battery_compatibility:simpliphi_power
battery_compatibility:simpliphi_power [2017-05-31 11:13] – [Compatible Victron products] mvader | battery_compatibility:simpliphi_power [2019-01-22 10:16] (current) – external edit 127.0.0.1 | ||
- | ====== Victron & SimpliPhi | + | ====== Victron & SimpliPhi |
===== Compatible Victron products ===== | ===== Compatible Victron products ===== | ||
- | The Freedom Lite range of Lithium Iron Phosphate batteries from SimpliPhi (www.simpliphipower.com) | + | 24V and 48V Lithium Iron Phosphate batteries from SimpliPhi (www.simpliphipower.com) |
+ | The SimpliPhi Power batteries are a drop in replacement for lead acid batteries: battery management and safety disconnects are integral to each battery, and there is no control wiring required or software integration required. Simple integration and a wide operating temperature range make these batteries ideal for off-grid solar and diesel-hybrid systems. | ||
+ | An integration guide with the recommended settings for each Victron product is available from SimpliPhi Power. | ||
- | The SimpliPhi Power batteries are a drop in replacement for lead acid batteries: control and safety disconnects are all inside the batteries, and there is no control wiring required. | ||
Line 12: | Line 17: | ||
battery_compatibility/simpliphi_power.1496221984.txt.gz · Last modified: 2017-05-31 11:13 by mvader
