battery_compatibility:can-bus_bms-cable [2019-01-21 10:39]
ictbeheer [DISQUS]
battery_compatibility:can-bus_bms-cable [2019-10-28 10:48] (current)
mvader [DISQUS]
 ====== VE.Can to CAN-bus BMS cables manual ====== ====== VE.Can to CAN-bus BMS cables manual ======
-Use these [[https://www.victronenergy.com/cables/ve-can-to-can-bus-bms|VE.Can to CAN-bus cables]] to connect a CAN-bus enabled battery to a [[https://www.victronenergy.com/live/venus-os:start|Venus-device]].+Use these [[https://www.victronenergy.com/cables/ve-can-to-can-bus-bms|VE.Can to CAN-bus cables]] to connect a CAN-bus enabled battery to a [[https://www.victronenergy.com/live/venus-os:start|GX device]].
Line 19: Line 19:
 ===== 2. Installation ===== ===== 2. Installation =====
-The side labeled 'CAN-bus BMS' plugs into the battery. The other side, labeled 'VE.Can' must be plugged into the VE.Can port of the Venus-device.+The side labeled 'CAN-bus BMS' plugs into the battery. The other side, labeled 'VE.Can' must be plugged into the VE.Can port of the GX device.
 For configuration, see the manual specific to the brand of battery you are using. For configuration, see the manual specific to the brand of battery you are using.
Line 39: Line 39:
 | CAN-L    | Pin 8        | Pin 5         | | CAN-L    | Pin 8        | Pin 5         |
 | CAN-H    | Pin 7        | Pin 4         | | CAN-H    | Pin 7        | Pin 4         |
battery_compatibility/can-bus_bms-cable.1548063547.txt.gz · Last modified: 2019-01-21 10:39 by ictbeheer
