ccgx:firmware_updating
ccgx:firmware_updating [2019-04-29 12:31] – [How to update a GX device] mvader | ccgx:firmware_updating [2019-07-23 22:13] – [Step 1. Download] mvader | ||
====== How to update a GX device ====== | ====== How to update a GX device ====== | ||
- | These instructions apply to all [[venus-os: | + | These instructions apply to all [[venus-os: |
- | * Color Control GX (CCGX) | + | ===== 1. Changelog ===== |
- | * Venus GX (VGX) | + | |
- | * Octo GX (OGX) | + | |
- | * CANvu GX (CGX) | + | |
- | ===== 1. Using the right procedure (CCGX only) ===== | + | The change log is available in [[http:// |
+ | ===== 2. Using the right procedure (CCGX only) ===== | ||
Depending on the installed firmware version, the update procedure differs. | Depending on the installed firmware version, the update procedure differs. | ||
Line 15: | Line 14: | ||
Otherwise follow instructions below. | Otherwise follow instructions below. | ||
- | ===== 2. Via internet or with microSD-card/ | + | ===== 3. Via internet or with microSD-card/ |
There are two ways to update the firmware: | There are two ways to update the firmware: | ||
Line 22: | Line 21: | ||
- | ===== 2.1 Direct download from the internet ===== | + | ===== 3.1 Direct download from the internet ===== |
To update from the internet, navigate to: | To update from the internet, navigate to: | ||
Line 29: | Line 28: | ||
- | ===== 2.2 MicroSD-card or USB-stick ===== | + | ===== 3.2 MicroSD-card or USB-stick ===== |
Updating with a microSD-card or USB-stick is called ' | Updating with a microSD-card or USB-stick is called ' | ||
Line 39: | Line 38: | ||
Get the latest swu file: | Get the latest swu file: | ||
- | * CCGX: [[https:// | + | * Color Control GX: [[https:// |
- | * Venus GX: [[https:// | + | * Venus GX & Octo GX: [[https:// |
+ | * GX Card in the MultiPlus-II or EasySolar GX: [[https:// | ||
+ | * CANvu GX: [[https:// | ||
+ | Note that the same files, and the change log, is available on [[https:// | ||
==== Step 2. Install on an sdcard or usb stick ==== | ==== Step 2. Install on an sdcard or usb stick ==== | ||
ccgx/firmware_updating.txt · Last modified: 2022-06-28 10:38 by marmour
