ccgx:ccgx_faq
ccgx:ccgx_faq [2017-05-24 23:43] – mvader | ccgx:ccgx_faq [2020-10-15 10:33] – [Q15: What type of networking is used by the Color Control GX (TCP and UDP ports)?] ictbeheer | ||
====== Color Control GX FAQ ===== | ====== Color Control GX FAQ ===== | ||
- | ===== I cannot switch my Multi/ | + | ==== Q1: I cannot switch my Multi/ |
To solve the problem, first find out how the system is connected, and then follow the right step by step instruction below. | To solve the problem, first find out how the system is connected, and then follow the right step by step instruction below. | ||
There are two ways to connect a Multi/ | There are two ways to connect a Multi/ | ||
=== Step by step instructions when connected to VE.Bus port on the CCGX === | === Step by step instructions when connected to VE.Bus port on the CCGX === | ||
- | - Update the Color Control to the latest available version. See our blog posts in the [[https:// | + | - Update the Color Control to the latest available version. See our blog posts in the [[https:// |
- Do you have a Digital Multi Control or VE.Bus BMS in the system? In that case it is normal that on/off is disabled. See also the VE.Bus related notes in the [[: | - Do you have a Digital Multi Control or VE.Bus BMS in the system? In that case it is normal that on/off is disabled. See also the VE.Bus related notes in the [[: | ||
- In case you have had a Digital Multi Control or VE.Bus BMS connected to your system, the Color Control remembers it and even when those accessories have been removed the On/off switch will still be disabled. To clear the memory, execute a Redetect system, the option is in the Multi or Quattro section of the Color Control GX menu. | - In case you have had a Digital Multi Control or VE.Bus BMS connected to your system, the Color Control remembers it and even when those accessories have been removed the On/off switch will still be disabled. To clear the memory, execute a Redetect system, the option is in the Multi or Quattro section of the Color Control GX menu. | ||
Line 15: | Line 15: | ||
- In case you have had a Digital Multi Control or VE.Bus BMS connected to your system, and it is now no longer connected, the Canbus interface remembers it. Therefore, even after those accessories have been removed, the On/off switch will still be disabled. Clearing this memory is unfortunately not possible yourself, please contact us so we can help you. | - In case you have had a Digital Multi Control or VE.Bus BMS connected to your system, and it is now no longer connected, the Canbus interface remembers it. Therefore, even after those accessories have been removed, the On/off switch will still be disabled. Clearing this memory is unfortunately not possible yourself, please contact us so we can help you. | ||
+ | ==== Q2: Do I need a BMV to see proper battery state of charge? ===== | ||
- | ===== Do I need a BMV to see proper battery state of charge, or not? ====== | + | Moved [[https://www.victronenergy.com/ |
- | That depends on the type of system. There are three products that can calculate State Of Charge (SOC). Note that the CCGX is not in the list, as it does not calculate SOC. Instead, it only retrieves it from the connected devices, to then display it to the user and on VRM. | + | |
- | The three products: | + | |
- | - Multi and Quattro inverter/chargers | + | |
- | - Batteries with built-in batt. monitor and a (mostly canbus-) link to the CCGX. | + | |
- | From simple to complex systems: | + | |
- | === Battery and Multi or Quattro (a typical backup system) === | + | |
- | No BMV is required: as the Multi or Quattro is the only product connected to the battery, it knows exactly about all charge- and discharge currents. | + | |
- | Configuration: | + | |
- | - In the CCGX, in Settings -> System setup, verify the selected Battery Monitor. It should be the Multi or Quattro. | + | |
- | === Same, but then adding MPPT Solar Chargers === | + | |
- | There is no BMV is required, as long as all MPPT Solar Chargers are Victron, and connected to the CCGX. | + | |
- | This is how it works: the CCGX will continuously read the actual charge current from all solar chargers, and send the total to the Multi (or Quattro). Which then uses that in its SOC calculations. | + | |
