ccgx:ccgx_faq
ccgx:ccgx_faq [2019-06-06 15:54] – [Q24: What is Error #42?] mvader | ccgx:ccgx_faq [2020-01-21 16:18] – [Q15: What type of networking is used by the Color Control GX (TCP and UDP ports)?] wiebe | ||
Line 120: | Line 120: | ||
MQTT (default disabled): | MQTT (default disabled): | ||
- | * When enabled, a local MQTT broker is started, which accepts TCP connections on port 1883. The CCGX will also try to connect to the victron MQTT cloud server | + | * When enabled, a local MQTT broker is started, which accepts TCP connections on port 1883. The CCGX will also try to connect to a victron MQTT cloud server |
Remote Console on VRM (default disabled): | Remote Console on VRM (default disabled): | ||
- | * Remote Console on VRM uses the same reverse ssh tunnel as is used for Remote Support: outbound connection to supporthost.victronenergy.com on port 22, 80 or 443. No port forwarding in routers is necessary to use Remote Console on VRM. | + | * Remote Console on VRM uses the same reverse ssh tunnel as is used for Remote Support: outbound connection to supporthosts.victronenergy.com on port 22, 80 or 443. No port forwarding in routers is necessary to use Remote Console on VRM. Note that supporthosts.victronenergy.com resolves to multiple IP addresses: 84.22.108.49 and 84.22.107.120. |
* See [[vrm_portal: | * See [[vrm_portal: | ||
Line 157: | Line 157: | ||
==== Q20: Issues with Multi not starting when CCGX is connected / Caution when powering the CCGX from the AC-out terminal of a VE.Bus Inverter, Multi or Quattro ==== | ==== Q20: Issues with Multi not starting when CCGX is connected / Caution when powering the CCGX from the AC-out terminal of a VE.Bus Inverter, Multi or Quattro ==== | ||
- | If you power the CCGX from an AC adaptor connected to the AC-out port of any VE.Bus product (Inverter, Multi or Quattro), then a deadlock | + | |
+ | Make sure that the GX device and MultiPlus is running the latest firmware version. | ||
+ | If you power the CCGX from an AC adaptor connected to the AC-out port of any VE.Bus product (Inverter, Multi or Quattro), then a deadlock | ||
This deadlock can be rectified by briefly unplugging the CCGX VE.Bus cable at which point you will observe the VE.Bus products will immediately begin to boot-up. | This deadlock can be rectified by briefly unplugging the CCGX VE.Bus cable at which point you will observe the VE.Bus products will immediately begin to boot-up. | ||
Line 166: | Line 169: | ||
Cutting/ | Cutting/ | ||
+ | Note that when using a Redflow ZBM2/ZCell battery, pin 7 should be cut even if the CCGX is DC powered, to avoid the same deadlock at times when the Redflow battery cluster is at 0% SoC. | ||
The // | The // | ||
==== Q21: I love Linux, programming, | ==== Q21: I love Linux, programming, | ||
Line 178: | Line 184: | ||
Typic the following address into the web browser of a device connected to the same network. Using this address as a template: | Typic the following address into the web browser of a device connected to the same network. Using this address as a template: | ||
http:// | http:// | ||
- | The IP address can be found by going to Settings > Ethernet or Wifi. Once the page is loaded, Choose an image file from your device. Re-boot the [[venus-os: | + | The IP address can be found by going to Settings > Ethernet or Wifi. Once the page is loaded, Choose an image file from your device. Re-boot the [[venus-os: |
==== Q23: Multi restarts all the time (after every ~10sec) ==== | ==== Q23: Multi restarts all the time (after every ~10sec) ==== | ||
Line 199: | Line 205: | ||
