ccgx:beta-testing
ccgx:beta-testing [2019-01-22 10:42] – external edit 127.0.0.1 | ccgx:beta-testing [2019-04-16 15:52] – [Where can I find the change logs?] mvader | ||
Line 46: | Line 46: | ||
==== Where can I find the change logs? ==== | ==== Where can I find the change logs? ==== | ||
+ | Change logs for beta versions are on the [[https:// | ||
Change logs of the official releases are on [[https:// | Change logs of the official releases are on [[https:// | ||
- | Change logs of the test versions are emailed to the test group. They can also be found on the [[https:// | ||
==== I have a problem, how can I return to the previous version? ==== | ==== I have a problem, how can I return to the previous version? ==== | ||
You can always return to the previously installed version: | You can always return to the previously installed version: |
ccgx/beta-testing.txt · Last modified: 2023-07-05 07:30 by mvader
