ccgx:ccgx_faq
ccgx:ccgx_faq [2020-05-12 15:50] – [Q15: What type of networking is used by the Color Control GX (TCP and UDP ports)?] mvader | ccgx:ccgx_faq [2020-05-27 17:54] – Q9 was outdated and no longer applies mvader | ||
Line 74: | Line 74: | ||
- | ==== Q9: When I type the ip-address of the Color Control into my browser, I see a web page mentioning Hiawatha? ==== | ||
- | Our plan is to at least run a website where you can change settings and see the current status. If all works out as we would like to, there might come be a fully functional version of the online VRM Portal running locally on the Color Control GX. This allows people without an internet connection, or an intermittent internet connection to have the same features and functionality. | ||
==== Q10: I have multiple Solar chargers MPPT 150/70 running in parallel. From which one will I see the relay status in the CCGX menu? ==== | ==== Q10: I have multiple Solar chargers MPPT 150/70 running in parallel. From which one will I see the relay status in the CCGX menu? ==== |
