ccgx:firmware_updating
ccgx:firmware_updating [2019-04-29 13:54] mvaderccgx:firmware_updating [2022-06-28 10:38] (current) marmour
 ====== How to update a GX device ====== ====== How to update a GX device ======
-These instructions apply to all [[venus-os:start|GX Devices]]: +These instructions have been moved to the manuals:
-  * Color Control GX (CCGX) +
-  * Venus GX (VGX) +
-  * Octo GX (OGX) +
-  * CANvu GX (CGX)+
-===== 1Changelog =====+[[https://www.victronenergy.com/media/pg/CCGX/en/firmware-updates.html|CCGX]]
-The change log is available in [[http://professional.victronenergy.com/|Victron Professional]].+[[https://www.victronenergy.com/media/pg/Venus_GX/en/firmware-updates.html|Venus GX]]
-===== 2Using the right procedure (CCGX only) =====+[[https://www.victronenergy.com/media/pg/Cerbo_GX/en/firmware-updates.html|Cerbo GX]]
-Depending on the installed firmware version, the update procedure differs.
-Running firmware version v1.74 or earlier? An upgrade is needed. Follow [[ccgx:firmware_upgrade_to_v2|the upgrade procedure to v2]].
-Otherwise follow instructions below.
-===== 3. Via internet or with microSD-card/USB-stick =====
-There are two ways to update the firmware:
-  - Update it via the internet, either manually or let it check for new updates every day
-  - Update it from a microSD-card or USB-stick
-===== 3.1 Direct download from the internet =====
-To update from the internet, navigate to:
-**Settings-> Firmware->Online updates.**
-{{:ccgx:ccgx_fwupdate_fwpage.png?direct|}}
-{{:ccgx:ccgx_fwupdate_online.png?direct|}}
-===== 3.2 MicroSD-card or USB-stick =====
-Updating with a microSD-card or USB-stick is called 'Offline updating'. Use it when updating a device that is not connected to the internet.
-==== Step 1. Download ====
-Get the latest swu file:
-  * CCGX: [[https://updates.victronenergy.com/feeds/venus/release/images/ccgx/venus-swu-ccgx.swu|venus-swu.ccgx.swu]]
-  * Venus GX: [[https://updates.victronenergy.com/feeds/venus/release/images/beaglebone/venus-swu-beaglebone.swu|venus-swu-beaglebone.swu]]
-==== Step 2. Install on an sdcard or usb stick ====
-Store the file in the root folder of a USB-stick or microSD-card.
-==== Step 3. Insert the device ====
-Note that you will see a warning "Not using media for storing logs". That warning can safely be ignored.
-{{:ccgx:ccgx_fwupdate_containsfirmware_toast.png?direct|}}
-==== Step 4. Initiate the update ====
-  * Navigate to **Settings -> Firmware -> Offline updates.**
-  * Press Check for updates
-  * If the firmware in the microSD-card or USB-stick is newer than the running one, "Update available" item will appear, press it to start the update process.
-{{:ccgx:ccgx_fwupdate_offline.png?direct|}}
-===== DISQUS =====
-~~DISQUS~~
ccgx/firmware_updating.1556538846.txt.gz · Last modified: 2019-04-29 13:54 by mvader
