battery_compatibility:hubble
battery_compatibility:hubble [2023-11-01 10:33] – [Configure for Victron] adaptive + save and reboot warwickchapmanbattery_compatibility:hubble [2026-08-27 13:12] (current) – [Minimum Battery Sizing] warwickchapman
Line 36: Line 36:
 This gives the system designer choices.  If budget is the priority, then using an NMC battery like the AM-2 paired with a MultiPlus-II 5kVA (1:1) will result in a reliable solution.  The lower instantaneous power characteristics of the LFP battery, like the AM-5 mean it would be better to put 2 x AM-5 with a single MultiPlus-II 5kVA or 8kVA (2:1 or 1:0.8).  This gives the system designer choices.  If budget is the priority, then using an NMC battery like the AM-2 paired with a MultiPlus-II 5kVA (1:1) will result in a reliable solution.  The lower instantaneous power characteristics of the LFP battery, like the AM-5 mean it would be better to put 2 x AM-5 with a single MultiPlus-II 5kVA or 8kVA (2:1 or 1:0.8).
-Thus, the guidance we give to system designers on Battery:Inverter ratio is:+Thus, the guidance (*) we give to system designers on Battery:Inverter ratio is:
 ^ Chemistry ^ Guideline ^ ^ Chemistry ^ Guideline ^
-| NMC | Battery kWh : Inverter kVA should be at least 1:1 | +| NMC | Battery Max Discharge kW : Inverter kVA should be at least 1:1 |
-| LFP | Battery kWh : Inverter kVA should be > 1:1 |+| LFP | Battery Max Discharge kW : Inverter kVA should be > 1:1 |
 +(*) Note: that the C-rating of the battery must be observed, so with the AM-16+ which has a discharge C-rating of 0.5C, the battery kWh of 16 is twice as high as the Max Discharge power at 8kW.
 ===== Required Firmware Versions ===== ===== Required Firmware Versions =====
Line 172: Line 174:
     - Battery capacity: Use 100Ah per Hubble battery (excl. AM-10: 200Ah, AM-3: 50Ah, S-200: 200Ah, Blade: 137Ah). Eg. If there are 3 x AM-4, then capacity is 300Ah.     - Battery capacity: Use 100Ah per Hubble battery (excl. AM-10: 200Ah, AM-3: 50Ah, S-200: 200Ah, Blade: 137Ah). Eg. If there are 3 x AM-4, then capacity is 300Ah.
     - Sustain voltage, set the value from the tables below     - Sustain voltage, set the value from the tables below
-    - Dynamic cutoff, set the fallback value from the tables below+    - Dynamic cutoff, use the low cutoff value from the tables below
     - Restart offset, set the value from the tables below     - Restart offset, set the value from the tables below
Line 186: Line 188:
 ^ Chemistry ^ Charge ^ Cutoff ^ Restart ^ Sustain ^ Models ^  ^ Chemistry ^ Charge ^ Cutoff ^ Restart ^ Sustain ^ Models ^
 | LiNiMnCo (NMC) | 53.3V | 44.2V | 46.2V | 47.0V | AM-2, AM-3, X101 | | LiNiMnCo (NMC) | 53.3V | 44.2V | 46.2V | 47.0V | AM-2, AM-3, X101 |
-| LiFePO4 (LFP)  | 56.0V | 48.0V | 50.0V | 50.0V | AM-5, AM-10, Blade | +| LiFePO4 (LFP)  | 56.0V | 40.0V | 50.0V | 50.0V | AM-5, AM-10, AM-16, Blade |
-| LiFePO4 (LFP)  | 51.0V | 45.0V | 47.0V | 47.0V | X-100 |+| LiFePO4 (LFP)  | 51.0V | 40.0V | 47.0V | 47.0V | X-100 |
 ==== 24V ==== ==== 24V ====
battery_compatibility/hubble.1698834794.txt.gz · Last modified: by warwickchapman
