ccgx:ccgx_fronius
ccgx:ccgx_fronius [2018-03-20 13:07] – [4. Monitoring on the VRM Portal] justin_tyers_live_a_c | ccgx:ccgx_fronius [2020-03-19 15:30] (current) – guy_stewart | ||
====== CCGX & Fronius PV Inverters ====== | ====== CCGX & Fronius PV Inverters ====== | ||
- | By connecting a Fronius PV Inverter and [[https:// | + | This manual |
- | - See Fronius information on the CCGX. | + | |
- | - Monitor the Fronius on the VRM Portal. | + | |
- | - Enable the Fronius kWh reading so that it is used for the solar yield and also the consumption tab on VRM. | + | |
- | - Allow the Victron system to control the Fronius output power, Zero feed-in. See the [[ess: | + | |
- | This document describes how to setup the monitoring functions; and how to configure a Fronius PV inverter to work together with the Multi or Quattro, see [[ac_coupling: | + | |
- | ===== 1. Requirements ===== | + | |
- | ^ Model ^ Required accessory ^ | + | |
- | | Fronius Symo Light | Purchase and install the [[http:// | + | |
- | | Fronius Symo | No accessory needed, datamanager card installed from factory | | + | |
- | | Fronius Galvo | No accessory needed, datamanager card installed from factory | | + | |
- | | Fronius IG Plus (*) | Purchase and install the [[http:// | + | |
- | | Fronius Agilo | Purchase and install the [[http:// | + | |
- | (*) The Fronius Zero feed-in feature - which is part of an Energy Storage System [[ess: | + | |
- | All the new Fronius inverters - for example the upcoming Fronius Primo - will arrive fitted with a // | + | |
- | Both the Fronius and the CCGX need to be connected on the same LAN - either via Wi-Fi or Ethernet. | + | |
- | Note that the [[http:// | + | |
- | ===== 2. Configuring ===== | + | |
- | ==== 2.1 Setup ==== | + | |
- | - Connect both the Fronius and the CCGX on the same LAN network, in the same subnet. (If you don't know what a subnet is, don't worry - you'll probably be fine!) | + | |
- | - Configure the Fronius datamanager using its manual. (On DHCP networks, no configuration of the datamanager is required.) | + | |
- | - In the CCGX, navigate to // | + | |
- | - Select //Scan// in the CCGX menu, and after completion go into the Inverters submenu to see the results. If scanning does not find the inverter, manually add the IP address of the Fronius Datamanager from its card, or box. | + | |
- | - Once located, you will see the Inverters listed in the menu. The name used will be the serial number of the inverter - which you will also find on the inverter itself: \\ {{: | + | |
- | - Configure the // | + | |
- | * Position: = the position relative to the Multi or Quattro [AC Input 1 / AC Input 2 / AC Output] | + | |
- | * Phase: = the phase on which the PV Inverter installed. Disabled and set to Multi-phase for split- and three-phase PV Inverters | + | |
- | * Show: = show this device in the system or not. Use this feature when there are multiple, separate, energy systems on the same LAN. | + | |
- | - Done! | + | |
- | ==== 2.1 Device scan details ==== | + | |
- | As mentioned above the CCGX should find all Fronius inverters automatically. It will scan all IP-addresses in the local network (that is, all IP-addresses within the netmask assigned to the CCGX) to check whether or not they are //Fronius datamanager// | + | |
- | Usually a scan is completed within a minute - though if you have a large subnet it may take much more time. If you don't want to wait for completion, enter an IP-address manually. | + | |
- | All data cards found will be entered in the ' | + | |
- | If you changed to //TCP// port number on the data manager, you should change this setting on the CCGX, too (TCP port) - otherwise leave the setting at its default (80). | + | |
- | ==== 3. Monitoring CCGX ==== | + | |
- | When the Fronius is detected and configured on the CCGX all PV inverters will be visible in the devicelist. | + | |
- | To see the device details, navigate to the menu. | + | |
- | Here you can see the current state, current power generated, total power generated. | + | |
- | For more details on each device navigate to the Device menu. Here you will find: IP address, Product name, product ID, and Serial number, etc. | + | |
- | ==== 4. Monitoring on the VRM Portal ==== | + | |
- | To see the yield on the VRM site (in the // | + | |
