ccgx:modbustcp_faq
ccgx:modbustcp_faq [2020-05-29 14:48] – [1. Introduction] bwillacker | ccgx:modbustcp_faq [2021-01-13 14:06] – [1. Introduction] guystewart | ||
Line 2: | Line 2: | ||
- | Modbus-TCP is a feature on our [[venus-os: | + | Modbus-TCP is a feature on all our [[venus-os: |
Modbus-TCP is an industry standard protocol, that can be used to interface PLCs or other third party equipment with Victron products. Through the Modbus-TCP interface you can read and write data to the chargers, battery monitors, inverter/ | Modbus-TCP is an industry standard protocol, that can be used to interface PLCs or other third party equipment with Victron products. Through the Modbus-TCP interface you can read and write data to the chargers, battery monitors, inverter/ | ||
Line 103: | Line 103: | ||
==== 7. Support ==== | ==== 7. Support ==== | ||
- | The recommended method for report | + | The recommended method for support |
Direct company support is only offered on a limited basis. For such support, contact our Victron representative. | Direct company support is only offered on a limited basis. For such support, contact our Victron representative. |
