ccgx:beta-testing
ccgx:beta-testing [2019-04-16 15:52] – [Where can I find the change logs?] mvader | ccgx:beta-testing [2023-07-05 07:30] (current) – [How to join the program?] mvader | ||
Would you like to become a Beta tester? | Would you like to become a Beta tester? | ||
- | Venus OS - or //Venus// for short - is the operating software for our //Color Control | + | Venus OS - or //Venus// for short - is the operating software for our range of GX monitoring products, such as the Cerbo GX. Extensive field testing over a wide variety of installation-types and user-cases is very valuable to us ...and we're very grateful to you for your interest in joining this program, and for your help. |
==== What happens when I join the program? ==== | ==== What happens when I join the program? ==== | ||
Line 15: | Line 15: | ||
This is a note to dealers & installers: **Do not install test versions on a customer' | This is a note to dealers & installers: **Do not install test versions on a customer' | ||
- | These versions are called //test versions//, or // | + | These versions are called |
- | ==== Where should I post possible | + | Also, don't contact Victron dealers, installers, support, or sales managers or anyone else in case you see problems while running a beta version. The only channel for issues in such case is the relevant open Venus OS post on the Modifications section on Community. |
+ | ==== Where should I post possible | ||
If you think you have found a bug, first of all install the latest official release again (a version without the ~ notation) to check that if that solves it. Sometimes you can go back by using the Backup firmware option. If that also contains a beta version, then you’ll need to install the official version by hand. Download the .swu file from https:// | If you think you have found a bug, first of all install the latest official release again (a version without the ~ notation) to check that if that solves it. Sometimes you can go back by using the Backup firmware option. If that also contains a beta version, then you’ll need to install the official version by hand. Download the .swu file from https:// | ||
If the problem also exists with the official release; then contact normal support. | If the problem also exists with the official release; then contact normal support. | ||
- | If the problem only exists in the beta version, then please | + | If the problem only exists in the beta version, then please |
And don't forget to mention which test version you are using. | And don't forget to mention which test version you are using. | ||
Line 28: | Line 29: | ||
==== How to join the program? ==== | ==== How to join the program? ==== | ||
Go to Settings -> Firmware -> Online updates -> Update to, and there select //Latest release candidate// | Go to Settings -> Firmware -> Online updates -> Update to, and there select //Latest release candidate// | ||
- | To receive the emails about the test versions, make sure you register the device on the VRM Portal, and change the setting so that you have admin rights on the product. | ||
==== How can I install the latest beta firmware? ==== | ==== How can I install the latest beta firmware? ==== | ||
Line 37: | Line 35: | ||
...or alternatively, | ...or alternatively, | ||
- | http:// | + | https:// |
- | You will find the Venus GX images in the directory titled: // | + | Which directory to use depends on the GX Device you have: |
+ | * Venus GX: beaglebone | ||
+ | * Cerbo GX: einstein | ||
+ | * MultiPlus-II GX, or EasySolar-II GX: nanopi | ||
- | ==== How do I know if the firmware I am running is a beta version? ==== | + | |
- | Beta versions are marked | + | ==== How do I know if the firmware I am running is a offical release? ==== |
+ | Official releases have a clean version number, ie v2.06, or v2.10. | ||
+ | Version | ||
+ | For example, v2.06~12 is test version number 12 of version v2.06. The next build will be v2.06~13, and so forth. When releasing the final version of v2.06, the tilde and test number are removed, and the firmware is officially | ||
==== Where can I find the change logs? ==== | ==== Where can I find the change logs? ==== | ||
- | Change logs for beta versions are on the [[https:// | + | Change logs for beta versions are on the [[https:// |
Change logs of the official releases are on [[https:// | Change logs of the official releases are on [[https:// | ||
Line 58: | Line 65: | ||
==== How can I unsubscribe to the emails? ==== | ==== How can I unsubscribe to the emails? ==== | ||
- | By un-joining | + | |
+ | Only be changing | ||
+ | ==== How can I leave the beta testing | ||
+ | On your GX Device, go to Settings -> Firmware -> Online updates -> Update to. | ||
+ | There, select //Latest release//. | ||
+ | The other option, | ||
ccgx/beta-testing.txt · Last modified: 2023-07-05 07:30 by mvader
