ccgx:fischer_panda
ccgx:fischer_panda [2018-03-20 13:28] – [Maintenance] justin_tyers_live_a_c | ccgx:fischer_panda [2020-09-07 12:29] (current) – [Maintenance] mvader | ||
- | Beginning with [[https:// | + | Fischer Panda generator can be connected to a GX Device, which makes it possible to monitor & operate the generator |
+ | The generator needs to be connected to the VE.Can port of the GX Device, which requires a Fischer Panda SAE J1939 module. | ||
===== Requirements ===== | ===== Requirements ===== | ||
- | * CCGX or Venus GX | + | * [[venus-os: |
* Fischer Panda generator, xControl or iGenerator | * Fischer Panda generator, xControl or iGenerator | ||
* Fischer Panda SAE J1939 CAN module (part number 0006107) | * Fischer Panda SAE J1939 CAN module (part number 0006107) | ||
Line 27: | Line 29: | ||
- | ===== Menu ===== | + | **:!: Important: Operation of the generator is only possible and allowed when the xControl or the iControl panel is switched on. ** |
+ | ===== GX Device | ||
+ | In Settings -> Services, the selected canbus profile must be one that says NMEA2000. (The default). | ||
When all wiring is complete and the setup has been correctly carried-out, | When all wiring is complete and the setup has been correctly carried-out, | ||
Line 42: | Line 48: | ||
===== Generator start/stop ===== | ===== Generator start/stop ===== | ||
- | In addition to the manual start/stop and monitoring, there is also an automatic start/stop feature. This has the same comprehensive range of options as the Generator start/stop feature associated with the CCGX relay. | + | In addition to the manual start/stop and monitoring, there is also an automatic start/stop feature. This has the same comprehensive range of options as the Generator start/stop feature associated with the GX relay. |
See [[ccgx: | See [[ccgx: | ||
Line 48: | Line 54: | ||
===== Maintenance ===== | ===== Maintenance ===== | ||
- | Whenever performing maintenance on the generator, be sure to //stop// the generator from the Fischer Panda control panel. This will disable the Fischer Panda autostart feature, and ensure | + | Whenever performing maintenance on the generator, be sure to //stop// the generator from the Fischer Panda control panel. This will disable the Fischer Panda autostart feature, and ensures |
When the maintenance is completed, make sure you enable the autostart feature again. You can do this on the Fischer Panda control panel in the menu '' | When the maintenance is completed, make sure you enable the autostart feature again. You can do this on the Fischer Panda control panel in the menu '' | ||
+ | ===== MFD App ==== | ||
+ | The Marine MFD HTML5 app (more information [[https:// | ||
===== Troubleshooting ===== | ===== Troubleshooting ===== | ||
=== I've set the mode of the genset to ' | === I've set the mode of the genset to ' | ||
- | Make sure the Fischer Panda autostart feature is on, this allows the CCGX control the remote on/off of the genset. You can find this option on the control panel in the menu '' | + | Make sure the Fischer Panda autostart feature is on, this allows the GX control the remote on/off of the genset. You can find this option on the control panel in the menu '' |
If you're manually trying to start the genset, a toast message appears with the text '' | If you're manually trying to start the genset, a toast message appears with the text '' | ||
Line 63: | Line 74: | ||
- | ===== Disqus ===== | + | |
ccgx/fischer_panda.1521548908.txt.gz · Last modified: 2018-03-20 13:28 by justin_tyers_live_a_c
