ccgx:beta-testing
ccgx:beta-testing [2017-08-07 13:51] – [Venus OS - Beta testing] mvader | ccgx:beta-testing [2023-07-05 07:30] (current) – [How to join the program?] mvader | ||
====== Venus OS - Beta testing ====== | ====== Venus OS - Beta testing ====== | ||
- | Venus OS, Venus in short, is the software running on the Color Control GX and the Venus GX. Doing extensive field test in a wide variety of installation types and use cases is very valuable | + | Would you like to become a Beta tester? |
- | === What happens when I join the program? === | + | Venus OS - or //Venus// for short - is the operating software |
- | The development cycle works like this: we develop new features, improvements and bug fixes for all the various functions. These changes are first tested internally, | + | |
- | A cycle typically consists | + | ==== What happens when I join the program? ==== |
+ | The development | ||
- | When joining the test program, your device will run on these test versions. | + | A cycle typically consists of 10 or so test versions. After that, when all known bugs are fixed, we release the new version to the general public. |
- | === What not to do? === | + | When you join the test program, your device will run on these test versions. |
- | This is especially a note to dealers & installers: do not install | + | |
- | These versions are called | + | ==== What not to do? ==== |
+ | This is a note to dealers & installers: **Do not install | ||
- | === Where to post questions and possible issues? === | + | These versions are called //beta versions//, //test versions//, or //release-candidates// |
- | In case of any questions, please post them on disqus on this page, or send them to the dev-venus mailing list. Do not ask them on other disqus pages. | + | |
- | Make sure to mention which test version you are using. | + | Also, don't contact Victron dealers, installers, support, or sales managers or anyone else in case you see problems while running a beta version. The only channel for issues in such case is the relevant open Venus OS post on the Modifications section on Community. |
+ | ==== Where should I post possible bug reports? ==== | ||
+ | If you think you have found a bug, first of all install the latest official release again (a version without the ~ notation) | ||
- | === How to join the program? === | + | If the problem also exists with the official release; then contact normal support. |
- | Go to Settings -> Firmware -> Online updates -> Update to, and there select Release candidates | + | |
- | To receive | + | If the problem only exists in the beta version, then please post a message on the relevant Venus OS beta version thread on [[https:// |
- | === How can I see if I run beta firmware? === | + | And don't forget to mention which test version |
- | Beta versions are marked with a tilde followed by the test version | + | |
- | === Where are the change logs? === | + | ==== How to join the program? ==== |
- | Change logs of the official releases are on [[https://professional.victronenergy.com/|Victron Professional]]. | + | Go to Settings -> Firmware -> Online updates -> Update to, and there select |
+ | ==== How can I install the latest beta firmware? ==== | ||
- | Change logs of the test versions are emailed to the test group. And can also be found on the [[https://groups.google.com/ | + | To install beta firmware online follow |
- | === I have a problem, and want to go back, how? === | + | ...or alternatively, to install |
- | You can always go back to the previously installed | + | |
- | | + | https:// |
+ | Which directory to use depends on the GX Device you have: | ||
+ | * Venus GX: beaglebone | ||
+ | * Cerbo GX: einstein | ||
+ | * MultiPlus-II GX, or EasySolar-II GX: nanopi | ||
+ | ==== How do I know if the firmware I am running is a offical release? ==== | ||
+ | Official releases have a clean version number, ie v2.06, or v2.10. | ||
+ | Version with a tilde in their version number, are either internal test versions, or beta versions. | ||
+ | For example, v2.06~12 is test version number 12 of version v2.06. The next build will be v2.06~13, and so forth. When releasing the final version of v2.06, the tilde and test number are removed, and the firmware is officially released as v2.06. | ||
+ | ==== Where can I find the change logs? ==== | ||
+ | Change logs for beta versions are on the [[https:// | ||
+ | Change logs of the official releases are on [[https:// | ||
+ | ==== I have a problem, how can I return to the previous version? ==== | ||
+ | You can always return to the previously installed version: | ||
- Revert to the previous version: Settings -> Firmware -> Stored backup firmware. | - Revert to the previous version: Settings -> Firmware -> Stored backup firmware. | ||
- | In case that available | + | In case the backup firmware is //also// a test-version, and you wish to return |
+ | ==== How can I unsubscribe to the emails? ==== | ||
+ | Only be changing the parameter in the Victron equipment (ie. GX Device) that configures it to use beta software. See next chapter. | ||
+ | ==== How can I leave the beta testing program? ==== | ||
+ | On your GX Device, go to Settings -> Firmware -> Online updates -> Update to. | ||
+ | There, select //Latest release// | ||
+ | The other option, // | ||
- | === How can I unsubscribe to the emails? === | ||
- | By setting your systems to work on official software. As long as you are using release-candidate aka beta versions of our software, it is not possible to unsubscribe. Not even with the unsubscribe link at the bottom of the email. | ||
- | ~~DISQUS~~ | ||
ccgx/beta-testing.1502106671.txt.gz · Last modified: 2017-08-07 13:51 by mvader
