ccgx:firmware_updating
ccgx:firmware_updating [2020-03-14 22:57] – [3.1 Direct download from the internet] mvader | ccgx:firmware_updating [2022-06-28 10:38] (current) – marmour | ||
====== How to update a GX device ====== | ====== How to update a GX device ====== | ||
- | These instructions | + | These instructions |
- | ===== 1. Changelog ===== | + | |
- | The change log is available in [[http://professional.victronenergy.com/ | + | [[https://www.victronenergy.com/ |
- | ===== 2. Using the right procedure (CCGX only) ===== | + | [[https:// |
- | Depending on the installed | + | [[https:// |
- | Running firmware version v1.74 or earlier? An upgrade is needed. Follow [[ccgx: | ||
- | Otherwise follow instructions below. | ||
- | ===== 3. Via internet or with microSD-card/ | ||
- | There are two ways to update the firmware: | ||
- | - Update it via the internet, either manually or let it check for new updates every day | ||
- | - Update it from a microSD-card or USB-stick | ||
- | ===== 3.1 Direct download from the internet ===== | ||
- | To update from the internet, navigate to: **Settings-> | ||
- | On GX devices without a display (ie. a Venus GX or Cerbo GX without GX Touch), use [[https:// | ||
- | ===== 3.2 MicroSD-card or USB-stick ===== | ||
- | Updating with a microSD-card or USB-stick is called ' | ||
- | ==== Step 1. Download ==== | ||
- | Get the latest swu file: | ||
- | * Color Control GX: [[https:// | ||
- | * Venus GX & Octo GX: [[https:// | ||
- | * GX Card in the MultiPlus-II or EasySolar GX: [[https:// | ||
- | * CANvu GX: [[https:// | ||
- | Note that the same files, and the change log, is available on [[https:// | ||
- | ==== Step 2. Install on an sdcard or usb stick ==== | ||
- | Store the file in the root folder of a USB-stick or microSD-card. | ||
- | ==== Step 3. Insert the device ==== | ||
- | Note that you will see a warning "Not using media for storing logs". That warning can safely be ignored. | ||
- | ==== Step 4. Initiate the update ==== | ||
- | * Navigate to **Settings -> Firmware -> Offline updates.** | ||
- | * Press Check for updates | ||
- | * If the firmware in the microSD-card or USB-stick is newer than the running one, " | ||
- | ~~DISQUS~~ | ||
ccgx/firmware_updating.txt · Last modified: 2022-06-28 10:38 by marmour
