battery_compatibility:voltsmile
| Next revision | Previous revision | ||
| battery_compatibility:voltsmile [2026-09-23 05:32] – created guy_stewart | battery_compatibility:voltsmile [2026-10-11 21:53] (current) – guy_stewart | ||
| Line 3: | Line 3: | ||
| This page tells you how to set up a Victron Energy system with Voltsmile lithium iron phosphate (LiFePO4) batteries. | This page tells you how to set up a Victron Energy system with Voltsmile lithium iron phosphate (LiFePO4) batteries. | ||
| - | Voltsmile batteries communicate with the Victron [[https:// | + | Voltsmile batteries communicate with the Victron [[https:// |
| - | * Charge Voltage Limit (CVL) | + | |
| - | * Charge Current Limit (CCL) | + | |
| - | * Discharge Current Limit (DCL) | + | |
| - | * State of Charge (SOC) | + | |
| - | * Highest and lowest cell voltages | + | |
| - | * Temperature | + | |
| - | The [[https:// | + | |
| ===== 1. Supported battery models ===== | ===== 1. Supported battery models ===== | ||
| Line 30: | Line 22: | ||
| | S16 | 16.07 | 51.2 V | 314 | | | S16 | 16.07 | 51.2 V | 314 | | ||
| | Monolith | 5.12 (4.61 usable) | 51.2 V | 100 | | | Monolith | 5.12 (4.61 usable) | 51.2 V | 100 | | ||
| + | The battery BMS sends these values to the [[https:// | ||
| + | * State of Charge (SOC) | ||
| + | * Charge Voltage Limit (CVL) | ||
| + | * Charge Current Limit (CCL) | ||
| + | * Discharge Current Limit (DCL) | ||
| + | * Highest and lowest cell voltages | ||
| + | * Temperature | ||
| + | The [[https:// | ||
| The BMS sends the charge and discharge current limits to the [[https:// | The BMS sends the charge and discharge current limits to the [[https:// | ||
| Line 202: | Line 204: | ||
| ===== 13. Inverter/ | ===== 13. Inverter/ | ||
| - | **Important: | + | **Important: |
| * **Charge voltage:** the lower value applies. If the BMS CVL is lower than the charger setting, the CVL applies. If the charger setting is lower than the CVL, the charger setting applies. | * **Charge voltage:** the lower value applies. If the BMS CVL is lower than the charger setting, the CVL applies. If the charger setting is lower than the CVL, the charger setting applies. | ||
| * **Discharge shut-down: | * **Discharge shut-down: | ||
battery_compatibility/voltsmile.1790141550.txt.gz · Last modified: by guy_stewart
