ccgx:generator_start_stop
ccgx:generator_start_stop [2019-03-17 19:51] – [6. Conditions: User-definable parameters which trigger a generator auto-start.] mvader | ccgx:generator_start_stop [2019-08-15 12:38] – replace venus-device with GX device guy_stewart | ||
- | ====== Generator auto start/ | + | ====== |
- | An internal relay on a [[venus-os: | + | An internal relay on a [[venus-os: |
This is one of the available options to automatically start and stop a generator. See the [[auto-generator-start-stop: | This is one of the available options to automatically start and stop a generator. See the [[auto-generator-start-stop: | ||
Line 62: | Line 62: | ||
* **Minimum run time**: It's good practice for a generator, once started, to be allowed to reach its operating temperature. When started manually this setting is ignored. | * **Minimum run time**: It's good practice for a generator, once started, to be allowed to reach its operating temperature. When started manually this setting is ignored. | ||
- | * **Detect generator at AC input**: Enabling this feature will sound an alarm whenever power is //not// detected at the AC input terminal of the Inverter/ | + | * **Detect generator at AC input**: Enabling this feature will raise an alarm on the GX device, as well as trigger an alarm email from the VRM portal(1), |
* **Quiet hours**: See [[#Quiet hours|Quiet hours]] | * **Quiet hours**: See [[#Quiet hours|Quiet hours]] |
ccgx/generator_start_stop.txt · Last modified: 2021-02-05 08:58 by mvader
