battery_compatibility:start
battery_compatibility:start [2018-11-21 10:07] – [Battery Compatibility] doesn't need the old way nobody uses any more for ZBM2 - its all BMS and DVCC now simonhackettbattery_compatibility:start [2020-06-23 11:56] – Add willson
 ====== Battery Compatibility ====== ====== Battery Compatibility ======
-Victron inverter/chargers, inverters, chargers, solar chargers and other products work with common battery technologies such as AGM, Gel, OPzS, OPzV, traction batteries and more. But also with other technologies that require a deeper integration and communication between the power electronics and the battery management hardware.+Victron inverter/chargers, inverters, chargers, solar chargersand other products work with common lead-based battery technologies such as AGM, Gel, OPzS, OPzV, traction batteries and more.
-More information:+We also provide some documentation and guidelines for other battery or energy storage technologies that require deeper integration and communication between the power electronics and the battery management hardware.
 +These are sometimes controlled via the CANBus on a [[venus-os:start|GX device]], require special settings or parameters, and proper operation requires testing and adjustment by both battery manufacturer and Victron.
 +Specific information about compatible batteries that have been tested and are supported:
   * [[battery_compatibility:aquion_ahi|Aquion AHI]]   * [[battery_compatibility:aquion_ahi|Aquion AHI]]
   * [[battery_compatibility:axistorage|AXIstorage 7S/9S]]   * [[battery_compatibility:axistorage|AXIstorage 7S/9S]]
-  * [[battery_compatibility:bmz_ess|BMZ ESS 3.0 and ESS 7.0]]+  * [[battery_compatibility:battleborn|BattleBorn]]
 +  * [[battery_compatibility: bluenova |Bluenova Energy Storage]]
 +  * [[battery_compatibility:bmz_ess|BMZ ESS 7.0 ESS 9.0 and ESS X]]
   * [[battery_compatibility:BYD B-Box|BYD B-Box]]   * [[battery_compatibility:BYD B-Box|BYD B-Box]]
 +  * [[battery_compatibility:discover|Discover AES]]
   * [[battery_compatibility:freedomwon|Freedomwon Lithium]]   * [[battery_compatibility:freedomwon|Freedomwon Lithium]]
-  * [[battery_compatibility:lg_chem_resu|LG Chem Resu 6.4]]+  * [[battery_compatibility:greenrock|Greenrock]]
 +  * [[battery_compatibility:lg_chem_resu|LG Chem Resu]] - (Grid Connected ESS Only)
 +  * [[battery_compatibility:mgenergysystems|MG Energy Systems]]
   * [[battery_compatibility: Panasonic DCB105|Panasonic DCB-105 (India)]]   * [[battery_compatibility: Panasonic DCB105|Panasonic DCB-105 (India)]]
-  * [[pylontech_phantom|Pylontech US2000B and Phantom-S]]+  * [[pylontech_phantom|Pylontech UP2500, US2000, US3000, Phantom-S, and Force-L1]]
   * [[battery_compatibility:redflow_zcell|Redflow ZBM2 / ZCell]]   * [[battery_compatibility:redflow_zcell|Redflow ZBM2 / ZCell]]
 +  * [[battery_compatibility:rolls|Rolls LFP]]
   * [[battery_compatibility:simpliphi_power|SimpliPhi Power]]   * [[battery_compatibility:simpliphi_power|SimpliPhi Power]]
-  * [[battery_compatibility: bluenova |Bluenova Energy Storage]] +  * [[battery_compatibility:Solar MD|SolarMD]]
 +  * [[https://www.victronenergy.com/batteries/lithium-battery-12-8v|Victron Lithium Batteries]]
 ~~DISQUS~~ ~~DISQUS~~
battery_compatibility/start.txt · Last modified: 2024-02-22 13:07 by guy_stewart
