ccgx:ccgx_faq
ccgx:ccgx_faq [2019-01-21 10:58] – [DISQUS] ictbeheer | ccgx:ccgx_faq [2019-08-15 12:34] – replace venus-device with GX device guy_stewart | ||
Line 5: | Line 5: | ||
=== Step by step instructions when connected to VE.Bus port on the CCGX === | === Step by step instructions when connected to VE.Bus port on the CCGX === | ||
- | - Update the Color Control to the latest available version. See our blog posts in the [[https:// | + | - Update the Color Control to the latest available version. See our blog posts in the [[https:// |
- Do you have a Digital Multi Control or VE.Bus BMS in the system? In that case it is normal that on/off is disabled. See also the VE.Bus related notes in the [[: | - Do you have a Digital Multi Control or VE.Bus BMS in the system? In that case it is normal that on/off is disabled. See also the VE.Bus related notes in the [[: | ||
- In case you have had a Digital Multi Control or VE.Bus BMS connected to your system, the Color Control remembers it and even when those accessories have been removed the On/off switch will still be disabled. To clear the memory, execute a Redetect system, the option is in the Multi or Quattro section of the Color Control GX menu. | - In case you have had a Digital Multi Control or VE.Bus BMS connected to your system, the Color Control remembers it and even when those accessories have been removed the On/off switch will still be disabled. To clear the memory, execute a Redetect system, the option is in the Multi or Quattro section of the Color Control GX menu. | ||
Line 15: | Line 15: | ||
- In case you have had a Digital Multi Control or VE.Bus BMS connected to your system, and it is now no longer connected, the Canbus interface remembers it. Therefore, even after those accessories have been removed, the On/off switch will still be disabled. Clearing this memory is unfortunately not possible yourself, please contact us so we can help you. | - In case you have had a Digital Multi Control or VE.Bus BMS connected to your system, and it is now no longer connected, the Canbus interface remembers it. Therefore, even after those accessories have been removed, the On/off switch will still be disabled. Clearing this memory is unfortunately not possible yourself, please contact us so we can help you. | ||
==== Q2: Do I need a BMV to see proper battery state of charge? ===== | ==== Q2: Do I need a BMV to see proper battery state of charge? ===== | ||
Line 117: | Line 116: | ||
Two way communication (Remote VEConfig and Remote Firmware updates): | Two way communication (Remote VEConfig and Remote Firmware updates): | ||
- | * Uses HTTPS (port 443) to the Pubnub servers | + | |
+ | * v2.20 and later: connects to mqtt-rpc.victronenergy.com on port 443 | ||
MQTT (default disabled): | MQTT (default disabled): | ||
- | * When enabled, a MQTT broker is started, which accepts TCP connections on port 1883. The CCGX will also try to connect to the victron MQTT cloud server (mqtt.victronenergy.com) using SSL on port 8883. | + | * When enabled, a local MQTT broker is started, which accepts TCP connections on port 1883. The CCGX will also try to connect to the victron MQTT cloud server (mqtt.victronenergy.com) using SSL on port 8883. |
Remote Console on VRM (default disabled): | Remote Console on VRM (default disabled): | ||
Line 157: | Line 157: | ||
==== Q20: Issues with Multi not starting when CCGX is connected / Caution when powering the CCGX from the AC-out terminal of a VE.Bus Inverter, Multi or Quattro ==== | ==== Q20: Issues with Multi not starting when CCGX is connected / Caution when powering the CCGX from the AC-out terminal of a VE.Bus Inverter, Multi or Quattro ==== | ||
- | If you power the CCGX from an AC adaptor connected to the AC-out port of any VE.Bus product (Inverter, Multi or Quattro), then a deadlock | + | |
+ | Make sure that the GX device and MultiPlus is running the latest firmware version. | ||
+ | If you power the CCGX from an AC adaptor connected to the AC-out port of any VE.Bus product (Inverter, Multi or Quattro), then a deadlock | ||
This deadlock can be rectified by briefly unplugging the CCGX VE.Bus cable at which point you will observe the VE.Bus products will immediately begin to boot-up. | This deadlock can be rectified by briefly unplugging the CCGX VE.Bus cable at which point you will observe the VE.Bus products will immediately begin to boot-up. | ||
Line 166: | Line 169: | ||
Cutting/ | Cutting/ | ||
+ | Note that when using a Redflow ZBM2/ZCell battery, pin 7 should be cut even if the CCGX is DC powered, to avoid the same deadlock at times when the Redflow battery cluster is at 0% SoC. | ||
The // | The // | ||
==== Q21: I love Linux, programming, | ==== Q21: I love Linux, programming, | ||
Line 178: | Line 184: | ||
Typic the following address into the web browser of a device connected to the same network. Using this address as a template: | Typic the following address into the web browser of a device connected to the same network. Using this address as a template: | ||
http:// | http:// | ||
- | The IP address can be found by going to Settings > Ethernet or Wifi. Once the page is loaded, Choose an image file from your device. Re-boot the [[venus-os: | + | The IP address can be found by going to Settings > Ethernet or Wifi. Once the page is loaded, Choose an image file from your device. Re-boot the [[venus-os: |
==== Q23: Multi restarts all the time (after every ~10sec) ==== | ==== Q23: Multi restarts all the time (after every ~10sec) ==== | ||
Please check the remote switch connection on the Multi control PCB. There should be a wire bridge between the left and middle terminal. The CCGX switches a line which enables the power of the Multi control board. After 10 seconds this line is released and the Multi should take over from there. When the remote switch connection is not wired the Multi is unable to take over it's own supply. The CCGX will retry, the Multi will boot and after 10 seconds stop, and so on. | Please check the remote switch connection on the Multi control PCB. There should be a wire bridge between the left and middle terminal. The CCGX switches a line which enables the power of the Multi control board. After 10 seconds this line is released and the Multi should take over from there. When the remote switch connection is not wired the Multi is unable to take over it's own supply. The CCGX will retry, the Multi will boot and after 10 seconds stop, and so on. | ||
+ | ==== Q24: What is Error #42? ==== | ||
+ | If the GX Device shows an Error 42 - Hardware fault. In that case, the flash storage on the device is corrupt. As a result, settings will not be saved (rebooting resets back to default) and other problems will rise. | ||
+ | This error is not recoverable in the field or by repair departments. Contact your dealer for a replacement. | ||
+ | Firmware versions until v2.30 did not report the error. Since v2.30; its visible on the device itself (in the GUI) and on the VRM Portal. | ||
===== GPL Note ===== | ===== GPL Note ===== | ||
Line 189: | Line 203: | ||
+ | ~~DISQUS~~ |
