Last revision Both sides next revision
battery_compatibility:pylontech_phantom [2020-07-09 15:44]
iburger [5. VEConfigure Settings]
battery_compatibility:pylontech_phantom [2020-08-26 12:03]
boekel [6. VE.Direct MPPT Settings]
Line 220: Line 220:
 ^MPPT Parameter ^ Setting ^ ^MPPT Parameter ^ Setting ^
 |Battery voltage.     |48V| |Battery voltage.     |48V|
-|Absorption voltage   |53V|+|Absorption voltage   |52V|
 ===== 7. Example Wiring Diagram ===== ===== 7. Example Wiring Diagram =====
battery_compatibility/pylontech_phantom.txt · Last modified: 2020-09-19 11:53 by boekel