- | - In the same menu, verify that the 'Use solar charger current to improve VE.Bus SOC' is enabled. Note that this is not a setting, it just an indicator of an automatic process. | + | |
- | Note that this feature requires recent firmware versions in both the Multis or Quattros (402 minimum), and the CCGX (v2.06 minimum) | + | |
- | === An EasySolar with CCGX built-in === | + | |
- | See previous. | + | |
- | === Batteries with built-in batt. monitor === | + | |
- | In case the system includes a battery with built-in battery monitor and SOC calculation, | + | |
- | Note that the Battery Monitor setting in VEConfigure3 is irrelevant. For systems like this, changing this setting has no effect to the charge- or any other mechanisms in this type of system. | + | |
- | === Other system types === | + | |
- | When there are more chargers, or loads, connected to the battery than just the Multi or MPPT Solar Chargers, a BMV will be required. Examples are: | + | |
- | * Alternators | + | |
- | * DC-DC chargers | + | |
- | * Wind turbines | + | |
- | * Hydro turbines | + | |
- | - Configure all BMV parameters (see BMV documentation) | + | |
- | - In the CCGX, in Settings -> System setup, verify the selected Battery Monitor. It should be the BMV Battery Monitor. | + | |
- | === Notes === | + | |
- | * Do realize that all this is about showing an accurate state of charge to the user. Not about the system working well. A SOC is not necessary for accurate charging, except for example when a genset needs to be started and stopped automatically based on battery SOC. | + | |
- | * For hub-2 installations we recommend to __not__ add a BMV to the system. Since it will only confuse the user of the system as there are then two different SOCs being calculated and shown to the user. | + | |
- | More information: | + | ==== Q3: I have no internet, where can I insert a sim-card? ==== |
- | * [[vrm_portal: | + | |
- | * [[ccgx: | + | |
- | ===== I have no internet, where can I insert a sim-card? | + | |
There is no 3G modem in the Color Control, and therefore also no slot for a sim-card. Go to a local store and buy a 3G router with Ethernet ports. More information in the blog post link below and particularly in the comments section, as more users try differing equipment: | There is no 3G modem in the Color Control, and therefore also no slot for a sim-card. Go to a local store and buy a 3G router with Ethernet ports. More information in the blog post link below and particularly in the comments section, as more users try differing equipment: | ||
Line 101: | Line 27: | ||
Note that it is not possible to use a VGR2 or VER for this. Also it will not be possible in the foreseeable future. | Note that it is not possible to use a VGR2 or VER for this. Also it will not be possible in the foreseeable future. | ||
- | ===== Can I connect both a Color Control and a VGR2/VER to a Multi/ | + | ==== Q4: Can I connect both a Color Control and a VGR2/VER to a Multi/ |
No. Also, instead of this combination, | No. Also, instead of this combination, | ||
- | ===== Can I connect multiple Color Controls to a Multi/ | + | ==== Q5: Can I connect multiple Color Controls to a Multi/ |
No. | No. | ||
- | ===== I see incorrect current (amps) or power readings on my CCGX ===== | + | ==== Q6: I see incorrect current (amps) or power readings on my CCGX ==== |
Examples are: | Examples are: | ||
* I know that a load is drawing 40W from the Multi, but the CCGX shows 10W or even 0W. | * I know that a load is drawing 40W from the Multi, but the CCGX shows 10W or even 0W. | ||
Line 137: | Line 63: | ||
- VE.Bus is not a 100% plug and play system: if you disconnect the CCGX from one Multi, and very quickly connect it to another, it can result it wrong values. To make sure that this is not the case, use the ' | - VE.Bus is not a 100% plug and play system: if you disconnect the CCGX from one Multi, and very quickly connect it to another, it can result it wrong values. To make sure that this is not the case, use the ' | ||
- | ===== There is a menu entry named " | + | ==== Q7: There is a menu entry named " |
A VE.Bus system can be completely turned off, including its communication. If you turn a VE.Bus system off, and thereafter reset the CCGX, the CCGX cannot obtain the detailed product name and shows " | A VE.Bus system can be completely turned off, including its communication. If you turn a VE.Bus system off, and thereafter reset the CCGX, the CCGX cannot obtain the detailed product name and shows " | ||
