battery_compatibility:zyc_energy
battery_compatibility:zyc_energy [2025-03-05 06:16] – [4. Remote ZYC firmware update via VRM] guy_stewartbattery_compatibility:zyc_energy [2026-06-11 13:14] (current) – guy_stewart
Line 13: Line 13:
 === 1.2 All 48V Multis, MultiPlus, Quattros and RS models are compatible === === 1.2 All 48V Multis, MultiPlus, Quattros and RS models are compatible ===
-The minimum supported firmware version for VE.Bus models is 469. Minimum supported firmware for RS models is 1.16. Updating to the latest firmware is recommended for new installations, and troubleshooting issues.+The minimum supported firmware version for VE.Bus models is 469. These inverter/charger units must be connected to the [[venus-os:start|GX device]] via the VE.Bus connection port.
-These inverter/charger units must be connected to the [[venus-os:start|GX device]] via the VE.Bus connection port. +Minimum supported firmware for Inverter RS and Multi RS models is 1.16, and these must be connected via the VE.Can port, on a seperate VE.Can (250kbps) interface.
 +Updating to the latest firmware is recommended for new installations, and troubleshooting issues.
 In grid connected systems, advanced control functions are configurable in the ESS settings on the [[venus-os:start|GX device]]. In grid connected systems, advanced control functions are configurable in the ESS settings on the [[venus-os:start|GX device]].
Line 68: Line 70:
 ===== 3. Further system integration documentation  ===== ===== 3. Further system integration documentation  =====
-A [[https://ziyouchuangxin.oss-ap-southeast-1.aliyuncs.com/file/SIMPO%205000%20Quick%20Start%20Guide%20_V1.1-final%20EN.pdf|QuickStart guide with further details about installation and configuration is available from ZYC Energy here]].+Please note that these may not be the latest revisions, always check with your battery supplier first for the most up-to-date information.
 +A QuickStart guide with further details about installation and configuration is available from ZYC Energy here.
 +{{ :battery_compatibility:quick-start-of-simpo-5000_v1.7_en-20241228.pdf |}}
 +Their product manual contains further information here.
-[[https://ziyouchuangxin.oss-ap-southeast-1.aliyuncs.com/file/Inverter%20Setting%20Guide%20for%20SIMPO5000%20(No%20Communication%EF%BC%89.pdf|Their product manual contains further information here]].+{{ :battery_compatibility:zyc-simpo-5000_inverter-setting-guide-for-simpo5000_no-communication-offgridshop_en.pdf |}}
-===== 3. Installation Video  =====+===== 3.1 Installation Video  =====
 {{youtube>4Sw4u5UGTpk?medium}} {{youtube>4Sw4u5UGTpk?medium}}
battery_compatibility/zyc_energy.1741155407.txt.gz · Last modified: by guy_stewart
