ccgx:ccgx_faq
ccgx:ccgx_faq [2019-08-14 04:08] – [Q20: Issues with Multi not starting when CCGX is connected / Caution when powering the CCGX from the AC-out terminal of a VE.Bus Inverter, Multi or Quattro] simonhackett | ccgx:ccgx_faq [2020-01-15 15:00] – [Q15: What type of networking is used by the Color Control GX (TCP and UDP ports)?] wiebe | ||
Line 123: | Line 123: | ||
Remote Console on VRM (default disabled): | Remote Console on VRM (default disabled): | ||
- | * Remote Console on VRM uses the same reverse ssh tunnel as is used for Remote Support: outbound connection to supporthost.victronenergy.com on port 22, 80 or 443. No port forwarding in routers is necessary to use Remote Console on VRM. | + | * Remote Console on VRM uses the same reverse ssh tunnel as is used for Remote Support: outbound connection to supporthosts.victronenergy.com on port 22, 80 or 443. No port forwarding in routers is necessary to use Remote Console on VRM. Note that supporthosts.victronenergy.com resolves to multiple IP addresses: 84.22.108.49 and 84.22.107.120. |
* See [[vrm_portal: | * See [[vrm_portal: | ||
Line 184: | Line 184: | ||
Typic the following address into the web browser of a device connected to the same network. Using this address as a template: | Typic the following address into the web browser of a device connected to the same network. Using this address as a template: | ||
http:// | http:// | ||
- | The IP address can be found by going to Settings > Ethernet or Wifi. Once the page is loaded, Choose an image file from your device. Re-boot the [[venus-os: | + | The IP address can be found by going to Settings > Ethernet or Wifi. Once the page is loaded, Choose an image file from your device. Re-boot the [[venus-os: |
==== Q23: Multi restarts all the time (after every ~10sec) ==== | ==== Q23: Multi restarts all the time (after every ~10sec) ==== |