To get the proper name again, go into the Multi menu on the CCGX and set the Switch menu entry to On or in case a Digital Multi Control is present, set the physical switch to On. Note that when there is a BMS, above procedure only works when within battery working voltages. | To get the proper name again, go into the Multi menu on the CCGX and set the Switch menu entry to On or in case a Digital Multi Control is present, set the physical switch to On. Note that when there is a BMS, above procedure only works when within battery working voltages. | ||
- | ===== There is a menu entry named " | + | ==== Q8: There is a menu entry named " |
If a CCGX ever saw a VE.Bus BMS or Digital Multi Control (DMC), it will remember them, until ' | If a CCGX ever saw a VE.Bus BMS or Digital Multi Control (DMC), it will remember them, until ' | ||
Line 148: | Line 74: | ||
- | ===== When I type the ip-address of the Color Control into my browser, I see a web page mentioning Hiawatha. Is there more? ===== | ||
- | Our plan is to at least run a website where you can change settings and see the current status. If all works out as we would like to, there might come be a fully functional version of the online VRM Portal running locally on the Color Control GX. This allows people without an internet connection, or an intermittent internet connection to have the same features and functionality. | ||
- | ===== I have multiple Solar chargers MPPT 150/70 running in parallel. From which one will I see the relay status in the CCGX menu? ===== | + | ==== Q10: I have multiple Solar chargers MPPT 150/70 running in parallel. From which one will I see the relay status in the CCGX menu? ==== |
From a random one. | From a random one. | ||
- | ===== How long should an automatic update take? ===== | + | ==== Q11: How long should an automatic update take? ==== |
- | The size of the download typically | + | The size of the download typically |
- | ===== I have a VGR with IO Extender, how can I replace this with a Color Control GX? ===== | + | ==== Q12: I have a VGR with IO Extender, how can I replace this with a Color Control GX? ==== |
It is not yet possible to replace the IO Extender functionality. | It is not yet possible to replace the IO Extender functionality. | ||
- | ===== Can I use Remote VEConfigure, | + | ==== Q13: Can I use Remote VEConfigure, |
Yes, see [[ccgx: | Yes, see [[ccgx: | ||
- | ===== The Blue Power Panel could be powered through the VE.Net network, can I also do that with a Color Control GX? ===== | + | ==== Q14: The Blue Power Panel could be powered through the VE.Net network, can I also do that with a Color Control GX? ==== |
No, a Color Control GX always needs to be powered itself. | No, a Color Control GX always needs to be powered itself. | ||
- | ===== What type of networking is used by the Color Control GX (TCP and UDP ports)? | + | ==== Q15: What type of networking is used by the Color Control GX (TCP and UDP ports)? ==== |
Basics: | Basics: | ||
Line 180: | Line 104: | ||
VRM Portal: | VRM Portal: | ||
- | * Data to the VRM Portal is sent via HTTP POST and GET requests to http:// | + | * Data to the VRM Portal is sent via HTTP POST and GET requests to https:// |
Firmware updates: | Firmware updates: | ||
- | * The CCGX connects to [[https:// | + | * The CCGX connects to [[https:// |
Remote support (default disabled): | Remote support (default disabled): | ||
- | * When enabled, an outbound SSH connection to supporthost.victronenergy.com is maintained. The CCGX will try to connect on port 22, 80 and 443, and the first that works is maintained. | + | * When enabled, an outbound SSH connection to supporthosts.victronenergy.com is maintained. The CCGX will try to connect on port 22, 80 and 443, and the first that works is maintained. |
- | * Enabling Remote Support also enables the sshd daemon, listening for incoming SSH requests on port 22. See next FAQ entry for more information about the Remote Support functionality. | + | * Enabling Remote Support also enables the sshd daemon, listening for incoming SSH requests on port 22. See below FAQ entry for more information about the Remote Support functionality. |
