ccgx:beta-testing
ccgx:beta-testing [2018-03-20 11:44] – [Venus OS - Beta testing] justin_tyers_live_a_c | ccgx:beta-testing [2023-06-03 22:44] – [Venus OS - Beta testing] mvader | ||
Would you like to become a Beta tester? | Would you like to become a Beta tester? | ||
- | Venus OS - or //Venus// for short - is the operating software for our //Color Control | + | Venus OS - or //Venus// for short - is the operating software for our range of GX monitoring products, such as the Cerbo GX. Extensive field testing over a wide variety of installation-types and user-cases is very valuable to us ...and we're very grateful to you for your interest in joining this program, and for your help. |
- | === What happens when I join the program? === | + | ==== What happens when I join the program? |
The development cycle works like this: We are constantly developing new features, making improvements and fixing bugs for all the various functions of our devices. We test these changes in our factory, and when we're fairly sure they are stable, we combine all these changes for release as a //Venus OS test version//. But only by testing in the real world can we learn how the software works in practise - that's where you come in! You will be informed by email whenever a new test version is available. | The development cycle works like this: We are constantly developing new features, making improvements and fixing bugs for all the various functions of our devices. We test these changes in our factory, and when we're fairly sure they are stable, we combine all these changes for release as a //Venus OS test version//. But only by testing in the real world can we learn how the software works in practise - that's where you come in! You will be informed by email whenever a new test version is available. | ||
Line 12: | Line 12: | ||
When you join the test program, your device will run on these test versions. | When you join the test program, your device will run on these test versions. | ||
- | === What not to do? === | + | ==== What not to do? ==== |
This is a note to dealers & installers: **Do not install test versions on a customer' | This is a note to dealers & installers: **Do not install test versions on a customer' | ||
- | These versions are called //test versions//, or // | + | These versions are called |
- | === Where should I post possible | + | Also, don't contact Victron dealers, installers, support, or sales managers or anyone else in case you see problems while running a beta version. The only channel for issues in such case is the relevant open Venus OS post on the Modifications section on Community. |
- | If you think you have found a bug, please reply to the emails containing | + | ==== Where should I post possible |
+ | If you think you have found a bug, first of all install | ||
- | And don't forget to mention which test version you are using! | + | If the problem also exists with the official release; then contact normal support. |
- | === How to join the program? === | + | If the problem only exists in the beta version, then please post a message on the relevant Venus OS beta version thread on [[https:// |
+ | And don't forget to mention which test version you are using. | ||
+ | ==== How to join the program? | ||
Go to Settings -> Firmware -> Online updates -> Update to, and there select //Latest release candidate// | Go to Settings -> Firmware -> Online updates -> Update to, and there select //Latest release candidate// | ||
To receive the emails about the test versions, make sure you register the device on the VRM Portal, and change the setting so that you have admin rights on the product. | To receive the emails about the test versions, make sure you register the device on the VRM Portal, and change the setting so that you have admin rights on the product. | ||
- | === How can I install the latest beta firmware? === | + | ==== How can I install the latest beta firmware? |
To install beta firmware online follow the instructions above in - //How can I join the program?// | To install beta firmware online follow the instructions above in - //How can I join the program?// | ||
Line 35: | Line 40: | ||
http:// | http:// | ||
- | You will find the Venus GX images in the directory titled: // | + | Which directory to use depends on the GX Device you have: |
+ | * Venus GX: beaglebone | ||
+ | * Cerbo GX: einstein | ||
+ | * MultiPlus-II GX, or EasySolar-II GX: nanopi | ||
- | === How do I know if the firmware I am running is a beta version? === | ||
- | Beta versions are marked with a tilde (~) followed by the test version number. For example, v2.06~12 is test version number 12 of version v2.06. When releasing the final version of v2.06, the tilde and test number are removed, and the firmware is simply released as v2.06. | ||
- | === Where can I find the change logs? === | + | ==== How do I know if the firmware I am running is a offical release? ==== |
- | Change logs of the official releases are on [[https:// | + | |
- | Change logs of the test versions are emailed to the test group. They can also be found on the [[https:// | + | Official releases have a clean version number, ie v2.06, or v2.10. |
- | === I have a problem, how can I return to the previous version? === | + | Version with a tilde in their version number, are either internal test versions, or beta versions. |
+ | For example, v2.06~12 is test version number 12 of version v2.06. The next build will be v2.06~13, and so forth. When releasing the final version of v2.06, the tilde and test number are removed, and the firmware is officially released as v2.06. | ||
+ | ==== Where can I find the change logs? ==== | ||
+ | Change logs for beta versions are on the [[https:// | ||
+ | Change logs of the official releases are on [[https:// | ||
+ | ==== I have a problem, how can I return to the previous version? | ||
You can always return to the previously installed version: | You can always return to the previously installed version: | ||
Line 54: | Line 67: | ||
In case the backup firmware is //also// a test-version, | In case the backup firmware is //also// a test-version, | ||
- | === How can I unsubscribe to the emails? === | + | ==== How can I unsubscribe to the emails? |
- | By un-joining | + | |
- | ===== DISQUS ===== | + | Only be changing |
- | ~~DISQUS~~ | + | |
+ | ==== How can I leave the beta testing | ||
+ | On your GX Device, go to Settings -> Firmware -> Online updates -> Update to. | ||
+ | There, select //Latest release//. | ||
+ | The other option, | ||
ccgx/beta-testing.txt · Last modified: 2023-07-05 07:30 by mvader
