On/Off (header on the VE.Bus control PCB) in combination with a CCGX. There should be wire between the left and middle terminal, as it is when shipped from the factory. In case a wired switch that disables the system is required, use the [[assistants: | + | |
- | __Connecting multiple VE.Bus systems to a single CCGX__\\ | + | |
- | Other notes: | + | |
- | === 1.2.6 VE.Can Resistive Tank Sender Adapter === | + | |
- | See [[https:// | + | |
- | Alternatively, | + | |
- | ==== 1.5 Monitoring PV Inverter output ==== | + | |
- | There are several ways to get the system to show the output of a PV Inverter: | + | |
- | - [[https:// | + | |
- | - [[http:// | + | |
- | - Using a [[https:// | + | |
- | - By using [[https:// | + | |
- | In addition to remote monitoring, an active internet connection allows the CCGX to regularly check for a new firmware versions - which will be automatically downloaded and installed. | + | |
- | * [[venus-os: | + | |
- | The chapters below describe these options in detail. | + | |
- | * Partno. BPP900100200 - CCGX WiFi module simple (Nano USB), small, low cost. | + | |
- | * Partno. BPP900200300 - [[https:// | + | |
- | WiFi modules that are no longer available, but still supported, are: | + | |
- | * Partno. BPP900200100 - [[https:// | + | |
- | * Partno. BPP900100100 - [[https:// | + | |
- | * Partno. BPP900200200 - [[https:// | + | |
- | This is a useful facility when it works - but don't rely on it because it has not proved very dependable. Consult the internet for instructions about tethering for your phone and its particular operating system. We have heard of it working on: | + | |
- | ...but not on: | + | |
- | Almost no installations will need the IP address configuration | + | |
- | See [[ccgx: | + | |
- | |**General** ||| | + | |
- | |**Firmware** ||| | + | |
- | |Disable password check |Password authentication not required for remote consul access.|| | + | |
- | |Enable on LAN |No|Enabling will allow direct connection to the CCGX by typing it's IP address into a web browser. Only Enable this function on trusted networks.| | + | |
- | |Show mobile overview | No |Enable this to show the mobile overview page which is designed for Marine and Remote Vehicle applications. This overview gives direct access to the AC Current limit as well as the // | + | |
- | |Log to |Internet |Choose between //no logging//, //logging via the internet// directly to the VRM Portal, and //logging to a microSD card or USB flash drive//. See chapter 2.2 below for more information. | | + | |
- | |**ESS**||| | + | |
- | |**Hub-4**||| | + | |
- | |**Ethernet** ||| | + | |
- | |**Wi-Fi** ||| | + | |
- | |**GPS** ||| | + | |
- | |**Relay** ||| | + | |
- | |**Services** ||| | + | |
- | Click the thumbnail below to see the complete menu-tree: | + | |
- | ==== 2.2 Logging data for the VRM portal ==== | + | |
- | The CCGX can be used in combination with the [[https:// | + | |
- | Since version 1.40, dealing with an absent or intermittent internet connection has changed. Data is sent out via the Internet if it's available, and will fall back to non-volatile storage when there is a (temporary) Internet outage. The built-in non-volatile storage can contain 48 hours worth of data. To extend this period, one can insert an microSD card or USB stick, and the CCGX will automatically transfer any data that may reside on the internal storage to it, and will start using this external memory as backlog buffer. You can see that it's active in the settings menu: | + | |
- | When using this external memory, it will still make use of an active internet connection to send its backlog. That means that even with months worth of backlog, once the CCGX re-acquires an Internet connection, all of the backlog is sent out. And because of an enhanced algorithm, this takes considerably less time and traffic than before. | + | |
- | When a CCGX is permanently without Internet, one can choose to upload the backlog buffer manually. The first step is to use the GUI (Graphical User Interface) to eject the storage (don't just remove the SD-card/ | + | |
- | It's important to know that when the microSD card or USB stick is re-inserted, | + | |
- | Because of the aforementioned improvement in sending of backlog data, the data logging is also highly resillient to bad internet connections. Lines of up to 70% permenant packet loss are still sufficient to get the data out, albeit somewhat delayed. | + | |
- | When the storage device is full, no more data will be logged. This is due to the nature of Sqlite files. Removing data from the Sqlite database doesn' | + | |
- | If both a microSD card and a USB flash drive are connected to the CCGX, then data is logged to the one that was inserted first. If one is removed, the CCGX will not try to write to the other, but will create an internal backlog buffer until a new storage medium is inserted when it will use that storage medium. | + | |
- | *MicroSD cards or USB flash drives must be formatted as FAT12, FAT16 or FAT32 file systems - and not exFAT or NTFS. | + | |
- | *SD and SDHC type microSD cards of 32 GB capacity and smaller are sold containing FAT12, FAT16 or FAT32. They can be used without a problem, unless they are subsequently re-formatted to a different file system. | + | |
