ccgx:ccgx_faq
ccgx:ccgx_faq [2020-01-15 15:00] – [Q15: What type of networking is used by the Color Control GX (TCP and UDP ports)?] wiebe | ccgx:ccgx_faq [2020-01-21 16:18] – [Q15: What type of networking is used by the Color Control GX (TCP and UDP ports)?] wiebe | ||
Line 120: | Line 120: | ||
MQTT (default disabled): | MQTT (default disabled): | ||
- | * When enabled, a local MQTT broker is started, which accepts TCP connections on port 1883. The CCGX will also try to connect to the victron MQTT cloud server | + | * When enabled, a local MQTT broker is started, which accepts TCP connections on port 1883. The CCGX will also try to connect to a victron MQTT cloud server |
Remote Console on VRM (default disabled): | Remote Console on VRM (default disabled): |
