ccgx:pump_start_stop
ccgx:pump_start_stop [2016-08-08 15:38] – Page moved from drafts:pump_start_stop to ccgx:pump_start_stop mvaderccgx:pump_start_stop [2019-01-22 10:42] (current) – external edit 127.0.0.1
Line 4: Line 4:
 ===== Introduction ===== ===== Introduction =====
-The CCGX internal relay can be used to start a pump. +The CCGX has a relay - switch - which can automatically start a pump. The switch is triggered by 'tank level' data, received from a tank-sender. The level at which the switch is automatically tripped is user-definable.
-With this functionality you can open or close the relay based on a tank level.+==== Boat & Motorhome overview ====
-==== Mobile/automotive overview ====+An additional Overview page is available which shows at-a-glance status information from all tanks connected to the CCGX. To enable the tank overview page from the main menu go to: Settings -> Display and language -> Show boat and motorhome overview. You will now find that 'Mobile' has been added to CCGX 'homepage showing: 'Overview' and 'Tiles'
-On this overview you can easily see all the attached tank sensors levels and control a pump. It is also posible to change Multi/Quattro AC current limit and mode when available.+It is also posible to change Multi/Quattro AC current limit and mode when those functions are available.
 {{:drafts:mobileoverview.png?direct|}} {{:drafts:mobileoverview.png?direct|}}
 ==== Enable pump start/stop ==== ==== Enable pump start/stop ====
-To enable the pump start/stop functionality go to Settings-> Relay and set the function to "Tank pump", once enabled the tank pump configuration page will be available.+To enable the pump start/stop functionality go to Settings ->Relayand set the function to "Tank pump"
 {{:drafts:pumpstartstop-relay.png?direct|}} {{:drafts:pumpstartstop-relay.png?direct|}}
 ==== Configuration ==== ==== Configuration ====
-Pump start/stop configuration page is located in Settings -> Tank pump.+Once enabled the tank pump configuration page will be found at: Main Menu ->Settings ->Tank pump.
 {{:drafts:pumpstartstop-config.png?direct|}} {{:drafts:pumpstartstop-config.png?direct|}}
-{{:drafts:pumpstartstop-modes.png?direct|}}
-{{:drafts:pumpstartstop-list.png?direct|}}
-**Mode:**+==== Mode ====
   * **Auto:** Start and stop the pump based on level settings   * **Auto:** Start and stop the pump based on level settings
   * **On:** Pump always on   * **On:** Pump always on
   * **Off:** Pump always off   * **Off:** Pump always off
-**Tank sensor**:+
 +{{:drafts:pumpstartstop-modes.png?direct|}}
 +==== Tank sensor ====
 Select which sensor will be monitored to start/stop the pump when the "Auto" mode is enabled.  Select which sensor will be monitored to start/stop the pump when the "Auto" mode is enabled.
 +{{:drafts:pumpstartstop-list.png?direct|}}
 +==== Pump auto-start levels ====
 **Start level:** When the tank level reaches this value the pump will be started. **Start level:** When the tank level reaches this value the pump will be started.
ccgx/pump_start_stop.1470663499.txt.gz · Last modified: 2016-08-08 15:38 by mvader
