battery_compatibility:voltsmile
battery_compatibility:voltsmile [2026-09-23 08:25] – [1. Supported battery models] guy_stewartbattery_compatibility:voltsmile [2026-10-11 21:53] (current) – guy_stewart
Line 204: Line 204:
 ===== 13. Inverter/charger and MPPT settings ===== ===== 13. Inverter/charger and MPPT settings =====
-**Important:** When DVCC is on, the system compares the BMS limits with the settings in VEConfigure or VictronConnect. The system always uses the more conservative value:+**Important:** When DVCC is on, the system compares the BMS limits with the settings in VEConfigure or VictronConnect. The system always uses the safer value:
   * **Charge voltage:** the lower value applies. If the BMS CVL is lower than the charger setting, the CVL applies. If the charger setting is lower than the CVL, the charger setting applies.   * **Charge voltage:** the lower value applies. If the BMS CVL is lower than the charger setting, the CVL applies. If the charger setting is lower than the CVL, the charger setting applies.
   * **Discharge shut-down:** the higher voltage applies. If the inverter low-voltage shut-down setting is higher than the BMS limit, the inverter stops at its own setting.   * **Discharge shut-down:** the higher voltage applies. If the inverter low-voltage shut-down setting is higher than the BMS limit, the inverter stops at its own setting.
battery_compatibility/voltsmile.txt · Last modified: by guy_stewart
