ccgx:ccgx_faq
ccgx:ccgx_faq [2019-01-22 10:16] – external edit 127.0.0.1 | ccgx:ccgx_faq [2019-02-06 21:38] – [Q15: What type of networking is used by the Color Control GX (TCP and UDP ports)?] mvader | ||
Line 117: | Line 117: | ||
Two way communication (Remote VEConfig and Remote Firmware updates): | Two way communication (Remote VEConfig and Remote Firmware updates): | ||
- | * Uses HTTPS (port 443) to the Pubnub servers | + | |
+ | * v2.20 and later: connects to mqtt-rpc.victronenergy.com on port 443 | ||
MQTT (default disabled): | MQTT (default disabled): | ||
- | * When enabled, a MQTT broker is started, which accepts TCP connections on port 1883. The CCGX will also try to connect to the victron MQTT cloud server (mqtt.victronenergy.com) using SSL on port 8883. | + | * When enabled, a local MQTT broker is started, which accepts TCP connections on port 1883. The CCGX will also try to connect to the victron MQTT cloud server (mqtt.victronenergy.com) using SSL on port 8883. |
Remote Console on VRM (default disabled): | Remote Console on VRM (default disabled): |