Two way communication (Remote VEConfig and Remote Firmware updates): | Two way communication (Remote VEConfig and Remote Firmware updates): | ||
- | * Uses HTTPS (port 443) to the Pubnub servers | + | |
+ | * v2.20 and later: connects to mqtt-rpc.victronenergy.com on port 443 | ||
MQTT (default disabled): | MQTT (default disabled): | ||
- | * When enabled, a MQTT broker is started, which accepts TCP connections on port 1883. The CCGX will also try to connect to the victron MQTT cloud server | + | * When enabled, a local MQTT broker is started, which accepts TCP connections on port 1883. The CCGX will also try to connect to a victron MQTT cloud server |
Remote Console on VRM (default disabled): | Remote Console on VRM (default disabled): | ||
- | * Remote Console on VRM uses the same reverse ssh tunnel as is used for Remote Support: outbound connection to supporthost.victronenergy.com on port 22, 80 or 443. No port forwarding in routers is necessary to use Remote Console on VRM. | + | * Remote Console on VRM uses the same reverse ssh tunnel as is used for Remote Support: outbound connection to supporthosts.victronenergy.com on port 22, 80 or 443. No port forwarding in routers is necessary to use Remote Console on VRM. Note that supporthosts.victronenergy.com resolves to multiple IP addresses: 84.22.108.49, |
- | * See [[vrm_portal:troubleshooting_ccgx_vrm_connectivity#trouble_shooting_remote_console_on_vrm|here]] to trouble shoot Remote Console on VRM. | + | * Remote console also relies on the data connection to the VRM portal using HTTPS (port 443), as describe above. |
+ | * For troubleshooting, | ||
Remote Console on LAN (default disabled): | Remote Console on LAN (default disabled): | ||
Line 206: | Line 132: | ||
- | ===== What is the functionality behind the menu item Remote support (SSH), in the Ethernet menu? ===== | + | ==== Q16: What is the functionality behind the menu item Remote support (SSH), in the Ethernet menu? ==== |
- | When enabled, the Color Control will open a SSH connection to our secure server, with a reverse tunnel back to the Color Control. Through this tunnel, Victron engineers can login to your Color Control GX and perform remote support. This works when the Color Control GX is installed on an internet connection. The connection will even work when installed behind | + | When enabled, the Color Control will open a SSH connection to our secure server, with a reverse tunnel back to the Color Control. Through this tunnel, Victron engineers can login to your Color Control GX and perform remote support. This works when the Color Control GX is installed on an internet connection. The connection will even work when installed behind |
- | ===== I don’t see support for VE.Net products in the list, is that still coming? | + | ==== Q17: I don’t see support for VE.Net products in the list, is that still coming? ==== |
No. | No. | ||
- | ===== What is the data usage of the Color Control GX? ===== | + | ==== Q18: What is the data usage of the Color Control GX? ==== |
Data usage depends heavily on amount of connected products, and behavior and usage of those products. The measurements below are an indication only, and taken from a system with one Color Control GX, one Multi, one BMV and one MPPT. Log interval set to 15 minutes. If you are on an expensive data-plan, do make some fail-safe. | Data usage depends heavily on amount of connected products, and behavior and usage of those products. The measurements below are an indication only, and taken from a system with one Color Control GX, one Multi, one BMV and one MPPT. Log interval set to 15 minutes. If you are on an expensive data-plan, do make some fail-safe. | ||
Line 226: | Line 152: | ||
Mentioned megabytes do not include the download of a Color Control firmware update. Firmware updates of 60MB are not uncommon. | Mentioned megabytes do not include the download of a Color Control firmware update. Firmware updates of 60MB are not uncommon. | ||
- | ===== How many AC Current Sensors can I connect in one VE.Bus system? ==== | + | ==== Q19: How many AC Current Sensors can I connect in one VE.Bus system? ==== |
The current maximum is 9 sensors (since CCGX v1.31). Note that each need to be configured separately with an assistant in the Multi or Quattro to which it is wired. | The current maximum is 9 sensors (since CCGX v1.31). Note that each need to be configured separately with an assistant in the Multi or Quattro to which it is wired. | ||
