ccgx:beta-testing
| ccgx:beta-testing [2017-11-10 21:21] – mvader | ccgx:beta-testing [2024-10-21 07:57] (current) – [Where should I post possible bug reports?] mvader | ||
| Line 1: | Line 1: | ||
| ====== Venus OS - Beta testing ====== | ====== Venus OS - Beta testing ====== | ||
| - | Venus OS, Venus in short, is the software running on the Color Control GX and the Venus GX. Doing extensive field test in a wide variety of installation types and use cases is very valuable | + | Would you like to become a Beta tester? |
| - | === What happens when I join the program? === | + | Venus OS - or //Venus// for short - is the operating software |
| - | The development cycle works like this: we develop new features, improvements and bug fixes for all the various functions. These changes are first tested internally, | + | |
| - | A cycle typically consists | + | ==== What happens when I join the program? ==== |
| + | The development | ||
| - | When joining the test program, your device will run on these test versions. | + | A cycle typically consists of 10 or so test versions. After that, when all known bugs are fixed, we release the new version to the general public. |
| - | === What not to do? === | + | When you join the test program, your device will run on these test versions. |
| - | This is especially a note to dealers & installers: do not install | + | |
| - | These versions are called | + | ==== What not to do? ==== |
| + | This is a note to dealers & installers: **Do not install | ||
| - | === Where to post possible issues? === | + | These versions are called //beta versions//, //test versions//, or //release-candidates// |
| - | In case of a possible bug report, please reply to the emails containing the change logs, or send them to the [[https://groups.google.com/forum/#!forum/victron-dev-venus|dev-venus mailing list]]. Do not ask them on Disqus pages or any other regular support channel. | + | |
| - | Make sure to mention which test version you are using. | + | Also, don't contact Victron dealers, installers, support, or sales managers or anyone else in case you see problems while running a beta version. The only channel for issues in such case is the relevant open Venus OS post on the Modifications section on Community. |
| + | ==== Where should I post possible bug reports? ==== | ||
| + | If you think you have found a bug, first of all install the latest official release again (a version without the ~ notation) | ||
| - | === How to join the program? === | + | If the problem also exists with the official release; then contact normal support. |
| - | Go to Settings -> Firmware -> Online updates -> Update to, and there select Release candidates | + | |
| - | To receive | + | If the problem only exists |
| - | === How can I install the latest beta firmware? === | + | And don't forget to mention which test version you are using. |
| - | To do that online, see above. | + | ==== How to join the program? ==== |
| + | Go to Settings -> Firmware -> Online updates -> Update feed, and there select //Beta release//. | ||
| + | ==== How can I install the latest beta firmware? ==== | ||
| - | To install the version with a usb-stick or sd card, download | + | To install |
| - | http:// | + | ...or alternatively, |
| - | Venus GX images are in the beaglebone directory. | + | https:// |
| + | Which directory to use depends on the GX Device you have: | ||
| - | === How can I see if I run beta firmware? === | + | * Venus GX: beaglebone |
| - | Beta versions are marked with a tilde followed by the test version number. For example, v2.06~12 is test version number 12 of version v2.06. When releasing the final version of v2.06, the tilde and test number are removed, and all tested features are released as v2.06. | + | * Cerbo GX: einstein |
| + | * Cerbo-S GX: cerbosgx | ||
| + | * Ekrano GX: ekrano | ||
| + | * MultiPlus-II GX, or EasySolar-II GX: nanopi | ||
| - | === Where are the change logs? === | ||
| - | Change logs of the official releases are on [[https:// | ||
| - | Change logs of the test versions are emailed to the test group. And can also be found on the [[https:// | + | ==== How do I know if the firmware I am running is a offical release? ==== |
| - | === I have a problem, and want to go back, how? === | + | Official releases |
| - | You can always go back to the previously installed version: | + | |
| - | | + | Version with a tilde in their version number, are either internal test versions, or beta versions. |
| + | For example, v2.06~12 is test version number 12 of version v2.06. The next build will be v2.06~13, and so forth. When releasing the final version of v2.06, the tilde and test number are removed, and the firmware is officially released as v2.06. | ||
| + | ==== Where can I find the change logs? ==== | ||
| + | Change logs for beta versions are on the [[https:// | ||
| + | Change logs of the official releases are on [[https:// | ||
| + | ==== I have a problem, how can I return to the previous version? ==== | ||
| + | You can always return to the previously installed version: | ||
| - Revert to the previous version: Settings -> Firmware -> Stored backup firmware. | - Revert to the previous version: Settings -> Firmware -> Stored backup firmware. | ||
| - | In case that available | + | In case the backup firmware is //also// a test-version, and you wish to return |
| + | ==== How can I unsubscribe to the emails? ==== | ||
| + | Only be changing the parameter in the Victron equipment (ie. GX Device) that configures it to use beta software. See next chapter. | ||
| + | ==== How can I leave the beta testing program? ==== | ||
| + | On your GX Device, go to Settings -> Firmware -> Online updates -> Update to. | ||
| + | There, select //Latest release// | ||
| + | The other option, // | ||
| - | === How can I unsubscribe to the emails? === | ||
| - | By setting your systems to work on official software. As long as you are using release-candidate aka beta versions of our software, it is not possible to unsubscribe. Not even with the unsubscribe link at the bottom of the email. | ||
| - | ===== DISQUS ===== | ||
| - | ~~DISQUS~~ | ||
ccgx/beta-testing.1510348900.txt.gz · Last modified: by mvader
