ccgx:ccgx_faq
ccgx:ccgx_faq [2019-08-15 12:34] – replace venus-device with GX device guy_stewart | ccgx:ccgx_faq [2020-02-04 14:58] – [Q15: What type of networking is used by the Color Control GX (TCP and UDP ports)?] wiebe | ||
Line 120: | Line 120: | ||
MQTT (default disabled): | MQTT (default disabled): | ||
- | * When enabled, a local MQTT broker is started, which accepts TCP connections on port 1883. The CCGX will also try to connect to the victron MQTT cloud server | + | * When enabled, a local MQTT broker is started, which accepts TCP connections on port 1883. The CCGX will also try to connect to a victron MQTT cloud server |
Remote Console on VRM (default disabled): | Remote Console on VRM (default disabled): | ||
- | * Remote Console on VRM uses the same reverse ssh tunnel as is used for Remote Support: outbound connection to supporthost.victronenergy.com on port 22, 80 or 443. No port forwarding in routers is necessary to use Remote Console on VRM. | + | * Remote Console on VRM uses the same reverse ssh tunnel as is used for Remote Support: outbound connection to supporthosts.victronenergy.com on port 22, 80 or 443. No port forwarding in routers is necessary to use Remote Console on VRM. Note that supporthosts.victronenergy.com resolves to multiple IP addresses: 84.22.108.49 and 84.22.107.120. |
* See [[vrm_portal: | * See [[vrm_portal: | ||