- | *SDXC type microSD cards which have greater than 32 GB capacity are often formatted with exFAT, and therefore cannot be used with the CCGX without reformatting and possibly re-partitioning. | + | |
- | ==== 2.3 Using the Multi and Quattro input current-limiter setting ==== | + | |
- | Also the // | + | |
- | The configured input limit is the total limit //per phase//. | + | |
- | ==== 2.4 Battery State of Charge (SOC) ==== | + | |
- | === 2.4.1 Which device should I use for SOC calculation? | + | |
- | __When to use what?__ | + | |
- | If you have a battery with build-in battery monitor, such as a BYD or Freedomwon battery; its easy. Use that. | + | |
- | If the MultiPlus or Quattro inverter/ | + | |
- | If the systems consists of an inverter/ | + | |
- | For any other system types, such as a boat or vehicle with DC lights and other loads, a dedicated battery monitor will be required. | + | |
- | === 2.4.2 The different solutions explained in detail === | + | |
- | Configuration: | + | |
- | * Alternators | + | |
- | * DC-DC chargers | + | |
- | * Wind turbines | + | |
- | * Hydro turbines | + | |
- | - Configure all BMV parameters (see BMV documentation) | + | |
- | - In the CCGX, in Settings -> System setup, verify the selected Battery Monitor. It should be the BMV Battery Monitor. | + | |
- | === 2.4.3 Notes === | + | |
- | More information: | + | |
- | * [[vrm_portal: | + | |
- | * [[ccgx: | + | |
- | === 2.4.4 Selecting SOC source === | + | |
- | The ' | + | |
- | === 2.4.5 Details on VE.Bus SOC === | + | |
- | === 2.5 Customize the logo on the Boat & Motorhome page === | + | |
- | Type the following address into the web browser of a device connected to the same network. Using this address as a template: | + | |
- | http:// | + | |
- | The IP address can be found by going to Settings > Ethernet or Wifi. Once the page is loaded, Choose an image file from your device. Re-boot the VENUS device. | + | |
- | ===== 3 DVCC - Distributed Voltage and Current Control ===== | + | |
- | ==== 3.1 Introduction and requirements ==== | + | |
- | With DVCC enabled, the [[venus-os: | + | |
- | For example, an Off-grid system with MPPTs, Multis and a diesel generator. The MPPTs are sized and configured such that they charge the battery with the maximum allowed charge current. If the genset starts while there are no AC loads, with DVCC enabled, the Multi will be limited and prioritise the MPPTs. Without DVCC, the Multi would also start charging with its maximum configured charge current. | + | |
- | This system is also used to apply the various | + | |
- | Enabling and disabling DVCC: | + | |
- | * Go to Settings -> System Setup | + | |
- | * Multi/ | + | |
- | * Lynx BMS: v1.09 | + | |
- | In case of installing a MultiGrid 48/3000 the firmware needs to be version 424 or later. | + | |
- | Do not use DVCC in cases where these requirements are not met. | + | |
- | Important: Where batteries are connected via CAN-bus, check the relevant page on the [[battery_compatibility: | + | |
- | ==== 3.2 Generic features ==== | + | |
- | Below features apply to all types of systems when DVCC is enabled: Offgrid, Backup, ESS, marine and others. And applies to all types of batteries: lead batteries as well as lithium batteries, both with and without a CAN-bus BMS connected to the Victron system. | + | |
- | * A user-configurable maximum charge current setting. It works across the whole system. MPPTs are automatically prioritized over the mains/ | + | |
- | * Shared voltage sense (SVS) for VE.Bus devices and VE.Direct Solar Chargers. | + | |
- | ==== 3.3 Features for systems using a CAN-bus BMS systems ==== | + | |
- | These features apply to all types of systems (ESS and not ESS), that have a CAN-bus BMS connected battery. | + | |
- | * CAN-bus BMS control is no longer tied into ESS. It now works for other systems as well, including Off-grid and plain backup systems. It is not longer necessary to wire allow-to-charge and allow-to-discharge connections to the AUX inputs on a Multi or a Quattro. | + | |
- | * VE.Direct MPPT Solar Chargers are now also controlled with the max charge current, just like Multis and Quattros already were. | + | |
- | * When inverting, ie in Island mode, Multis and Quattros will shut down when the max discharge current is zero. They will automatically start again as soon as either AC mains returns, or when BMS increases the max discharge current again. | + | |
- | * New for Off-grid systems only (for ESS systems this was already happening): setting up charge voltages in VEConfigure is no longer necessary: the Multis, Quattros and also MPPT Solar Chargers will charge with the voltage as received via CAN-bus from the battery. | + | |
- | ==== 3.4 Features for ESS ==== | + | |
- | * Fix keep batteries charged. | + | |
- | * Change the solar offset from a variable 2V to a fixed 0.4V. These values are for 48V systems, divide by 4 for 12V. This fixes over voltage warnings and shut-downs as seen on several systems with CAN-bus BMSes. Note that this solar offset is only used by the system when '' | + | |
- | * #1: SOC is low | + | |
- | ===== 4 More information resources ===== | + | |
- | * [[https:// | + | |
- | * [[open_source: | + | |
- | ~~DISQUS~~ | + | |
+ | Please go to your product on our [[https:// |
