battery_compatibility:can-bus_bms-cable [2019-10-28 09:48] – [DISQUS] mvaderbattery_compatibility:can-bus_bms-cable [2026-10-10 08:37] (current) – [1. Selecting the right cable] guy_stewart
Line 6: Line 6:
 ===== 1. Selecting the right cable ===== ===== 1. Selecting the right cable =====
-=== ASS030710018 - VE.Can to CAN-bus BMS type A Cable 1.8m ===+=== ASS030710118 - VE.Can to CAN-bus BMS type A Cable 1.8m ===
   * BYD B-Box   * BYD B-Box
 +  * Discover HELIOS ESS (direct to COM2, without LYNK II)
 +  * Hubble Lithium via CloudLink (incl. AM-10+/Blade internal CloudLink)
 +  * Pylontech US2000C/US3000C/UP5000/Force-L
-=== ASS030720018 - VE.Can to CAN-bus BMS type B Cable 1.8m ===+=== ASS030720118 - VE.Can to CAN-bus BMS type B Cable 1.8m ===
-  * LG Chem Resu +  * AXIstorage 7S/9S
-  * AXIstorage+
   * BMZ   * BMZ
-  * Pylontech+  * BSLBATT Lithium battery
 +  * LG Chem Resu
 +  * Pylontech US2000/US3000/UP2500
 +  * Solar MD BMS EX
 +  * Freedom Won eTower
 +=== ASS030064950 RJ45 UTP Cable (Standard Ethernet) ===
 +  * Bluenova Energy Storage
 +  * Cegasa eBick
 +  * Freedom Won LiTE
 +  * MG Energy Systems
 +=== Custom (See Battery Documentation) ===
 +  * Exide
 +  * SolarMD Logger V2
 ===== 2. Installation ===== ===== 2. Installation =====
-The side labeled 'CAN-bus BMS' plugs into the battery. The other side, labeled 'VE.Can' must be plugged into the VE.Can port of the GX device.+The side labeled 'CAN-bus BMS' plugs into the battery. The other side, labeled 'VE.Can' must be plugged into either the VE.Can port of the GX device, or the BMS-Can port.
 +Both port types (VE.Can and BMS-Can) on a GX Device can be configured for use with a CAN-bus BMS connected third party battery.
 For configuration, see the manual specific to the brand of battery you are using. For configuration, see the manual specific to the brand of battery you are using.
battery_compatibility/can-bus_bms-cable.1572256103.txt.gz · Last modified: by mvader
