ccgx:ccgx_fronius
ccgx:ccgx_fronius [2019-01-20 19:49] – [2.1 Setup Local Area Network (LAN) Configuration] markus_pauritsch | ccgx:ccgx_fronius [2019-12-03 15:30] – [2.2 Adding Fronius to the CCGX] iburger | ||
====== CCGX & Fronius PV Inverters ====== | ====== CCGX & Fronius PV Inverters ====== | ||
- | By connecting a Fronius PV Inverter and [[https:// | + | By connecting a Fronius PV Inverter and [[https:// |
- See Fronius information on the CCGX. | - See Fronius information on the CCGX. | ||
- Monitor the Fronius on the VRM Portal. | - Monitor the Fronius on the VRM Portal. | ||
Line 24: | Line 24: | ||
Note that the [[http:// | Note that the [[http:// | ||
===== 2. Configuring ===== | ===== 2. Configuring ===== | ||
==== 2.1 Setup Local Area Network (LAN) Configuration==== | ==== 2.1 Setup Local Area Network (LAN) Configuration==== | ||
- | === 2.1.1 Setup using Manual Addressing or DHCP === | + | In order to establish a data communication between |
- | - Connect both, the Fronius and the CCGX, on the same LAN network and configure the IP address | + | |
- | - Configure the Fronius Datamanager, referring to its operating manual, for using an IP address on the same subnet, as described above. If you have the possibility | + | === 2.1.1 DHCP addressing method === |
- | - In the CCGX, navigate | + | If you have a DHCP server running |
- | - Select //Scan// in the CCGX menu, and after completion go into the Inverters submenu | + | |
- | - Once located, you will see the Inverters listed | + | === 2.1.2 Link-local addressing |
- | - Configure the // | + | When no DHCP server is present |
- | * Position: = the position relative to the Multi or Quattro [AC Input 1 / AC Input 2 / AC Output] | + | This could be the case, if you use a WiFi Network for the CCGX to gain access |
- | * Phase: = the phase on which the PV Inverter installed. Disabled and set to Multi-phase for split- and three-phase PV Inverters | + | |
- | * Show: = show this device in the system or not. Use this feature when there are multiple, separate, energy systems on the same LAN. | + | Note, that no direct |
- | - Done! | + | |
- | === 2.1.2 Setup using Link-local addressing === | + | This method can only be used to configure |
- | If you don't use a router or have some other DHCP Server service available | + | |
- | This could be the case when you use a WiFi Network for the CCGX to access the Internet and have a Fronius connected | + | |
- | Note, that no access to the internet will be possible for the Fronius in that configuration and therefore only communication to the CCGX is possible. | + | |
- | This method can only be used to configure | + | |
- Make sure the "IP Switch" | - Make sure the "IP Switch" | ||
- | - Connect both, the Fronius and the CCGX, on the same LAN network | + | - Connect both, the Fronius and the CCGX, on the same LAN network, either directly with a LAN cable or using a network switch. |
- | - The Fronius is now accessible and having a " | + | - The Fronius is now accessible and having a " |
+ | === 2.1.3 manual addressing method === | ||
+ | You will have to configure the IP address of the Fronius to be in the same subnet as the IP address of the CCGX. To do this, first have a look at the IP configuration your CCGX is using on that network. | ||
- | + | If the LAN IP address and Subnet Mask of the CCGX is not configured yet, you will have to set it first. | |
- | ==== 2.1 Device scan details ==== | + | |
+ | As an example, the IP address on the CCGX could be: 192.168.10.1 and the Subnet Mask: 255.255.255.0. | ||
+ | If you would like to connect the Fronius to be able to use the internet connection of your Local network, you have to set Gateway and DNS IP addresses on the Fronius as well. They should be exactly the same as in the Settings --> Ethernet of the CCGX. | ||
+ | ==== 2.2 Adding Fronius to the CCGX ==== | ||
+ | 1. In the CCGX, navigate to // | ||
+ | 2. Select //Scan// in the CCGX menu, and after completion go into the Inverters submenu to see the results. If scanning does not find the inverter, manually add the IP address of the Fronius Datamanager < | ||
+ | 3. The CCGX will automatically scan for PV-inverters on the local network if no PV-inverters were found previously or if a previously-found PV-inverter cannot be contacted. This will happen if the IP address of the PV-inverter changes. To prevent automatic scanning, disable //Automatic scanning// | ||
+ | 5. Configure the // | ||
+ | 7. Done! | ||
+ | ==== 2.3 Device scan details ==== | ||
As mentioned above the CCGX should find all Fronius inverters automatically. It will scan all IP-addresses in the local network (that is, all IP-addresses within the netmask assigned to the CCGX) to check whether or not they are //Fronius datamanager// | As mentioned above the CCGX should find all Fronius inverters automatically. It will scan all IP-addresses in the local network (that is, all IP-addresses within the netmask assigned to the CCGX) to check whether or not they are //Fronius datamanager// | ||
Line 57: | Line 101: | ||
All data cards found will be entered in the ' | All data cards found will be entered in the ' | ||
- | If you changed | + | If you don't want an automatic scan to be performed, disable the //Automatic scanning// setting on the PV-inverters menu. |
+ | ===== 3. Monitoring CCGX ===== | ||
- | ==== 3. Monitoring CCGX ==== | ||
When the Fronius is detected and configured on the CCGX all PV inverters will be visible in the devicelist. | When the Fronius is detected and configured on the CCGX all PV inverters will be visible in the devicelist. | ||
Line 74: | Line 119: | ||
+ | ^ State ^ Meaning ^ | ||
+ | ===== 4. Monitoring on the VRM Portal ===== | ||
- | ==== 4. Monitoring on the VRM Portal ==== | ||
To see the yield on the VRM site (in the // | To see the yield on the VRM site (in the // | ||
Line 82: | Line 137: | ||
