ccgx:firmware_updating
ccgx:firmware_updating [2017-08-27 10:01] – [2. Update procedure when v2.08 or later is already installed] careka | ccgx:firmware_updating [2022-06-28 10:38] (current) – marmour | ||
- | ===== 1. Using the right procedure (CCGX only) ===== | + | These instructions have been moved to the manuals: |
- | Depending on the installed | + | [[https:// |
- | Running firmware version v1.74 or earlier? An upgrade is needed. Follow | + | [[https:// |
- | When the device already has software version v2.00 or later, follow instructions below. | + | [[https:// |
- | ===== 2. Update procedure when v2.00 or later is already installed ===== | ||
- | There are two ways to update the firmware: | ||
- | - Update it via the internet, either manually or let it check for new updates every day | ||
- | - Update it from an microSD-card or USB-stick | ||
- | ===== 2.1 Direct download from the internet ===== | ||
- | To update from the internet, navigate to: | ||
- | **Settings-> | ||
- | ===== 2.2 microSD-card or USB-stick ===== | ||
- | Updating with a microSD-card or USB-stick is called ' | ||
- | ==== Step 1. Download ==== | ||
- | Get the latest swu file: | ||
- | * CCGX: [[https:// | ||
- | * Venus GX: [[https:// | ||
- | ==== Step 2. Install on an sdcard or usb stick ==== | ||
- | Store the file in the root folder of a USB stick or microSD card. | ||
- | ==== Step 3. Insert the device ==== | ||
- | Note that you will see a warning "Not using media for storing logs". That warning can safely be ignored. | ||
- | ==== Step 4. Initiate the update ==== | ||
- | * Navigate to **Settings -> Firmware -> Offline updates.** | ||
- | * Press Check for updates | ||
- | * If the firmware in the microSD card or USB stick is newer than the running one " | ||
- | ~~DISQUS~~ | ||
ccgx/firmware_updating.txt · Last modified: 2022-06-28 10:38 by marmour
