battery_compatibility:discover [2020-08-17 09:22] – [4.2 VE.Configure Settings] mvader | battery_compatibility:discover [2021-03-20 03:16] – guystewart | ||
Line 18: | Line 18: | ||
These instructions provide information about the integration of Discover AES Lithium batteries with Victron Energy devices in a Closed Loop configuration using the AES LYNK Communication Gateway with installed AES LYNK Edge Card for Victron. AES batteries can be use in an Energy Storage System (ESS) for self consumption, | These instructions provide information about the integration of Discover AES Lithium batteries with Victron Energy devices in a Closed Loop configuration using the AES LYNK Communication Gateway with installed AES LYNK Edge Card for Victron. AES batteries can be use in an Energy Storage System (ESS) for self consumption, | ||
- | **NOTE:** In a Victron networked system the charging variables will be managed automatically by the AES battery BMS and the Venus GX / Color Control | + | **NOTE:** In a Victron networked system the charging variables will be managed automatically by the AES battery BMS and the GX device. Discharging variables are managed by the set up of the Victron inverter. |
===== 2. Documentation ===== | ===== 2. Documentation ===== | ||
Line 27: | Line 27: | ||
* MultiPlus Inverter Charge Manual | * MultiPlus Inverter Charge Manual | ||
* SmartSolar / BlueSolar Charge Controller Manual | * SmartSolar / BlueSolar Charge Controller Manual | ||
- | * Venus GX (VGX) / Color Control | + | * GX device |
Discover Reference Documents: | Discover Reference Documents: | ||
Line 76: | Line 76: | ||
- | Battery charge and discharge rates are managed automatically by the AES LiFePO4 Battery and Victron | + | Battery charge and discharge rates are managed automatically by the AES LiFePO4 Battery and Victron |
^ Model^ Inverter Peak* ^ Charger ^ 1-Phase Min 42-48-6650 ^ 3-Phase Min 42-48-6650 ^ | ^ Model^ Inverter Peak* ^ Charger ^ 1-Phase Min 42-48-6650 ^ 3-Phase Min 42-48-6650 ^ | ||
Line 105: | Line 105: | ||
* MultiPlus / Quattro - version 459 or later. | * MultiPlus / Quattro - version 459 or later. | ||
- | * GX device to include | + | * GX device |
* VE.Direct MPPT - version 1.42 or later. | * VE.Direct MPPT - version 1.42 or later. | ||
Line 115: | Line 115: | ||
==== 4.2 VE.Configure Settings ==== | ==== 4.2 VE.Configure Settings ==== | ||
- | This section presumes familiarity with VEConfigure software. These settings are for an off-grid application. These parameters once set will become the default values used if communication with the AES battery is interrupted for some reason. During normal operation the charge characteristics are governed automatically by the CCGX via DVCC, with instructions from the connected AES battery. However it is necessary to set the discharging parameters for DC input low shut-down found under the Inverter Tab. After setting the parameters, ‘send’ all parameters to the inverter and CCGX. Restart the CCGX after completion. | + | This section presumes familiarity with VEConfigure software. These settings are for an off-grid application. These parameters once set will become the default values used if communication with the AES battery is interrupted for some reason. During normal operation the charge characteristics are governed automatically by the GX device |
Also keep in mind the settings below are for 1 unit only. If the system is a multiple inverter/ | Also keep in mind the settings below are for 1 unit only. If the system is a multiple inverter/ | ||
Line 155: | Line 155: | ||
==== 4.3 VE.Direct MPPT Settings ==== | ==== 4.3 VE.Direct MPPT Settings ==== | ||
- | During normal operation the MPPT charge characteristics are governed by the CCGX via DVCC, with instructions from the connected AES battery. | + | During normal operation the MPPT charge characteristics are governed by the GX device |
The settings below are precautionary. This section presumes familiarity with VictronConnect (Bluetooth App) used to configure, monitor and diagnose Victron MPPT products which feature Blue-tooth, or are equipped with a VE.Direct Port. | The settings below are precautionary. This section presumes familiarity with VictronConnect (Bluetooth App) used to configure, monitor and diagnose Victron MPPT products which feature Blue-tooth, or are equipped with a VE.Direct Port. | ||
**NOTE:** VE.Can MPPTs cannot be used and are not yet supported | **NOTE:** VE.Can MPPTs cannot be used and are not yet supported | ||
Line 210: | Line 210: | ||
Before connecting LYNK to the Victron Network ensure that the firmware for all Victron devices is up to date. | Before connecting LYNK to the Victron Network ensure that the firmware for all Victron devices is up to date. | ||
- | Insert one end of a CAT5 communication cable into the LYNK Edge Card port and the other end into one of the two VE.Can ports on the back of the Color Control | + | Insert one end of a CAT5 communication cable into the LYNK Edge Card port and the other end into one of the two VE.Can ports on the back of the GX device |
**NOTE:** Discover DC Power Converter and Lynk Gateway are internally terminated | **NOTE:** Discover DC Power Converter and Lynk Gateway are internally terminated | ||
Line 223: | Line 224: | ||
* Turn on all Victron equipment. | * Turn on all Victron equipment. | ||
- | Through the VRM or a physical | + | Through the VRM or a physical |
Line 248: | Line 249: | ||
- | Return to the Device List and the CCGX should display Discover AES as one of the devices along with the battery SoC, Voltage and Amps. If you have multiple batteries a single entry will show up, which represents all batteries. | + | Return to the Device List and the GX device |
**NOTE:** If Discover does not appear on the Device List, confirm that the CAT5 communication cable is a normal patch type and not a cross over type. Use manufactured cables to avoid bad crimps and reduce the risk of a poor | **NOTE:** If Discover does not appear on the Device List, confirm that the CAT5 communication cable is a normal patch type and not a cross over type. Use manufactured cables to avoid bad crimps and reduce the risk of a poor | ||
Line 259: | Line 260: | ||
Once the VE.Can and CAN-bus bit rate is set, communication of the AES battery parameters will be automatic. | Once the VE.Can and CAN-bus bit rate is set, communication of the AES battery parameters will be automatic. | ||
- | During normal operation, the charge parameter limits are set by the BMS of the AES battery and communicated through the system by the CCGX to the inverter/ | + | During normal operation, the charge parameter limits are set by the BMS of the AES battery and communicated through the system by the GX device |
Navigate from the Device List screen > Settings > System Setup> | Navigate from the Device List screen > Settings > System Setup> |
battery_compatibility/discover.txt · Last modified: 2022-09-20 10:52 by mvader
