ccgx:generator_start_stop
ccgx:generator_start_stop [2019-01-28 12:58] – [6. Troubleshooting] mvader | ccgx:generator_start_stop [2019-03-17 19:51] – [6. Conditions: User-definable parameters which trigger a generator auto-start.] mvader | ||
Line 184: | Line 184: | ||
=== Manual-Start Feature === | === Manual-Start Feature === | ||
- | Use the //Manual start// feature to remotely start the generator. You can also implement this feature | + | Use the //Manual start// feature to remotely start the generator. You can also press Start when the generator is already running - doing so will ensure that the generator won't automatically stop when the condition which caused it to start has been satisfied. In other words, the //Manual start// feature will override the auto-stop parameters. |
There are two ways to start the generator manually: | There are two ways to start the generator manually: |
ccgx/generator_start_stop.txt · Last modified: 2021-02-05 08:58 by mvader
