battery_compatibility:redflow_zbm
battery_compatibility:redflow_zbm [2016-06-11 10:01] – [Color Control GX] simonhackett | battery_compatibility:redflow_zbm [2019-01-22 10:16] – external edit 127.0.0.1 | ||
Line 27: | Line 27: | ||
- Control the battery: set it to run mode, initiate a maintenance cycle, clear the alarms and more. | - Control the battery: set it to run mode, initiate a maintenance cycle, clear the alarms and more. | ||
- Configure the battery: the CCGX will automatically assign a unique Modbus address to each battery. Just make sure to connect them, slowly, one by one. After connecting one, wait for it to show up on the CCGX, and then connect the next one. Additionally, | - Configure the battery: the CCGX will automatically assign a unique Modbus address to each battery. Just make sure to connect them, slowly, one by one. After connecting one, wait for it to show up on the CCGX, and then connect the next one. Additionally, | ||
- | ===== Disqus | + | |
+ | ===== DISQUS | ||
battery_compatibility/redflow_zbm.txt · Last modified: 2021-03-20 02:50 by guystewart
