ccgx:ccgx_fronius
ccgx:ccgx_fronius [2019-09-18 10:16] – [2.2 Adding Fronius to the CCGX] iburger | ccgx:ccgx_fronius [2019-12-03 15:30] – [2.2 Adding Fronius to the CCGX] iburger | ||
Line 77: | Line 77: | ||
3. The CCGX will automatically scan for PV-inverters on the local network if no PV-inverters were found previously or if a previously-found PV-inverter cannot be contacted. This will happen if the IP address of the PV-inverter changes. To prevent automatic scanning, disable //Automatic scanning//. | 3. The CCGX will automatically scan for PV-inverters on the local network if no PV-inverters were found previously or if a previously-found PV-inverter cannot be contacted. This will happen if the IP address of the PV-inverter changes. To prevent automatic scanning, disable //Automatic scanning//. | ||
4. Once located, you will see the Inverters listed in the menu. The name used will be the serial number of the inverter - which you will also find on the inverter itself: \\ {{: | 4. Once located, you will see the Inverters listed in the menu. The name used will be the serial number of the inverter - which you will also find on the inverter itself: \\ {{: |
