ccgx:ccgx_ve_power_setup
ccgx:ccgx_ve_power_setup [2019-01-22 10:16] – external edit 127.0.0.1 | ccgx:ccgx_ve_power_setup [2019-08-15 12:03] – replace Venus-device with GX device guy_stewart | ||
Line 6: | Line 6: | ||
There are two more procedures that can be done with VE Power Setup, but those have each been replaced with better newer functions: | There are two more procedures that can be done with VE Power Setup, but those have each been replaced with better newer functions: | ||
- | - (deprecated) Remotely updating firmware of a VE.Can product (requires an internet connected [[venus-os: | + | - (deprecated) Remotely updating firmware of a VE.Can product (requires an internet connected [[venus-os: |
- | - (deprecated) Remotely changing the configuration of VE.Bus system: Remote VEConfigure (requires an internet connected [[venus-os: | + | - (deprecated) Remotely changing the configuration of VE.Bus system: Remote VEConfigure (requires an internet connected [[venus-os: |
To update the firmware of a VE.Can product, its typically most convenient to use the remote option. Since its then not necessary to obtain the CANUSB adapter. | To update the firmware of a VE.Can product, its typically most convenient to use the remote option. Since its then not necessary to obtain the CANUSB adapter. | ||
Line 108: | Line 108: | ||
==== 4.2 Remote VEConfigure: | ==== 4.2 Remote VEConfigure: | ||
- | === Problem in the communication link between your computer and the Remote [[venus-os: | + | === Problem in the communication link between your computer and the Remote [[venus-os: |
Check the [[ccgx: | Check the [[ccgx: | ||
=== Error, remote Color Control gave VEConfig error code 30: MK2 communication error === | === Error, remote Color Control gave VEConfig error code 30: MK2 communication error === | ||
- | Verify that both the firmware of the VE.Bus system and the [[venus-os: | + | Verify that both the firmware of the VE.Bus system and the [[venus-os: |
===== 5. Two-way communication ===== | ===== 5. Two-way communication ===== | ||
- | Two-way communication is the name of the technology used for the communication link between your computer and the [[venus-os: | + | Two-way communication is the name of the technology used for the communication link between your computer and the [[venus-os: |
==== 5.1 Configuration ==== | ==== 5.1 Configuration ==== | ||
- Use the latest version of the [[https:// | - Use the latest version of the [[https:// | ||
- Use the latest version of [[https:// | - Use the latest version of [[https:// | ||
- | - Check that the [[venus-os: | + | - Check that the [[venus-os: |
- | - Enable Two-way communication on the [[venus-os: | + | - Enable Two-way communication on the [[venus-os: |
- Make sure to have Full Control access on the installation: | - Make sure to have Full Control access on the installation: | ||
- CCGX must be connected to internet, and Two-way communication must show as up in the Device list on the VRM Portal. | - CCGX must be connected to internet, and Two-way communication must show as up in the Device list on the VRM Portal. | ||
- | This screenshot shows the Device list on the VRM Portal. See [[venus-os: | + | This screenshot shows the Device list on the VRM Portal. See [[venus-os: |
ccgx/ccgx_ve_power_setup.txt · Last modified: 2023-05-07 09:53 by mvader