- | ===== I love Linux, programming, | + | ==== Q20: Issues with Multi not starting when CCGX is connected / Caution when powering the CCGX from the AC-out terminal of a VE.Bus Inverter, Multi or Quattro ==== |
+ | NOTES: | ||
+ | - We recommend to power a GX device from the battery. Not from the AC-out. In case you still power it from AC-out, carefully read this FAQ item. | ||
+ | - This FAQ item applies to Venus GX, CCGX, and all other GX Devices, but not the Cerbo GX. It has an improved design due to which its no longer recommended to cut pin 7 of the VE.Bus cable when powering the GX device on the AC-out port. | ||
+ | - Make sure that the GX device and MultiPlus is running the latest firmware version. | ||
+ | If you power the CCGX from an AC adaptor connected to the AC-out port of any VE.Bus product (Inverter, Multi or Quattro), then a deadlock can occur after the VE.Bus products are powered-down for any reason (after any operational fault or during a black start). The VE.Bus devices will not boot-up until the CCGX has power ...but the CCGX will not boot-up until //it// has power. | ||
+ | This deadlock can be rectified by briefly unplugging the CCGX VE.Bus cable at which point you will observe the VE.Bus products will immediately begin to boot-up. | ||
+ | This deadlock can be avoided in two ways: | ||
+ | * Power the CCGX from the battery; or | ||
+ | * Cut pin 7 in the VE.Bus cable connected to the CCGX | ||
+ | Cutting/ | ||
+ | Note that when using a Redflow ZBM2/ZCell battery, pin 7 should be cut even if the CCGX is DC powered, to avoid the same deadlock at times when the Redflow battery cluster is at 0% SoC. | ||
+ | The // | ||
+ | ==== Q21: I love Linux, programming, | ||
+ | Yes you can! We intend to release almost all code as open source, but we are not that far yet. What we can offer today is that many parts of the software are in script or other non-precompiled languages, such as Python and QML, and therefore available on your Color Control GX and easy to change. Root password and more information is available [[open_source: | ||
+ | ==== Q22: How do I change the logo ==== | ||
+ | Typic the following address into the web browser of a device connected to the same network. Using this address as a template: | ||
+ | http:// | ||
+ | The IP address can be found by going to Settings > Ethernet or Wifi. Once the page is loaded, Choose an image file from your device. Re-boot the [[venus-os: | ||
+ | ==== Q23: Multi restarts all the time (after every ~10sec) ==== | ||
+ | Please check the remote switch connection on the Multi control PCB. There should be a wire bridge between the left and middle terminal. The CCGX switches a line which enables the power of the Multi control board. After 10 seconds this line is released and the Multi should take over from there. When the remote switch connection is not wired the Multi is unable to take over it's own supply. The CCGX will retry, the Multi will boot and after 10 seconds stop, and so on. | ||
+ | ==== Q24: What is Error #42? ==== | ||
+ | If the GX Device shows an Error 42 - Hardware fault. In that case, the flash storage on the device is corrupt. As a result, settings will not be saved (rebooting resets back to default) and other problems will rise. | ||
+ | This error is not recoverable in the field or by repair departments. Contact your dealer for a replacement. | ||
- | Yes you can! We intend to release almost all code as open source, but we are not that far yet. What we can offer today is that many parts of the software are in script or other non-precompiled languages, such as Python | + | Firmware versions until v2.30 did not report the error. Since v2.30; its visible on the device itself (in the GUI) and on the VRM Portal. |
===== GPL Note ===== | ===== GPL Note ===== | ||
Line 237: | Line 204: | ||
The software included in this product contains copyrighted software that is licensed under the GPL. You may obtain the Corresponding Source code from us for a period of three years after our last shipment of this product. | The software included in this product contains copyrighted software that is licensed under the GPL. You may obtain the Corresponding Source code from us for a period of three years after our last shipment of this product. | ||
