ccgx:ccgx_fronius
ccgx:ccgx_fronius [2019-05-20 10:54] – iburger | ccgx:ccgx_fronius [2019-12-03 15:30] – [2.2 Adding Fronius to the CCGX] iburger | ||
Line 72: | Line 72: | ||
==== 2.2 Adding Fronius to the CCGX ==== | ==== 2.2 Adding Fronius to the CCGX ==== | ||
- | 1. In the CCGX, navigate to // | + | 1. In the CCGX, navigate to // |
2. Select //Scan// in the CCGX menu, and after completion go into the Inverters submenu to see the results. If scanning does not find the inverter, manually add the IP address of the Fronius Datamanager < | 2. Select //Scan// in the CCGX menu, and after completion go into the Inverters submenu to see the results. If scanning does not find the inverter, manually add the IP address of the Fronius Datamanager < | ||
- | 3. Once located, you will see the Inverters listed in the menu. The name used will be the serial number | + | 3. The CCGX will automatically scan for PV-inverters on the local network if no PV-inverters were found previously or if a previously-found PV-inverter cannot be contacted. This will happen if the IP address |
- | 4. Configure | + | * We recommend that automatic scanning is enabled (the default) in residential |
- | * Position: = the position relative to the Multi or Quattro [AC Input 1 / AC Input 2 / AC Output] | + | * In larger installations, |
- | * Phase: = the phase on which the PV Inverter installed. Disabled and set to Multi-phase for split- and three-phase PV Inverters | + | * Note that if DHCP is used to allocate dynamic addresses in your computer network, |
- | * Show: = show this device in the system or not. Use this feature when there are multiple, separate, energy systems on the same LAN. | + | |
- | 5. Done! | + | 4. Once located, you will see the Inverters listed in the menu. The name used will be the serial number of the inverter - which you will also find on the inverter itself: \\ {{: |
+ | 5. Configure the // | ||
+ | 7. Done! | ||
==== 2.3 Device scan details ==== | ==== 2.3 Device scan details ==== | ||
As mentioned above the CCGX should find all Fronius inverters automatically. It will scan all IP-addresses in the local network (that is, all IP-addresses within the netmask assigned to the CCGX) to check whether or not they are //Fronius datamanager// | As mentioned above the CCGX should find all Fronius inverters automatically. It will scan all IP-addresses in the local network (that is, all IP-addresses within the netmask assigned to the CCGX) to check whether or not they are //Fronius datamanager// | ||
Line 91: | Line 101: | ||
All data cards found will be entered in the ' | All data cards found will be entered in the ' | ||
- | If you changed | + | If you don't want an automatic scan to be performed, disable the //Automatic scanning// setting on the PV-inverters menu. |
===== 3. Monitoring CCGX ===== | ===== 3. Monitoring CCGX ===== | ||
Line 108: | Line 118: | ||
+ | ^ State ^ Meaning ^ | ||
===== 4. Monitoring on the VRM Portal ===== | ===== 4. Monitoring on the VRM Portal ===== |
