ccgx:start
ccgx:start [2019-01-22 10:16] – external edit 127.0.0.1 | ccgx:start [2019-03-26 08:35] – mvader | ||
====== Color Control GX manual ====== | ====== Color Control GX manual ====== | ||
- | Thank you for choosing the Color Control GX (CCGX). It sits at the heart of your energy installation allowing you to view data; change settings; instigate powerful functions; tailor your system to your needs; and to ensure that all the components of your system are working together, optimally. | + | {{: |
- | All this can be done either with the CCGX in front of you - or from anywhere in the world using an internet connection on the [[https://vrm.victronenergy.com|VRM Website]] | + | The Color Control GX (CCGX) sits at the heart of your energy installation. All the other system-components - such as inverter/chargers, solar chargers, and batteries - are connected to it. The CCGX ensures that they all work in harmony. |
- | All the information | + | Monitoring can be done either with the CCGX in front of you - or from anywhere |
+ | The CCGX also provides Remote firmware updates and even allows the settings to be Changed Remotely. | ||
+ | The Color Control GX is part of the [[https:// | ||
+ | All the information in this manual refers to the latest software. Your device will update itself to the latest version automatically. Check our blog posts to see that your device has the latest firmware: | ||
===== 1. Installation ===== | ===== 1. Installation ===== | ||
==== 1.1 Overview of connections ==== | ==== 1.1 Overview of connections ==== | ||
- | + | {{ :ccgx:overview_ccgx_feb2019.png?nolink&800 |}} | |
- | {{ :ccgx:ccgx_schematic_diagram.png?direct&700 |}} | + | |
==== 1.2 Snap-on ferrite beads for class B EMI compliance ==== | ==== 1.2 Snap-on ferrite beads for class B EMI compliance ==== | ||
Line 101: | Line 105: | ||
- VE.Direct cables with an angled connector on one end. These are designed to minimize the required depth behind a panel, ASS030531xxx | - VE.Direct cables with an angled connector on one end. These are designed to minimize the required depth behind a panel, ASS030531xxx | ||
- | VE.Direct cables have a maximum length of 10 metres. It is not possible to extend them. If longer lengths are required, use the [[https:// | + | VE.Direct cables have a maximum length of 10 metres. It is not possible to extend them. If longer lengths are required, use the [[https:// |
__Connecting more than two devices to your CCGX using VE.Direct__ | __Connecting more than two devices to your CCGX using VE.Direct__ | ||
Line 163: | Line 167: | ||
Alternatively, | Alternatively, | ||
- | ==== 1.5 Measuring | + | ==== 1.5 Monitoring |
Measuring the output of a PV Inverter will provide the user with an overview of both actual power balance and the energy distribution. Note that these measurements are only used to display information. They are not needed, nor used, by the installation for its performance. | Measuring the output of a PV Inverter will provide the user with an overview of both actual power balance and the energy distribution. Note that these measurements are only used to display information. They are not needed, nor used, by the installation for its performance. | ||
There are several ways to get the system to show the output of a PV Inverter: | There are several ways to get the system to show the output of a PV Inverter: | ||
- [[https:// | - [[https:// | ||
- | - [[http:// | + | - [[http:// |
- | - [[https:// | + | - [[https:// |
+ | - [[https:// | ||
- Using a [[https:// | - Using a [[https:// | ||
- By using [[https:// | - By using [[https:// |
